Finally I did it with this code.
// final result with the added ascii at 1st column
uint8_t new_ascii[855]={
0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, //
0x21, 0x18, 0x3c, 0x3c, 0x18, 0x18, 0x00, 0x18, 0x00, //>!
0x22, 0x6c, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, //"
0x23, 0x6c, 0x6c, 0xfe, 0x6c, 0xfe, 0x6c, 0x6c, 0x00, //#
0x24, 0x30, 0x7c, 0xc0, 0x78, 0x0c, 0xf8, 0x30, 0x00, //$
0x25, 0x00, 0xc6, 0xcc, 0x18, 0x30, 0x66, 0xc6, 0x00, //%
0x26, 0x38, 0x6c, 0x38, 0x76, 0xdc, 0xcc, 0x76, 0x00, //&
0x27, 0x60, 0x60, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, //'
0x28, 0x18, 0x30, 0x60, 0x60, 0x60, 0x30, 0x18, 0x00, //(
0x29, 0x60, 0x30, 0x18, 0x18, 0x18, 0x30, 0x60, 0x00, //)
0x2a, 0x00, 0x66, 0x3c, 0xff, 0x3c, 0x66, 0x00, 0x00, //*
0x2b, 0x00, 0x30, 0x30, 0xfc, 0x30, 0x30, 0x00, 0x00, //+
0x2c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x60, //,
0x2d, 0x00, 0x00, 0x00, 0xfc, 0x00, 0x00, 0x00, 0x00, //-
0x2e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x00, //.
0x2f, 0x06, 0x0c, 0x18, 0x30, 0x60, 0xc0, 0x80, 0x00, //>/
0x30, 0x7c, 0xc6, 0xce, 0xde, 0xf6, 0xe6, 0x7c, 0x00, //0
0x31, 0x30, 0x70, 0x30, 0x30, 0x30, 0x30, 0xfc, 0x00, //1
0x32, 0x78, 0xcc, 0x0c, 0x38, 0x60, 0xcc, 0xfc, 0x00, //2
0x33, 0x78, 0xcc, 0x0c, 0x38, 0x0c, 0xcc, 0x78, 0x00, //3
0x34, 0x1c, 0x3c, 0x6c, 0xcc, 0xfe, 0x0c, 0x1e, 0x00, //4
0x35, 0xfc, 0xc0, 0xf8, 0x0c, 0x0c, 0xcc, 0x78, 0x00, //5
0x36, 0x38, 0x60, 0xc0, 0xf8, 0xcc, 0xcc, 0x78, 0x00, //6
0x37, 0xfc, 0xcc, 0x0c, 0x18, 0x30, 0x30, 0x30, 0x00, //7
0x38, 0x78, 0xcc, 0xcc, 0x78, 0xcc, 0xcc, 0x78, 0x00, //8
0x39, 0x78, 0xcc, 0xcc, 0x7c, 0x0c, 0x18, 0x70, 0x00, //9
0x3a, 0x00, 0x30, 0x30, 0x00, 0x00, 0x30, 0x30, 0x00, //:
0x3b, 0x00, 0x30, 0x30, 0x00, 0x00, 0x30, 0x30, 0x60, //;
0x3c, 0x18, 0x30, 0x60, 0xc0, 0x60, 0x30, 0x18, 0x00, //<
0x3d, 0x00, 0x00, 0xfc, 0x00, 0x00, 0xfc, 0x00, 0x00, //=
0x3e, 0x60, 0x30, 0x18, 0x0c, 0x18, 0x30, 0x60, 0x00, //>
0x3f, 0x78, 0xcc, 0x0c, 0x18, 0x30, 0x00, 0x30, 0x00, //?
0x40, 0x7c, 0xc6, 0xde, 0xde, 0xde, 0xc0, 0x78, 0x00, //@
0x41, 0x30, 0x78, 0xcc, 0xcc, 0xfc, 0xcc, 0xcc, 0x00, //A
0x42, 0xfc, 0x66, 0x66, 0x7c, 0x66, 0x66, 0xfc, 0x00, //B
0x43, 0x3c, 0x66, 0xc0, 0xc0, 0xc0, 0x66, 0x3c, 0x00, //C
0x44, 0xf8, 0x6c, 0x66, 0x66, 0x66, 0x6c, 0xf8, 0x00, //D
0x45, 0xfe, 0x62, 0x68, 0x78, 0x68, 0x62, 0xfe, 0x00, //E
0x46, 0xfe, 0x62, 0x68, 0x78, 0x68, 0x60, 0xf0, 0x00, //F
0x47, 0x3c, 0x66, 0xc0, 0xc0, 0xce, 0x66, 0x3e, 0x00, //G
0x48, 0xcc, 0xcc, 0xcc, 0xfc, 0xcc, 0xcc, 0xcc, 0x00, //H
0x49, 0x78, 0x30, 0x30, 0x30, 0x30, 0x30, 0x78, 0x00, //I
0x4a, 0x1e, 0x0c, 0x0c, 0x0c, 0xcc, 0xcc, 0x78, 0x00, //J
0x4b, 0xe6, 0x66, 0x6c, 0x78, 0x6c, 0x66, 0xe6, 0x00, //K
0x4c, 0xf0, 0x60, 0x60, 0x60, 0x62, 0x66, 0xfe, 0x00, //L
0x4d, 0xc6, 0xee, 0xfe, 0xfe, 0xd6, 0xc6, 0xc6, 0x00, //M
0x4e, 0xc6, 0xe6, 0xf6, 0xde, 0xce, 0xc6, 0xc6, 0x00, //N
0x4f, 0x38, 0x6c, 0xc6, 0xc6, 0xc6, 0x6c, 0x38, 0x00, //O
0x50, 0xfc, 0x66, 0x66, 0x7c, 0x60, 0x60, 0xf0, 0x00, //P
0x51, 0x78, 0xcc, 0xcc, 0xcc, 0xdc, 0x78, 0x1c, 0x00, //Q
0x52, 0xfc, 0x66, 0x66, 0x7c, 0x6c, 0x66, 0xe6, 0x00, //R
0x53, 0x78, 0xcc, 0xe0, 0x70, 0x1c, 0xcc, 0x78, 0x00, //S
0x54, 0xfc, 0xb4, 0x30, 0x30, 0x30, 0x30, 0x78, 0x00, //T
0x55, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0xfc, 0x00, //U
0x56, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0x78, 0x30, 0x00, //V
0x57, 0xc6, 0xc6, 0xc6, 0xd6, 0xfe, 0xee, 0xc6, 0x00, //W
0x58, 0xc6, 0xc6, 0x6c, 0x38, 0x38, 0x6c, 0xc6, 0x00, //X
0x59, 0xcc, 0xcc, 0xcc, 0x78, 0x30, 0x30, 0x78, 0x00, //Y
0x5a, 0xfe, 0xc6, 0x8c, 0x18, 0x32, 0x66, 0xfe, 0x00, //Z
0x5b, 0x78, 0x60, 0x60, 0x60, 0x60, 0x60, 0x78, 0x00, //[
0x5c, 0xc0, 0x60, 0x30, 0x18, 0x0c, 0x06, 0x02, 0x00, //\<
0x5d, 0x78, 0x18, 0x18, 0x18, 0x18, 0x18, 0x78, 0x00, //]
0x5e, 0x10, 0x38, 0x6c, 0xc6, 0x00, 0x00, 0x00, 0x00, //^
0x5f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, //_
0x60, 0x30, 0x30, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, //`
0x61, 0x00, 0x00, 0x78, 0x0c, 0x7c, 0xcc, 0x76, 0x00, //a
0x62, 0xe0, 0x60, 0x60, 0x7c, 0x66, 0x66, 0xdc, 0x00, //b
0x63, 0x00, 0x00, 0x78, 0xcc, 0xc0, 0xcc, 0x78, 0x00, //c
0x64, 0x1c, 0x0c, 0x0c, 0x7c, 0xcc, 0xcc, 0x76, 0x00, //d
0x65, 0x00, 0x00, 0x78, 0xcc, 0xfc, 0xc0, 0x78, 0x00, //e
0x66, 0x38, 0x6c, 0x60, 0xf0, 0x60, 0x60, 0xf0, 0x00, //f
0x67, 0x00, 0x00, 0x76, 0xcc, 0xcc, 0x7c, 0x0c, 0xf8, //g
0x68, 0xe0, 0x60, 0x6c, 0x76, 0x66, 0x66, 0xe6, 0x00, //h
0x69, 0x30, 0x00, 0x70, 0x30, 0x30, 0x30, 0x78, 0x00, //i
0x6a, 0x0c, 0x00, 0x0c, 0x0c, 0x0c, 0xcc, 0xcc, 0x78, //j
0x6b, 0xe0, 0x60, 0x66, 0x6c, 0x78, 0x6c, 0xe6, 0x00, //k
0x6c, 0x70, 0x30, 0x30, 0x30, 0x30, 0x30, 0x78, 0x00, //l
0x6d, 0x00, 0x00, 0xcc, 0xfe, 0xfe, 0xd6, 0xc6, 0x00, //m
0x6e, 0x00, 0x00, 0xf8, 0xcc, 0xcc, 0xcc, 0xcc, 0x00, //n
0x6f, 0x00, 0x00, 0x78, 0xcc, 0xcc, 0xcc, 0x78, 0x00, //o
0x70, 0x00, 0x00, 0xdc, 0x66, 0x66, 0x7c, 0x60, 0xf0, //p
0x71, 0x00, 0x00, 0x76, 0xcc, 0xcc, 0x7c, 0x0c, 0x1e, //q
0x72, 0x00, 0x00, 0xdc, 0x76, 0x66, 0x60, 0xf0, 0x00, //r
0x73, 0x00, 0x00, 0x7c, 0xc0, 0x78, 0x0c, 0xf8, 0x00, //s
0x74, 0x10, 0x30, 0x7c, 0x30, 0x30, 0x34, 0x18, 0x00, //t
0x75, 0x00, 0x00, 0xcc, 0xcc, 0xcc, 0xcc, 0x76, 0x00, //u
0x76, 0x00, 0x00, 0xcc, 0xcc, 0xcc, 0x78, 0x30, 0x00, //v
0x77, 0x00, 0x00, 0xc6, 0xd6, 0xfe, 0xfe, 0x6c, 0x00, //w
0x78, 0x00, 0x00, 0xc6, 0x6c, 0x38, 0x6c, 0xc6, 0x00, //x
0x79, 0x00, 0x00, 0xcc, 0xcc, 0xcc, 0x7c, 0x0c, 0xf8, //y
0x7a, 0x00, 0x00, 0xfc, 0x98, 0x30, 0x64, 0xfc, 0x00, //z
0x7b, 0x1c, 0x30, 0x30, 0xe0, 0x30, 0x30, 0x1c, 0x00, //{
0x7c, 0x18, 0x18, 0x18, 0x00, 0x18, 0x18, 0x18, 0x00, //|
0x7d, 0xe0, 0x30, 0x30, 0x1c, 0x30, 0x30, 0xe0, 0x00, //}
0x7e, 0x76, 0xdc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, //~
/*convert the string to 8x8 dot matrix 8-bytes packets*/
#include <stdio.h>
#include <stdlib.h>
#include <inttypes.h>
#include <string.h>
#include "sketch.h"
#define ascii_index 95
#define buffer_size str1_len*8
uint16_t i,j,k;
int main(void) {
uint8_t str1[]="Hi, how are you?";
uint8_t str1_len=strlen(str1);
uint8_t buffer[buffer_size];
string_read_to_8x8_bytes_out(str1,str1_len,buffer);
for (i=0;i<str1_len;i++)
printf("letter %c:\n", str1[i]);
for (j=0;j<8;j++){
printf("0x%.2x ", buffer[(i*8)+j]);
if (j%8==7)printf("\n");}
return 0;
void string_read_to_8x8_bytes_out(uint8_t *str_in, uint8_t strlen, uint8_t *array_out)
for (i=0;i<strlen;i++)
for (k=0;k<ascii_index;k++)
if (str_in[i]==new_ascii[k*9])
for (j=0;j<8;j++)
array_out[(i*8)+j]=new_ascii[((k*9)+1)+j];
