Songle relays
I'd like to know how reliable are those 5V Songle relays on the many breakout board that are sold on ebay/other places ?
They're marked at 10Amps for 120V or 240V (in my case, I would use them on main's 120V)
Would guys rely on them:
  • at the full 10 amps ?
  • on a resistive or inductive load?
Thanks for you answers and ideas :slight_smile:
We need a link to the datasheet to know what you are talking about.
And you need to tell us what the relay will be controlling.
Personally I would like my relays to have at least twice the capacity of my actual load. But I am certainly not an expert.
...R
You're right,
Here is the relay datasheet : http://pub.ucpros.com/download/27115-Songle-Relay-Datasheet.pdf?osCsid=kaoa7n7eeqvl4v5ct4s6giap72
Form C
As for things connected, that is still to be determined.. its more of a "would you connect a 10A" load on those relay?" question
i want to experiment with IoT devices and want to build a remote power bar. So basically, there could be any type of things connected on the bar and be a load on the relay.
The approval agency file(s) listed in the datasheet will give more detailed information. Generally, I would only consider using them for up to 5A loads. For highly inductive loads, they show only 3A rating. Songle's SLA type might be better suited for your application.
If just switching on/off, consider a MOSFET. 10A is not a large current for many common MOSFETs. There is no arcing contacts to burn out. It depends on your usage of course.
Weedpharma
I would never attempt to switch a 10 amp AC load with those relays. Use a solid state relay (SSR) instead.
Also note that the relay contact voltage rating for DC circuits is very different from AC.
HERES: the SLA on an optically-isolated board for =$5
DISCLAIMER: Mentioned stuff from my own shop...
weedpharma:
Weedpharma
Thanks but i'l be switching a AC load.
In that case, a triac with a zero-cross opto and a snubber circuit would be better choice :wink:
Rigor_M:
Or more simply, an off the shelf SSR.
Weedpharma
