I simply try to create a short LED wave that circularly switch 3LED´s with diferent intensity. Can somebody explain why this routine don´t work as I want?
There are software PWM libraries.
I tried a software PWM:
// For: https://forum.arduino.cc/t/something-as-8led-snake/1039552
// Using the SoftPWM library: https://github.com/bhagman/SoftPWM
// There is a other one: https://github.com/Palatis/arduino-softpwm
#include <SoftPWM.h>
SoftPWMBegin();
for (int i = 2; i <= 9; i++) // pin 2 up to 9
SoftPWMSet(i, 0);
SoftPWMSetFadeTime(ALL, 50, 100);
for (int i=2; i<9; i++)
SoftPWMSet(i, 255);
delay(100);
SoftPWMSet(i, 0);
for (int i=9; i>=2; i--)
SoftPWMSet(i, 255);
delay(100);
SoftPWMSet(i, 0);
The sketch in Wokwi: 8LED-snake.ino - Wokwi Arduino and ESP32 Simulator
You could copy my diagram.json to your Wokwi project.
I don't know if my sketch uses the library correctly. You have to check that yourself.
Watch your sketch in the wokwi.
I see you have a few special cases, but consider what happens when thisPin gets up near highestPin.
Oh, actually I see your sketch works perfectly.
Of course your sketch is doing exactly what you said.
So never mind.
a7
I used the library @Koepel mentioned and just used it in @tombugkh's sketch, just replacing the analogWrite() calls:
The wokwi isn't that good at LED display, soI had to adjust the dimness numbers. And I believe I cancelled the library fade out idea, which is entirely exploitable but I wanted to see what the OP's original logic turned out.
But to really see Imma have to build a little one IRL.
a7
