(Solved) Weird Characters on LCD Screen Driving me mad!
Good evening,
Please could someone help. I have been wiring up a 16 x 2 LCD screen with an Arduino Uno and trying various code. At first I got on really well and it was doing exactly as I wanted, learning the code well. then yesterday the screen started showing unusual characters.
I have re-wired it numerous times to ensure that I have done it exactly as it is meant to be. And I have taken the code back to basics but it is still causing the same issue.
I have even bought another LCD screen just in case it was that.
Here is the code: -
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,11,5,4,3,2);
  lcd.begin(16,2);
  lcd.begin(16,2);
  lcd.setCursor(0,0);
  lcd.print("Hello");
  delay (500);
I have also attached a photo for reference.
Hopefully someone will be able to assist.
Thanks.
To start, your header soldering needs to be re-flowed.
LearningtoCode:
Here is the code: -
  lcd.begin(16,2);
  lcd.setCursor(0,0);
  lcd.print("Hello");
  delay (500);
why are you calling begin() every time through loop()?
set it in setup() and forget it!
LarryD:
+1. Look at the fourth one from the right. It has barely any solder on the actual join.
This might be some other issues, too, since "Hello" does not appear in the correct row-column position. What happens with this code:
  lcd.begin(16,2);
  lcd.setCursor(0,0);
  lcd.print("                ");    // 16 spaces
  lcd.setCursor(0,1);
  lcd.print("                ");
  int i;
  for (i = 0, i < 11; i++) {
    lcd.setCursor(i,0);
    lcd.print("Hello");
    delay (1000);
    lcd.setCursor(i,0);
    lcd.print("                ");    // 16 spaces again
Try this , eliminates some redundant coding
  // initialize and clears LCD
  lcd.begin(16,2);
 delay (5000); // is the display clear for 5 seconds ?
  lcd.clear(); // clear display
  lcd.print("Hello");// writes to line 0, position 0
  delay (5000); // show hello for 5 seconds
  lcd.print("The quick brown fox jump over the lazy dog  1234567890" // writes to line 0, starting position 0 uses most ASCII printable characters and may not write all of them on LCD or overwrite some
  delay (5000); // show it for 5 seconds
Hi all,
Thank you for the responses so far.
I have just quickly touched up some of the soldering and also tried the code above but it is still not working. I tried with both screens to see if it made a difference but neither are showing what they are meant to.
Se attached photos.
What does +5v read at the LCD?
With the power off, check the resistance from each pin at the LCD to the corresponding ARDUINO header pin.
The contrast could be lowered.
Have you tried using different pins for the display, like:
LiquidCrystal lcd(12,11,7,6,5,4);
Next, can you test the code on a different Arduino? Finally, do you know that the display works with this LiquidCrystal library? (I think there is more than one LiquidCrystal library.)
LarryD:
I will give this a go when I get home this evening.
econjack:
I do have an Arduino Micro which I have tried it with but am still getting the same problem. I will try testing the different pins when I get home. Now that is an interesting question with the library. The library was for the first LCD screen I had, although I have bought a similar screen (both 16 x 2 LCD's) I am not sure it is correct, I just assumed it would be. How could I check this?
econjack:
Thank you!
I have solved it with.... https://learn.sparkfun.com/tutorials/oled-display-hookup-guide/firmware
Being a beginner I didn't realise an OLED display was different. It has to be wired differently and use a different Library.
Thank you all for your responses.
Thank you ! Solved at least my problem !
