[Solved] Nrf24 arduino nano has weird output
I'm trying to get two test sketches to work for the Nrf24l01 PA module with an arduino nano, but for some reason it will not work:
/* Tranmsitter code for the Arduino Radio control with PWM output
 * Install the NRF24 library to your IDE
 * Upload this code to the Arduino UNO, NANO, Pro mini (5V,16MHz)
 * Connect a NRF24 module to it:
    Module // Arduino UNO,NANO
    GND    ->   GND
    Vcc    ->   3.3V
    CE     ->   D9
    CSN    ->   D10
    CLK    ->   D13
    MOSI   ->   D11
    MISO   ->   D12
This code transmits 1 channels with data from pins A0 POTENTIOMETER
Please, like share and subscribe : https://www.youtube.com/c/ELECTRONOOBS
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
const uint64_t my_radio_pipe = 0xE8E8F0F0E1LL; //Remember that this code should be the same for the receiver
RF24 radio(9, 10);
// The sizeof this struct should not exceed 32 bytes
struct Data_to_be_sent {
  byte ch1;
Data_to_be_sent sent_data;
  radio.begin();
  radio.setAutoAck(false);
  radio.setDataRate(RF24_250KBPS);
  radio.openWritingPipe(my_radio_pipe);
  sent_data.ch1 = 127;
  /*If your channel is reversed, just swap 0 to 255 by 255 to 0 below
  EXAMPLE:
  Normal:    data.ch1 = map( analogRead(A0), 0, 1024, 0, 255);
  Reversed:  data.ch1 = map( analogRead(A0), 0, 1024, 255, 0);  */
  sent_data.ch1 = map( analogRead(A0), 0, 1024, 0, 255);
  radio.write(&sent_data, sizeof(Data_to_be_sent));
  Serial.println("potentiometer: ");
  Serial.print(sent_data.ch1);
/* Receiver code for the Arduino Radio control with PWM output
    GND    ->   GND
    Vcc    ->   3.3V
    CE     ->   D9
    CSN    ->   D10
    CLK    ->   D13
    MOSI   ->   D11
    MISO   ->   D12
This code receive 1 channels and prints the value on the serial monitor
#include <SPI.h>
#include <RF24.h>
const uint64_t pipeIn = 0xE8E8F0F0E1LL;     //Remember that this code is the same as in the transmitter
RF24 radio(9, 10);  //CSN and CE pins
struct Received_data {
  byte ch1;
int ch1_value = 0;
Received_data received_data;
  //We reset the received values
  received_data.ch1 = 127;
  //Once again, begin and radio configuration
  radio.begin();
  radio.openReadingPipe(1,pipeIn);
  //We start the radio comunication
  radio.startListening();
unsigned long last_Time = 0;
//We create the function that will read the data each certain time
void receive_the_data()
  while ( radio.available() ) {
  radio.read(&received_data, sizeof(Received_data));
  last_Time = millis(); //Here we receive the data
  //Receive the radio data
  receive_the_data();
  ch1_value = map(received_data.ch1,0,255,1000,2000);
  Serial.println(ch1_value);
}//Loop end
this is what i get in the serial monitor of the transmitter:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
158potentiometer:
and this in the receiver:
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
transmitter:
receiver:
was a simple wiring error, fixed
