I have a SparkFun 8x8 RGB LED matrix with a backpack that is controlled via SPI. The following program works just fine on the Duemilanove but not when run on an Arduino Mega. Other programs run fine on the Mega including those using serial communication. Could anyone out there who has a Mega and one of these LED displays try this sketch to see if it works on their hardware?
// Blinking LEDs
// Simple program to test the SparkFun 8x8 RGB LED matrix and its SPI backpack
// Revised 2009.12.24
// Credits:
// Heather Dewey-Hagborg
// Arduino Forum user Little-Scale
// Daniel Hirschmann
// Arduino Forum user chessplayer
// SPI register bit positions
#define RX_IN 0
#define TX_OUT 1
#define CS 2
#define MOSI 3
#define MISO 4
#define SCK 5
// Arduino Duemilanove pin numbers for SPI
#define CHIPSELECT 10 // CS
#define DATAOUT 11 // MOSI
#define DATAIN 12 // MISO (not used)
#define SPICLOCK 13 // SCK
// SparkFun 8x8 RGB LED backpack officially supported LED colors
typedef unsigned char ledcolorType;
#define ledcolorBlack 0x00
#define ledcolorRed 0xe0
#define ledcolorGreen 0x1c
#define ledcolorBlue 0x03
#define ledcolorOrange 0xfc
#define ledcolorMagneta 0xe3
#define ledcolorTeal 0x1f
#define ledcolorWhite 0xff
#define ledcolorLen 8
static const ledcolorType ledcolors[ledcolorLen] =
ledcolorBlack, ledcolorRed, ledcolorGreen, ledcolorBlue,
ledcolorOrange, ledcolorMagneta, ledcolorTeal, ledcolorWhite
// SparkFun 8x8 RGB LED backpack frame geometry
#define rowLen 8
#define colLen 8
typedef struct
ledcolorType pixels[rowLen][colLen];
} frameType;
static void SetFrameToColor(frameType& frame, const ledcolorType ledcolor)
for (unsigned int col = 0; col < colLen; col++)
for (unsigned int row = 0; row < rowLen; row++)
frame.pixels[row][col] = ledcolor;
static void SetFrameToBlack(frameType& frame) {SetFrameToColor(frame, ledcolorBlack);}
static unsigned char PickRandomColor(void) {return ledcolors[random(ledcolorLen)];}
static void ChangeOneRandomPixelToColor(frameType& frame, const ledcolorType ledcolor)
frame.pixels[random(rowLen)][random(colLen)] = ledcolor;
static void SetBackpackSelectStatus(const unsigned int status)
digitalWrite(CHIPSELECT, status); delayMicroseconds(500);
static void BackpackEnable(void) {SetBackpackSelectStatus(LOW);}
static void BackpackDisable(void) {SetBackpackSelectStatus(HIGH);}
static unsigned char WriteSPIByte(unsigned char data)
SPDR = data; while (!(SPSR & (1 << SPIF))); return SPDR;
static void SetBackpackDaisyChainLength(const unsigned int length)
BackpackEnable();
WriteSPIByte('%'); WriteSPIByte(length);
BackpackDisable();
static void WriteFrame(const frameType& frame)
BackpackEnable();
WriteSPIByte(frame.pixels[row][col]);
BackpackDisable();
// The last real frame displayed
static frameType realframe;
// One time setup
// Initialize the Arduino SPI pin directions
pinMode(CHIPSELECT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(DATAOUT, OUTPUT);
pinMode(SPICLOCK, OUTPUT);
// Magical initialization of the Arduino SPI registers
volatile byte clr;
DDRB = (1 << CS) | (1 << MOSI) | (1 << SCK);
DDRD = (1 << TX_OUT);
SPCR = (1 << SPE) | (1 << MSTR) | (1 << SPR1);
SPSR = SPSR & 0xfe;
clr = SPSR; clr = SPDR;
// Set the backpack to its default state
BackpackDisable();
SetBackpackDaisyChainLength(1); // Be careful with this one
// Initial display is all black pixels
SetFrameToBlack(realframe); WriteFrame(realframe);
// Main loop
delay(100);
ChangeOneRandomPixelToColor(realframe, PickRandomColor());
