Something that hasn't really been mentioned is that a int16 * int16 can result in an int32, but unless you instruct avr-gcc to not throw away the upper 16bits that's exactly what it's going to do.
In this sketch I compared the speeds of 5 ways to do int32 = int16 * int16. I used timer 1 to get the best resolution on the measurement and I turned off interrupts so that they wouldn't affect it either.
#include "Arduino.h"
#include <stdint.h>
#define TEST_PIN 2
#define TEST_PIN_MASK (1 << TEST_PIN) // Port D Pin 3
#define NS_PER_SEC 1000000000
#define TIME_RES 10
#define TIME_SCALE (uint32_t)(1ULL*NS_PER_SEC*TIME_RES/F_CPU)
// Macro From -> https://github.com/rekka/avrmultiplication/blob/master/mult16x16.h
// longRes = intIn1 * intIn2
// signed16 * signed16
#define MultiS16X16to32(longRes, intIn1, intIn2) \
asm volatile ( \
"clr r26 \n\t" \
"mul %A1, %A2 \n\t" \
"movw %A0, r0 \n\t" \
"muls %B1, %B2 \n\t" \
"movw %C0, r0 \n\t" \
"mulsu %B2, %A1 \n\t" \
"sbc %D0, r26 \n\t" \
"add %B0, r0 \n\t" \
"adc %C0, r1 \n\t" \
"adc %D0, r26 \n\t" \
"mulsu %B1, %A2 \n\t" \
"clr r1 \n\t" \
"=&r" (longRes) \
"a" (intIn1), \
"a" (intIn2) \
"r26" \
#define PRINT_MUL(p,a,b) \
Serial.print(p); \
Serial.print(F(" = ")); \
Serial.print(a); \
Serial.print(F(" * ")); \
Serial.println(b); \
enum
INT16_MUL,
INT16_MACRO_MUL,
INT16_CAST_MUL,
INT32_MUL,
FLOAT_MUL,
NUM_MUL
char int16_mul_string[] = "INT16_MUL";
char int16_macro_mul_string[] = "INT16_MACRO_MUL";
char int16_cast_mul_string[] = "INT16_CAST_MUL";
char int32_mul_string[] = "INT32_MUL";
char float_mul_string[] = "FLOAT_MUL";
const char *test_strings[NUM_MUL] =
int16_mul_string,
int16_macro_mul_string,
int16_cast_mul_string,
int32_mul_string,
float_mul_string
volatile int16_t int16a, int16b;
volatile int32_t int16p, int16_cast_p, int16_macro_p;
volatile int32_t int32a, int32b, int32p;
volatile float floata, floatb, floatp;
// Turn on Timer1 with no prescaling.
TCCR1A = 0;
TCCR1B = 1;
TCCR1C = 0;
// Set up pin to see if I'm calculating time correctly.
digitalWrite(TEST_PIN, LOW);
pinMode(TEST_PIN, OUTPUT);
// Display timing information.
Serial.print(F("F_CPU = "));
Serial.print(F_CPU);
Serial.println(F("Hz."));
Serial.print(F("Timer1 scale = "));
Serial.print(TIME_SCALE/TIME_RES);
Serial.print(F("."));
Serial.print(TIME_SCALE%TIME_RES);
Serial.println(F("ns/tick."));
static uint32_t slow_down_serial_timer;
const uint32_t slow_down_serial_time = 1000000;
uint16_t timestamps[NUM_MUL+1];
uint8_t idx;
if(micros() - slow_down_serial_timer > slow_down_serial_time)
slow_down_serial_timer += slow_down_serial_time;
// Generate Random Inputs
generate_section:
int16a = random(INT16_MIN, INT16_MAX);
int16b = random(INT16_MIN, INT16_MAX);
int32a = (int32_t)int16a;
int32b = (int32_t)int16b;
floata = (float)int32a;
floatb = (float)int32b;
// Measure the time for each operation
math_section:
cli();
PORTD |= TEST_PIN_MASK;
timestamps[0] = TCNT1;
int16p = int16a * int16b;
timestamps[1] = TCNT1;
MultiS16X16to32(int16_macro_p, int16a, int16b);
timestamps[2] = TCNT1;
int16_cast_p = (int32_t)int16a * (int32_t)int16b;
timestamps[3] = TCNT1;
int32p = int32a * int32b;
timestamps[4] = TCNT1;
floatp = floata * floatb;
timestamps[5] = TCNT1;
PORTD &= ~TEST_PIN_MASK;
sei();
// Print the measured times
print_section:
Serial.println(F("==================================================="));
for(idx = 0; idx < NUM_MUL; idx++)
uint32_t temp_time = TIME_SCALE*(timestamps[idx+1]-timestamps[idx]);
Serial.print(test_strings[idx]);
Serial.print(F(" : "));
Serial.print(temp_time/TIME_RES);
Serial.print(temp_time%TIME_RES);
Serial.print(F("ns. ("));
Serial.print((timestamps[idx+1]-timestamps[idx]));
Serial.println(F("ticks)."));
switch(idx)
case INT16_MUL:
PRINT_MUL(int16p, int16a, int16b);
case INT16_MACRO_MUL:
PRINT_MUL(int16_macro_p, int16a, int16b);
case INT16_CAST_MUL:
PRINT_MUL(int16_cast_p, int16a, int16b);
case INT32_MUL:
PRINT_MUL(int32p, int32a, int32b);
case FLOAT_MUL:
PRINT_MUL(floatp, floata, floatb);
These are a sample of the results:
F_CPU = 16000000Hz.
Timer1 scale = 62.5ns/tick.
INT16_MUL : 2375.0ns. (38ticks).
-2607 = -15961 * -13369
INT16_MACRO_MUL : 2750.0ns. (44ticks).
213382609 = -15961 * -13369
INT16_CAST_MUL : 4312.5ns. (69ticks).
INT32_MUL : 6562.5ns. (105ticks).
FLOAT_MUL : 9562.5ns. (153ticks).
213382608.00 = -15961.00 * -13369.00
- Method one (INT16_MUL) is the fastest, which doesn't mean much because the product is just wrong.
- Method two (INT16_MACRO_MUL) is nearly as fast, but it uses an assembly macro to prevent the compiler from throwing away the upper 16bits of the product.
- Method three (INT16_CAST_MUL) is almost twice as slow, as it casts the int16s into int32s before the multiplication. After this the compiler actually does an int32 * int32 multiplication. Smarter compilers exist, btw, that will recognize this casting method as a place where it can do an int16 * int16 = int32 (making the macro in method two unecessary)
- Method four (INT32_MUL) shows that at least AVR is doing some sort of optimization when casting the int16s to int32s, as the int32 * int32 = int32 still takes longer than method 3.
- Method five (FLOAT_MUL) uses floating point and not only is it super slow, but it also adds error to the product.
I noticed that I was getting different numbers from the other people in the thread so I verified my measurements. If you add up all of these measurements they are ~25.5us. The pulse I measured on TEST_PIN shows that the measurements are correct.
I also inspected the assembly code, to make sure that the number of cycles measured was equal to the number of cycles counted by hand. The first calculation of 38 cycles seems to match the assembly code:
math_section:
cli();
380: f8 94 cli
382: 5a 9a sbi 0x0b, 2 ; 11
timestamps[0] = TCNT1; ; cycles (total cycles)
384: 80 91 84 00 lds r24, 0x0084 ; 2 (2)
388: 90 91 85 00 lds r25, 0x0085 ; 2 (4)
38c: 9a 83 std Y+2, r25 ; 2 (6)
38e: 89 83 std Y+1, r24 ; 2 (8)
390: 40 91 96 01 lds r20, 0x0196 ; 2 (10)
394: 50 91 97 01 lds r21, 0x0197 ; 2 (12)
398: 20 91 94 01 lds r18, 0x0194 ; 2 (14)
39c: 30 91 95 01 lds r19, 0x0195 ; 2 (16)
3a0: 42 9f mul r20, r18 ; 2 (18)
3a2: c0 01 movw r24, r0 ; 1 (19)
3a4: 43 9f mul r20, r19 ; 2 (21)
3a6: 90 0d add r25, r0 ; 1 (22)
3a8: 52 9f mul r21, r18 ; 2 (24)
3aa: 90 0d add r25, r0 ; 1 (25)
3ac: 11 24 eor r1, r1 ; 1 (26)
3ae: aa 27 eor r26, r26 ; 1 (27)
3b0: 97 fd sbrc r25, 7 ; 1/2/3 (28/29/30)
3b2: a0 95 com r26 ; 1 (29/30/31)
3b4: ba 2f mov r27, r26 ; 1 (30/31/32)
3b6: 80 93 90 01 sts 0x0190, r24 ; 2 (32/33/34)
3ba: 90 93 91 01 sts 0x0191, r25 ; 2 (34/35/36)
3be: a0 93 92 01 sts 0x0192, r26 ; 2 (36/37/38)
3c2: b0 93 93 01 sts 0x0193, r27 ; 2 (38/39/40)
I can provide the rest of the assembly code is anyone is interested. I mostly generated it to be sure the optimizer wasn't doing anything to affect the measurements.
At this point I'm pretty sure my calculations are correct. I'm not sure why the discrepancy with the previous posters, however.
Edited to Add: I didn't realize this was a resurrected thread with 9618 views!
