Gentlemen,
I tried out the SparkFun ICM20948 library and did angle testing with my code and it worked out really nicely. However, something I noticed with the yaw is that it starts from 0 and starts climbing to a random number, which is not exactly what I want. Is there some sort of tare functionality or an angle-presetting functionality I can use to solve this issue. Here is the code and here is the problem modelled on a video:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "ICM_20948.h"
#include "SimpleKalmanFilter.h" // Include Kalman filter library
#define SERIAL_PORT Serial
#define WIRE_PORT Wire
#define AD0_VAL 0
ICM_20948_I2C myICM;
// Initialize Kalman filters for roll, pitch, and yaw
SimpleKalmanFilter kalmanRoll(2, 2, 0.01);
SimpleKalmanFilter kalmanPitch(2, 2, 0.01);
SimpleKalmanFilter kalmanYaw(2, 2, 0.01);
// Motor A connections
#define enA 13
#define in1 11
#define in2 12
// Motor B connections
#define enB 8
#define in3 10
#define in4 9
const byte MOTOR_A = 3;
const byte MOTOR_B = 2;
float stepcount = 275.00;
float circumference = 20.00;
volatile int counter_A = 0;
volatile int counter_B = 0;
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire1, OLED_RESET);
attachInterrupt(digitalPinToInterrupt (MOTOR_A), ISR_countA, RISING); // Attach interupts for encoders
attachInterrupt(digitalPinToInterrupt (MOTOR_B), ISR_countB, RISING);
SERIAL_PORT.begin(115200);
WIRE_PORT.begin();
WIRE_PORT.setClock(400000);
Wire1.begin();
Wire1.setClock(400000);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;);
// Set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
// Turn off motors - Initial state
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
delay(2000);
bool initialized = false;
while (!initialized) {
myICM.begin(WIRE_PORT, AD0_VAL);
if (myICM.status == ICM_20948_Stat_Ok) initialized = true;
else delay(500);
myICM.initializeDMP();
myICM.enableDMPSensor(INV_ICM20948_SENSOR_GAME_ROTATION_VECTOR);
myICM.setDMPODRrate(DMP_ODR_Reg_Quat6, 0);
myICM.enableFIFO();
myICM.enableDMP();
myICM.resetDMP();
myICM.resetFIFO();
while (digitalRead(40) == LOW) {
measureAngle();
directionControl(444, 150);
//ok
// This function lets you control spinning direction of motors
void directionControl(int steps, int speed) {
counter_A = 0;
counter_B = 0;
while ((2*steps) > counter_B + counter_A) {
// Set motors to maximum speed
// For PWM maximum possible values are 0 to 255
analogWrite(enA, speed*0.95); // Set PWM to 105
analogWrite(enB, speed);
// Turn on motor A & B
digitalWrite(in1, HIGH); // Move Motors Forward
digitalWrite(in3, HIGH);
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(SSD1306_WHITE);
display.setCursor(0, 0);
display.print(" Counter A: ");
display.println(counter_A);
display.print(" Counter B: ");
display.println(counter_B);
display.display();
delay(10);
digitalWrite(in1, LOW); // Stop motors
display.print(" SpeedA: ");
display.println(speed);
display.print(" SpeedB: ");
display.println(speed*0.95);
display.display();
void measureAngle() {
icm_20948_DMP_data_t data;
myICM.readDMPdataFromFIFO(&data);
if ((myICM.status == ICM_20948_Stat_Ok) || (myICM.status == ICM_20948_Stat_FIFOMoreDataAvail)) {
double q1 = ((double)data.Quat6.Data.Q1) / 1073741824.0;
double q2 = ((double)data.Quat6.Data.Q2) / 1073741824.0;
double q3 = ((double)data.Quat6.Data.Q3) / 1073741824.0;
double q0 = sqrt(1.0 - ((q1 * q1) + (q2 * q2) + (q3 * q3)));
double qw = q0, qx = q2, qy = q1, qz = -q3;
double t0 = +2.0 * (qw * qx + qy * qz);
double t1 = +1.0 - 2.0 * (qx * qx + qy * qy);
double roll = atan2(t0, t1) * 180.0 / PI;
double t2 = +2.0 * (qw * qy - qx * qz);
t2 = constrain(t2, -1.0, 1.0);
double pitch = asin(t2) * 180.0 / PI;
double t3 = +2.0 * (qw * qz + qx * qy);
double t4 = +1.0 - 2.0 * (qy * qy + qz * qz);
double yaw = atan2(t3, t4) * 180.0 / PI;
// Apply Kalman filtering
roll = kalmanRoll.updateEstimate(roll);
pitch = kalmanPitch.updateEstimate(pitch);
yaw = kalmanYaw.updateEstimate(yaw);
SERIAL_PORT.print(F("Filtered Roll:"));
SERIAL_PORT.print(roll, 1);
SERIAL_PORT.print(F(" Pitch:"));
SERIAL_PORT.print(pitch, 1);
SERIAL_PORT.print(F(" Yaw:"));
SERIAL_PORT.println(yaw, 1);
void ISR_countA() {
counter_A++; // increment Motor A counter value
// Motor B pulse count ISR
void ISR_countB() {
counter_B++; // increment Motor B counter value
