The SPI does not work on my self-layouted ESP32S3 Wroom-1U-N8R8 module.
My Arduino-Code works since I tested it successfully on a Seeed Xiao-ESP32S3.
But on the Wroom-module, I can't get the application to work. For now, I think it is purely software that causes the misfunction.
Here is my layouted ESP32S3 Wroom-1U-N8R8 module :
For my functionality (i.e. external peripherie) to work, I need the SPI pins CS / MOSI / SCK - and in addition my application also needs the BUSY / RES / DC pins as can be seen in the above layout.
Obviously, in comparison to the Xiao-ESP32S3, the Wroom-module has different pins for the SPI.
My Arduino pin-definition therefore looks like this:
#define CS_SS_PIN SS // 10 (CS SS)
#define HSPI_COPI MOSI // 11 (MOSI)
#define HSPI_SCLK SCK // 12 (SCK)
#define BUSY_PIN A4 // 5 (BUSY)
#define RST_PIN A5 // 6 (RST RES)
#define DC_PIN A6 // 7 (DC)
Inside Arduino IDE, I choose the board ESP32S3 Dev Module :
From the pins_arduino.h file of this ESP32S3 Dev Module I find:
static const uint8_t SS = 10; // --> I refer in code
static const uint8_t MOSI = 11; // --> I refer in code
static const uint8_t MISO = 13;
static const uint8_t SCK = 12; // --> I refer in code
static const uint8_t A0 = 1;
static const uint8_t A1 = 2;
static const uint8_t A2 = 3;
static const uint8_t A3 = 4;
static const uint8_t A4 = 5; // --> I refer in code
static const uint8_t A5 = 6; // --> I refer in code
static const uint8_t A6 = 7; // --> I refer in code
static const uint8_t A7 = 8;
static const uint8_t A8 = 9;
static const uint8_t A9 = 10;
static const uint8_t A10 = 11;
static const uint8_t A11 = 12;
static const uint8_t A12 = 13;
static const uint8_t A13 = 14;
static const uint8_t A14 = 15;
static const uint8_t A15 = 16;
static const uint8_t A16 = 17;
static const uint8_t A17 = 18;
static const uint8_t A18 = 19;
static const uint8_t A19 = 20;
The ESP32S3 Wroom-1U-N8R8 module I use, has 8MB of Flash as well as 8MB of PSRAM.
Here is the datasheet of the ESP32S3 Wroom-1U-N8R8 module: https://www.espressif.com/sites/default/files/documentation/esp32-s3-wroom-1_wroom-1u_datasheet_en.pdf
When I run my Arduino code, I have the following settings:
As you can see, the most important settings I set as such:
- USB CDC on Boot: "Enabled"
- Flash Mode: "QIO 80 MHz"
- Flash Size: "8MB (64Mb"
- PSRAM: "OPI PSRAM"
Inside my Arduino code's setup() function, I do the following:
pinMode(DC_PIN, OUTPUT);
pinMode(RST_PIN, OUTPUT);
pinMode(BUSY_PIN, INPUT);
SPI.beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE0));
SPI.begin ();
Why is my SPI not working ????? Any idea ??
