Uploading programs to Sparkfun Pro Micro
Hello! I am unable to upload a program (the "blink" example) to my new Sparkfun Pro Micro (5v/16MHz). I'm on Windows 7 x64 + Arduino IDE 1.0.1 and have installed all required drivers and addons successfully (http://www.sparkfun.com/tutorials/338). The COM port is set correctly and there are no compilation errors. But the problem comes when the Arduino IDE runs avrdude. Here is the output:
C:\Program Files (x86)\Arduino\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P\\.\COM38 -b57600 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\build6614488199660434471.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM38
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: V [56]
Somehow it gets stuck at the last command, "avrdude: Send: V [56]". Any suggestions? Thanks in advance!
Working now! Was a problem with the bootloader version. The pro micro addon I had installed was too new for the board.
I am having the same problem with the SparkFun 5V/16MHz Pro Micro (DEV-11098). Could you let me know which addon you used to get it to work in the end? The version I tried from the Getting Started tutorial page: http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Dev/Arduino/Boards/ProMicro-Addon-190612.zip resulted in the following:
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf" User configuration file is "/Users/calvin/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodemfa131 Using Programmer : avr109 Overriding Baud Rate : 57600 AVR Part : ATmega32U4 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PA0 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail :
Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
Programmer Type : butterfly Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b] avrdude: Send: S [53] avrdude: ser_recv(): programmer is not responding avrdude: butterfly_recv(): programmer is not responding
Hey guys! Did you manage to solve the problem? I've got exactly the same issue. Please help! :)
I figured out this problem.
The new addon "ProMicro-Addon-190612.zip" does not allow to upload any sketch!
But the old one addon dated 01/24/2012 is working well!
Guys, who are at the same problem like me, you may download workable addon here: http://dl.dropbox.com/u/3419665/Arduino-proMicro-Addon.zip
I have a problem with the same board (Arduino ProMicro 5v) and the error looks like this:
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences. Arduino: 1.0.6 (Windows NT (unknown)), Board: "SparkFun Pro Micro 5V/16MHz" Dimensiunea schiţei: 4.730 bytes (din maxim 28.672 bytes)
Found programmer: Id = "Bľá"; type =
I don't know how to make it work!Please help me :(
