Hello,
I am using an Arduino to drive a Subaru speedometer. I tried using the pulseIn() function to measure the time between bolts on a driveshaft, and the needle was bouncing around too much at higher speeds... so I rewrote the getSpeed() function to count the number of signals over a twentieth of a second (arbitrary decision there)... but now as soon as the setup function is done, the needle shoots past all the numbers. So I figure either I screwed something up in the programming or the wiring.
Code below; any input is appreciated.
Thanks!
Ted
const float ratio = 4.5; //ratio of input signals to output signals
const int VSS = 2; //pin receiving wheel speed signal
const int SpeedoPin = 8; //Output pin to speedo
unsigned long prevOutTime = 0; //last micros time signal was sent to speedometer
unsigned long prevInTime = 0; //last micros time checkSpeed function was run
unsigned long outputDelay = 0; //time between signals to speedometer, effectively the speed
unsigned long prevSerMonTime = 0; //last MILLIS() numbers were sent to serial
byte SpeedoPinState = LOW;void setup() {
pinMode(VSS, INPUT);
pinMode(SpeedoPin, OUTPUT);
tone(SpeedoPin, 65, 2000); //speedo displays about 57mph for 2 seconds
delay(2000);
tone(SpeedoPin, 131, 2000); //speedo displays about 113 mph for 2 seconds
delay(2000);
}void speedoOut() {
SpeedoPinState = !SpeedoPinState;
digitalWrite(SpeedoPin, SpeedoPinState);
prevOutTime = micros();
}void getSpeed() {
long start = micros();
int signals = 0;
byte VSSstate = digitalRead(VSS);
while (micros() - start <= 50000) {
if (VSSstate != digitalRead(VSS)) {
signals++;
VSSstate = !VSSstate;
if (signals > 0) {
outputDelay = ((micros() - start) / signals) * ratio;
prevInTime = micros();
}void speedToSerMon() {
Serial.println("OutputDelay:");
Serial.println(outputDelay);
prevSerMonTime = millis();
}void loop() {
if (micros() - prevInTime >= 250000){
getSpeed();
if (micros() - prevOutTime >= outputDelay > 0){
speedoOut();
Serial.print(".");
if (millis() - prevSerMonTime >= 3e3){
speedToSerMon();
