I am using ESP32 Ping from this page: GitHub - pbecchi/ESP32_ping: Ping library for ESP32
At first it works fine, no compiler error. Works perfectly on ESP32.
Because I upgraded my old Arduino IDE 1.8.7 to newest 1.8.8 version, now ESP32 Ping doesn't work anymore.
Compiler error in Ping.cpp file:
//Ping.cpp
#include <Arduino.h>
#include <math.h>
#include <float.h>
#include <signal.h>
#include <stdint.h>
#include <string.h>
#include <errno.h>
#include "ping.h"
#include "lwip/inet_chksum.h"
#include "lwip/ip.h"
#include "lwip/ip4.h"
#include "lwip/err.h"
#include "lwip/icmp.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include "lwip/netdb.h"
#include "lwip/dns.h"
static uint16_t ping_seq_num;
static uint8_t stopped = 0;
* Statistics
static uint32_t transmitted = 0;
static uint32_t received = 0;
static float min_time = 0;
static float max_time = 0;
static float mean_time = 0;
static float last_mean_time = 0;
static float var_time = 0;
#define PING_ID 0xAFAF
#define PING_DEFAULT_COUNT 10
#define PING_DEFAULT_INTERVAL 1
#define PING_DEFAULT_SIZE 32
#define PING_DEFAULT_TIMEOUT 1
* Helper functions
static void ping_prepare_echo(struct icmp_echo_hdr *iecho, uint16_t len) {
size_t i;
size_t data_len = len - sizeof(struct icmp_echo_hdr);
ICMPH_TYPE_SET(iecho, ICMP_ECHO);
ICMPH_CODE_SET(iecho, 0);
iecho->chksum = 0;
iecho->id = PING_ID;
iecho->seqno = htons(++ping_seq_num);
/* fill the additional data buffer with some data */
for (i = 0; i < data_len; i++) {
((char*)iecho)[sizeof(struct icmp_echo_hdr) + i] = (char)i;
iecho->chksum = inet_chksum(iecho, len);
static err_t ping_send(int s, ip4_addr_t *addr, int size) {
struct icmp_echo_hdr *iecho;
struct sockaddr_in to;
size_t ping_size = sizeof(struct icmp_echo_hdr) + size;
int err;
iecho = (struct icmp_echo_hdr *)mem_malloc((mem_size_t)ping_size);
if (!iecho) {
return ERR_MEM;
ping_prepare_echo(iecho, (uint16_t)ping_size);
to.sin_len = sizeof(to);
to.sin_family = AF_INET;
inet_addr_from_ipaddr(&to.sin_addr, addr);
if ((err = sendto(s, iecho, ping_size, 0, (struct sockaddr*)&to, sizeof(to)))) {
transmitted++;
free(iecho)
return (err ? ERR_OK : ERR_VAL);
static void ping_recv(int s) {
char buf[64];
int fromlen, len;
struct sockaddr_in from;
struct ip_hdr *iphdr;
struct icmp_echo_hdr *iecho = NULL;
char ipa[16];
struct timeval begin;
struct timeval end;
uint64_t micros_begin;
uint64_t micros_end;
float elapsed;
// Register begin time
gettimeofday(&begin, NULL);
// Send
while ((len = recvfrom(s, buf, sizeof(buf), 0, (struct sockaddr*)&from, (socklen_t*)&fromlen)) > 0) {
if (len >= (int)(sizeof(struct ip_hdr) + sizeof(struct icmp_echo_hdr))) {
// Register end time
gettimeofday(&end, NULL);
/// Get from IP address
ip4_addr_t fromaddr;
inet_addr_to_ipaddr(&fromaddr, &from.sin_addr);
strcpy(ipa, inet_ntoa(fromaddr));
// Get echo
iphdr = (struct ip_hdr *)buf;
iecho = (struct icmp_echo_hdr *)(buf + (IPH_HL(iphdr) * 4));
// Print ....
if ((iecho->id == PING_ID) && (iecho->seqno == htons(ping_seq_num))) {
received++;
// Get elapsed time in milliseconds
micros_begin = begin.tv_sec * 1000000;
micros_begin += begin.tv_usec;
micros_end = end.tv_sec * 1000000;
micros_end += end.tv_usec;
elapsed = (float)(micros_end - micros_begin) / (float)1000.0;
// Update statistics
// Mean and variance are computed in an incremental way
if (elapsed < min_time) {
min_time = elapsed;
if (elapsed > max_time) {
max_time = elapsed;
last_mean_time = mean_time;
mean_time = (((received - 1) * mean_time) + elapsed) / received;
if (received > 1) {
var_time = var_time + ((elapsed - last_mean_time) * (elapsed - mean_time));
// Print ...
log_d("%d bytes from %s: icmp_seq=%d time=%.3f ms\r\n", len, ipa,
ntohs(iecho->seqno), elapsed
return;
else {
// TODO
if (len < 0) {
log_d("Request timeout for icmp_seq %d\r\n", ping_seq_num);
static void stop_action(int i) {
signal(i, SIG_DFL);
stopped = 1;
* Operation functions
void ping(const char *name, int count, int interval, int size, int timeout) {
// Resolve name
hostent * target = gethostbyname(name);
IPAddress adr = *target->h_addr_list[0];
if (target->h_length == 0) {
// TODO: error not found target?????
return;
ping_start(adr, count, interval, size, timeout);
bool ping_start(struct ping_option *ping_o) {
return ping_start(ping_o->ip,ping_o->count,0,0,0);
bool ping_start(IPAddress adr, int count=0, int interval=0, int size=0, int timeout=0) {
// driver_error_t *error;
struct sockaddr_in address;
ip4_addr_t ping_target;
int s;
// Get default values if argument are not provided
if (count == 0) {
count = PING_DEFAULT_COUNT;
if (interval == 0) {
interval = PING_DEFAULT_INTERVAL;
if (size == 0) {
size = PING_DEFAULT_SIZE;
if (timeout == 0) {
timeout = PING_DEFAULT_TIMEOUT;
// Create socket
if ((s = socket(AF_INET, SOCK_RAW, IP_PROTO_ICMP)) < 0) {
// TODO: error
return false;
address.sin_addr.s_addr = adr;
ping_target.addr = address.sin_addr.s_addr;
// Setup socket
struct timeval tout;
// Timeout
tout.tv_sec = timeout;
tout.tv_usec = 0;
if (setsockopt(s, SOL_SOCKET, SO_RCVTIMEO, &tout, sizeof(tout)) < 0) {
closesocket(s);
// TODO: error
return false;
stopped = 0;
transmitted = 0;
received = 0;
min_time = 1.E+9;// FLT_MAX;
max_time = 0.0;
mean_time = 0.0;
var_time = 0.0;
// Register signal for stop ping
//signal(SIGINT, stop_action);
// Begin ping ...
char ipa[16];
strcpy(ipa, inet_ntoa(ping_target));
log_i("PING %s: %d data bytes\r\n", ipa, size);
ping_seq_num = 0;
while ((ping_seq_num < count) && (!stopped)) {
if (ping_send(s, &ping_target, size) == ERR_OK) {
ping_recv(s);
delay( interval*1000L);
closesocket(s);
log_i("%d packets transmitted, %d packets received, %.1f%% packet loss\r\n",
transmitted,
received,
((((float)transmitted - (float)received) / (float)transmitted) * 100.0)
if (received) {
ping_resp pingresp;
log_i("round-trip min/avg/max/stddev = %.3f/%.3f/%.3f/%.3f ms\r\n", min_time, mean_time, max_time, sqrt(var_time / received));
pingresp.total_count = 10;
pingresp.timeout_count = 10;
pingresp.total_bytes = 1;
pingresp.total_time = mean_time;
pingresp.ping_err = 0;
return true;
// ping_o->sent_function(ping_o, (uint8*)&pingresp);
return false;
bool ping_regist_recv(struct ping_option *ping_opt, ping_recv_function ping_recv)
if (ping_opt == NULL)
return false;
ping_opt->recv_function = ping_recv;
return true;
bool ping_regist_sent(struct ping_option *ping_opt, ping_sent_function ping_sent)
return false;
ping_opt->sent_function = ping_sent;
return true;
Arduino IDE 1.8.8. compiler stop in this line:
The error message: 'inet_addr_to_ipaddr' was not declared in this scope
How to fix this?
Please help...
