Is it possible to sort different data points coming in over the 1 serial port? I want to send multiple sensor readings from an arduino mega over to an ESP via UART and was wondering if its possible to sort the data so that I can store the data in the correct variables e.g. temperature and humidity sensors send data to the esp, esp then stores the temperature values in a temperature variable and the humidity values in a humidity variable. I made a post earlier on the same project that I'm working on but with a different (solved) problem. I believe this link provides enough context. Thanks. Why does serial2.read break the code?
EDIT: ESP Code
#define RXD2 16
#define TXD2 17
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#if defined(ESP32)
#include <WiFiMulti.h>
WiFiMulti wifiMulti;
#define DEVICE "ESP32"
#elif defined(ESP8266)
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti wifiMulti;
#define DEVICE "ESP8266"
#define WIFI_AUTH_OPEN ENC_TYPE_NONE
#endif
#include <InfluxDbClient.h>
#include <InfluxDbCloud.h>
// WiFi AP SSID
#define WIFI_SSID ""
// WiFi password
#define WIFI_PASSWORD ""
// InfluxDB v2 server url, e.g. https://eu-central-1-1.aws.cloud2.influxdata.com (Use: InfluxDB UI -> Load Data -> Client Libraries)
#define INFLUXDB_URL ""
// InfluxDB v2 server or cloud API authentication token (Use: InfluxDB UI -> Load Data -> Tokens -> <select token>)
#define INFLUXDB_TOKEN ""
// InfluxDB v2 organization id (Use: InfluxDB UI -> Settings -> Profile -> <name under tile> )
#define INFLUXDB_ORG ""
// InfluxDB v2 bucket name (Use: InfluxDB UI -> Load Data -> Buckets)
#define INFLUXDB_BUCKET ""
// Set timezone string according to https://www.gnu.org/software/libc/manual/html_node/TZ-Variable.html
// Examples:
// Pacific Time: "PST8PDT"
// Eastern: "EST5EDT"
// Japanesse: "JST-9"
// Central Europe: "CET-1CEST,M3.5.0,M10.5.0/3"
#define TZ_INFO ""
// InfluxDB client instance with preconfigured InfluxCloud certificate
InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN, InfluxDbCloud2CACert);
// InfluxDB client instance without preconfigured InfluxCloud certificate for insecure connection
//InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN);
// Data point
Point sensorReadings("measurements");
float temperature;
Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
// Setup wifi
WiFi.mode(WIFI_STA);
wifiMulti.addAP(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to wifi");
while (wifiMulti.run() != WL_CONNECTED) {
Serial.print(".");
// Add tags
sensorReadings.addTag("ESP32", DEVICE);
sensorReadings.addTag("TENT", "D1.168");
sensorReadings.addTag("sensor", "IRTEMP");
// Accurate time is necessary for certificate validation and writing in batches
// For the fastest time sync find NTP servers in your area: https://www.pool.ntp.org/zone/
// Syncing progress and the time will be printed to Serial.
timeSync(TZ_INFO, "pool.ntp.org", "time.nis.gov");
// Check server connection
if (client.validateConnection()) {
Serial.print("Connected to InfluxDB: ");
Serial.println(client.getServerUrl());
Serial.print("InfluxDB connection failed: ");
Serial.println(client.getLastErrorMessage());
Serial.println(Serial2.parseFloat());
// Get latest sensor readings
temperature = Serial2.parseFloat();
// Add readings as fields to point
sensorReadings.addField("TemperatureTwo", temperature);
// Print what are we exactly writing
Serial.print("Writing: ");
Serial.println(client.pointToLineProtocol(sensorReadings));
// Write point into buffer
client.writePoint(sensorReadings);
// Clear fields for next usage. Tags remain the same.
sensorReadings.clearFields();
// If no Wifi signal, try to reconnect it
if (wifiMulti.run() != WL_CONNECTED) {
Serial.println("Wifi connection lost");
// Wait 10s
Serial.println("Wait 10s");
Or, simply assign them based on the location in a line - the first variable is always temperature, the second always humidity, the third pressure. Etc.
You can get ideas from Robin's Serial Input Basics - updated. The principles apply to communication between two microcontrollers as well; you will have to write the sender side yourself matching the receiver.
I found that post earlier and thought it might be of use to me. Am I correct in saying that example 5 would be the best suited example to try and implement?
As I said,
Send each value with a precursor letter. E.g. H 250, T 12, P 101.35
Without your ESP code, how can I comment?
Basically, you receive H, you suck in a number and put it in the humidity variable. ditto for T, and whatever else. If you have multiple sensors of the same type, e.g. temperature 1 and 2, just give them different signature characters.
yes it's not exactly what you asked for but can certainly be easily modified to do what you ask and more. "123T" could set the temperature, "456H" the humidity.
case 'T':
temperature = val;
val = 0;
developing a flexible approach is often reusable and can easily be expanded for other purposes
I've updated the post including the ESP code. Also, I referenced a post about another problem yesterday. Essentially the issue was that the sensor values were displayed in ascii code on the ESP serial monitor and the solution was to use Serial2.parseFloat() instead of Serial2.read(). However, this .parsefloat doesnt send the precursor letters you said to use, so I'm not sure what to do now.
are you looking to process a string from the serial port or from a WiFi socket? or is mega sending a string to and esp which is then transmitting it over wifi to some other wifi device that needs to process the string?
once the string from Serial2 is read (parsed) i don't believe it can be read again.
also, code should check if something is available before reading the Serial2 interface
Im trying to get the mega to send data points as floats to the esp and then these data points are then sent to influxdb (an open-source time series database). Also, I never use those two lines of code at the same time. I comment one out when I'm testing different things. Ok, I'll add the check code now then
