I'm trying to send text to Arduino (Mega 2560) from Windows 10 (via Windows CMD or PuTTY) over Serial. I am using an RS232 to USB converter with a DB9 connector (based on an FTDI USB Serial converter chip) wired to Arduino's Serial1.
The problem is that wrong characters are received. For example:
sent | received
a | O
b | '
c | N
d |
e | M
g | L
i | K
No matter which device (PC/Arduino) is the sender and which one the receiver, the same thing happens; when I send 'c', I receive 'N'!
Packet format on both sides is configured to 8N1 and the baudrate is also correctly set.
This is the code I'm using on Arduino to receive each character from CMD/PuTTY and echo it on Serial Monitor:
Serial1.begin(115200);
while( Serial1.available() ){
char incoming = Serial1.read();
Serial.print(incoming);
I wonder what could be causing this :-\ Any help will be greatly appreciated!
Thanks ![]()
