Sketch uses 5130 bytes (17%) of program storage space. Maximum is 28672 bytes.
Global variables use 430 bytes (16%) of dynamic memory, leaving 2130 bytes for local variables. Maximum is 2560 bytes.
Performing 1200-bps touch reset on serial port COM6
Waiting for upload port...
No upload port found, using address:"COM6" label:"COM6" protocol:"serial" protocol_label:"Serial Port" as fallback
avrdude: Version 6.3"C:\Users\Djisa\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\Djisa\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega32u4 -cavr109 -PCOM6 -b57600 -D "-Uflash:w:C:\Users\Djisa\AppData\Local\Temp\arduino-sketch-0D53A90AF331C2CD8C5236A3985E2EE4/Blink.ino.hex:i"
-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Djisa\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
Using Programmer : avr109
Overriding Baud Rate : 57600
avrdude: ser_open(): can't open device "\\.\COM6": The system cannot find the file specified.
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
I've followed the sparkfun pro micro instructions, but I keep getting this error.
Inside the device manager, it reads it as a communication port.
