[SOLVED]Sub not declared
AruinoIDE 2.3.4 - Board UNO
Hi Group, as I am not a wel trained programmer I run into a problem.
getting during compilation a error: 'runTimeClock' was not declared in this scope
// (c) Harry H.Arends
#include <Wire.h>
#include <LiquidCrystal_I2C.h  >
//#include <TimeLib.h>
#include <AccelStepper.h>
#include <MultiStepper.h>
const int enPin = 8;
const int stepXPin = 2;  //X.STEP
const int dirXPin = 5;   // X.DIR
const int stepYPin = 3;  //Y.STEP
const int dirYPin = 6;   // Y.DIR
// Define the stepper motor and the pins that is connected to
AccelStepper stepperX(1, stepXPin, dirXPin);  // (Typeof driver: with 2 pins, STEP, DIR)
AccelStepper stepperY(1, stepYPin, dirYPin);
byte index = 0;  // Index into array; where to store the character
const byte numChars = 15;
char inChar;  // Where to store the character read
char *AXpos;
char *EYpos;
char AXposR[7];
char EYposR[7];
char inData[numChars];  // an array to store the received data
const char *delimiter = ",";
const long _maxRotorAX = 18000L;  // maximum rotor azimuth in degrees * 1000
const long _maxRotorEY = 18000L;  // maximum rotor elevation in degrees * 1000
long lastTime = 0;
long minutes = 0;
long hours = 0;
unsigned long value;
LiquidCrystal_I2C lcd(0x27, 20, 4);  // set the LCD address to 0x27 for a 16 chars and 2 line display
boolean newData = false;
boolean newTime = false;
unsigned long start, finished, elapsed;
  Serial.begin(9600); // initialize serial communication
  //while (!Serial.available())
  //  delay(0);
  value = millis();
  lcd.init();  // initialize the lcd
               // Print a message to the LCD.
  lcd.backlight();
  lcd.setCursor(0, 0);  // LCD row1
  lcd.print("     XY-Antenna");
  lcd.setCursor(0, 1);  // LCD row1
  //lcd.print("RT= 00 00:00:00");
  //lcd.print("Et= ");
  runTimeClock();
  lcd.setCursor(0, 2);
  lcd.print("Arduino LCM IIC 2004");
  lcd.setCursor(1, 3);
  lcd.print("(c)Harry H. Arends");
  Serial.println("XtTrm Ready");
  stepperX.setMaxSpeed(10000);     // Set maximum speed value for the stepper
  stepperX.setAcceleration(1000);  // Set acceleration value for the stepper
  stepperX.setCurrentPosition(0);  // Set the current position to 0 steps
  stepperY.setMaxSpeed(10000);
  stepperY.setAcceleration(500);
  stepperY.setCurrentPosition(0);
  recvWithEndMarker();
  processNewData();
  extractData();
  updateDisplay();
  runTimeClock();
void recvWithEndMarker() {
  static byte ndx = 0;
  char endMarker = '\n';
  char rc;
  while (Serial.available() > 0 && newData == false) {
    rc = Serial.read();
    if (rc != endMarker) {
      inData[ndx] = rc;
      ndx++;
      if (ndx >= numChars) {
        ndx = numChars - 1;
      inData[ndx] = '\0';  // terminate the string
      ndx = 0;
      newData = true;
void processNewData() {
  if (newData == true) {
    //Serial.print("This came just in ... ");
    //Serial.println(inData);
    //    newData = false;
void extractData() {
  //Extract two numbers from received data
    AXpos = strtok(inData, delimiter);
    EYpos = strtok(NULL, delimiter);
  void updateDisplay() {
    if (newData) {
      // Clear used rows
      //         12345678901234567890
      lcd.print("                    ");
      lcd.setCursor(0, 3);
      lcd.print("                    ");
      lcd.print("Xt= ");
      lcd.print(AXpos);
      lcd.print("Yt= ");
      lcd.print(EYpos);
      lcd.setCursor(8, 1);
      newData = false;
  void runTimeClock() {
    uint16_t seconds = 0, minutes = 0, hours = 0, days = 0;
    static uint32_t lastTime = -1000;
    static uint32_t count = 0;
    uint32_t now = millis();
    lcd.setCursor(5, 1);
    if (now - lastTime >= 1000) {
      lastTime = now;
      now = count;
      ++count;
      seconds = now % 60;
      now /= 60;
      minutes = now % 60;
      now /= 60;
      hours = now % 24;
      days = now / 24;
      lcd.print(days);
      lcd.print(" ");
      lcd.print(hours);
      printDigits(minutes);
      printDigits(seconds);
  void printDigits(int digits) {
    // utility function for digital clock display: prints preceding colon and leading 0
    lcd.print(":");
    if (digits < 10)
      //Serial.print('0');
      lcd.print('0');
    //Serial.print(digits);
    lcd.print(digits);
If I move this sub to the top the next sub produces a error.
My question is as follows: should I move all the subs to the start of the sketch or can it be solved in a other way??
You have a syntax error at least one, viz:
    if (newData) {
Autoformat your code and balance your { braces }. You can't have a function definition inside the body of another function.
These errors are easier to spot in formatted code, also the IDE will help match braces if you hover near the open brace it should highlight the closing brace, or something like that, click the open brace? Knowledge in my elbows, sry I can't say exact.
a7
Your LiquidCrystal_I2C.h has a whitespace in the line causing an error "not found"
You have commented-out TimeLib.h so every reference to "time" is an error... and I do not know which TimeLib.h you have, so I get errors regardless. wrong... read on...
This function is missing an end brace, causing many errors... extractData()
