Some intermediate relay control. Willing to pay!
Alright, so I'm going to describe this as well as I possibly can. Also, note that I am very much willing to pay if someone can do this for me. If you need any more information on it, please reply.
So I am making a giant ray gun basically, but the function of this is beside the point tbh. I need an Arduino to drive a relay board. This project is a prop for an upcoming event, so I need this code pretty quickly-- in the next week and a half or so. I have an 8 channel Relay board and need it to do several things. I'll make a description of what I want to be done on each channel here. I also have 9 buttons to control this relays.
I am operating on an Arduino Uno, and there should be enough outputs/inputs to handle this, but if there isn't, please tell me. I can handle the wiring of the Relay board, but I'd like you to handle the arduino side to fit the code. I may be a newb with coding, but I know wiring very well, so.
Hopefully this is enough information, please give me a quote first on the price, I'm getting re-embursed for whatever the cost of this project is, so I've got no reason not to pay you-- I don't totally get how this arrangement works on here so yeah. I've got venmo and all that stuff so I'm flexible.
thanks,
Alex
Button functions:
Button 1
this button will deal with channels 1 and 2 of the relay board
These two together will drive a linear actuator. When channel 1 is activated, it will drive the actuator forward, when channel two is activated it will drive the actuator in reverse.
When the button is pressed for this channel, I need it to reverse the actuator (activate relay 2) for a set amount of time (that exact time I still need to figure out, so ideally this is easily editable), pause and hold position (no relays are on) and Activate Relay 1 again, for the same amount of time as relay 2 (to return the actuator to its home position)
This is by far the most difficult relay to do in this project.
In simple terms, this happens:
Button 1 is pushed* --> Relay 2 is activated for XX ms, pauses for YY ms, Relay 1 is activated for XX ms
Button 2: this deals with channel 3 of the relay board (sorry that difference in numbers is probably annoying)
This relay should be a simple one, if button 3 is pushed, this relay is on, if it isn't pushed, Relay 3 is off.
It may seem like its pointless to even use a relay for this but you'll understand later here.
Button 3: this deals with channel 4 of the board (again sorry)
This is identical to button 2 except its for the next channel. Button pushed =on, button unpushed = off
Button 4: this button will drive a motor. When it is pushed once, the motor turns on, when it is pushed a second time, the motor turns off. The motor is hooked up to channel 5 of the relay board
Button 5: drives channel 6 of the relay board
this is just like buttons 2 and 3. When pushed, the relay is on, when unpushed the relay is off. C
Button 6: This drives channel 7 of the relay board. same as buttons 2,3, and 5. When pushed it's on, when unpushed it's off.
Button 7, just like 2,3,5,6. Drives channel 8 of the relay board, When pushed its on when unpushed it's off.
BUTTON 8: THIS IS WHERE ITS A LITTLE DIFFERENT. WHEN THIS IS PUSHED, IT WILL ACTIVATE A SERIES OF RELAYS
It activates relays 5, and 7. They remain on until either of the following happens-- Button 8 is pushed, or button 9 is pushed.
BUTTON 9:
When button 9 is pushed, several things happen
The sequence described for button 1 is triggered,
Relay 3 is triggered for XX amount of time
Relay 4 is triggered for XX amount of time
Relay 5 remains active for XX amount of time
Relay 6 is triggered for XX amount of time
Relay 7 is deactivated
Relay 8 is activated for XX amount of time
when that XX time is up everything is deactivated. The BUTTON 1 sequence should be allowed to play out though.
If ya got any questions please respond. Like I said this is timely.
After button eight has been pressed, are the other buttons locked out apart from button nine?
yes they should be. Isn't extremely important but that would be ideal.
Is a press on button nine the finalé? Can you press buttons after that?
(deleted)
