As said above by @sterretje, you're probably reading an AC signal.
Since it's a doorbell, it's also quite possible you're feeding a signal into the Arduino that exceeds its design limits. Can you show a circuit diagram/schematic of your setup, and a good photograph that shows how everything is connected?
Keep in mind that identifying a specific tune played by the doorbell in the way you have set this up will likely not be feasible. It will be feasible to detect if a tune is playing, or not. But not identifying a specific tune. Unless the tunes vary in duration, because then you might be able to determine how long each tune is and then use that information to work a relay etc.
What do you expect to get from the input when you play a tune for the speaker to pick up.
