(OK, I know it's not a sensor, it's an actuator, so mods feel free to move this thread :D)
I'm thinking of using an electromagnet on the end of a robot arm to pick stuff up. So far the smallest one I found is here (14kg lift) but a tiny one that can lift a few 100g would do.
I know I can make one with an old nail and some wire, would rather buy one.
But as it happens, I remembered there was one in my junk box. It came out of a copier / printer that I stripped- I think it was part of the door latch or some other kind of interlock safety thing.
It has no label so I took a flyer and threw about 10VDC into it and it seems to work.
MarkT:
Either way remember to drive it like a relay with a big enough transistor/FET and a free-wheeling diode.
Yep... I might not control it from the Arduino at all, might just switch it manually straight from its power.
Bit of a hassle that these things seem to be 12v (it has no label though), but I tested it at 6v which is what the rest of the kit will use and it does work... I suppose it might not be as strong at low voltages but I want it to be able to lift a few washers or panel pins is all.
MarkT:
At half voltage it'll be about 1/2 the magnetic field and 1/4 the power dissipation - the power saving alone is probably
valuable.
