Spectrophotometer sensor
Hello, everyone.
I am constructing a prototype model of a Spectrophotometer to measure the intensity of light absorbed by a specific solution. I want to ask about the type of the sensor I should use is it color sensor RGB or spectral sensor. And what about OPT4048 and OPT4060. Note that I need actual and nearly accurate numbers of light intensity. Also, in which old or discarded devices can I find these sensors to be able to use in my device ? Last one is can I use microcontroller from another old devices?
LM7805 where can I find this type of microcontroller in old devices?
Definitely a spectral sensor. An RGB sensor like OPT4048 and OPT4060 is useless to you.
LM7805 is not a microcontroller, it is a voltage regulator. It is very common. But also an old design. There are better replacements available.
Please specify the light wavelength range and number of bands in the analysis.
Consider the AS726x series of spectral sensors.
Still only a few channels. Will this be enough to perform spectroscopy?
I don't know if this would be a dumb idea, but what about an optical grating or prism moved by a servo motor? A fixed, wide-band sensor could be placed behind it.
That depends on the OP's requirements, which have not been specified. Let's await those details.
Vague indeed!
"Actual" light intensity as opposed to what? Relative light intensity? Can't you just calibrate your sensor against your light source with a sample of distilled water or something?
Spectrometers, I guess.
Almost certainly not.
Please give details of the "old and discarded" devices that you have found.
