Aaah, so kickback diodes prevent voltage spikes which could destroy the circuit. I could prevent that with an IRFZ44e which is rated up to 60v and install the diode in parallel with the inductive load, but backwards
Perfect-o. I'll give it a try right now
No, all you need to do is place a reverse biased diode (1N4007) across each solenoid coil terminals.
I've been working on this for 3 weeks!!! You solved my problem in a few short conversations. Thank you so much Red_Car. Made my day!
Will do. Definitely want to protect this build. Thank you
