Hi everyone
im trying to work out how to split a mqtt topic to pull out a number value
currently i have this
int getRelayFromTopic(const String &topic)
int s = -1, e = -1;
for(s = topic.length()-1; s>0; --s)
if (isDigit(topic[s]))
if (e == -1) e = s;
else if ( e != -1 ) break;
return topic.substring( s+1, e+1 ).toInt();
this "works" but the problem im having is that its not stored as a byte which it needs to be so i can use it with driving the I2C relay channels
this is my mqttCallback function
void mqttCallback(char* topic, byte* payload, unsigned int length)
Serial.println(getRelayFromTopic(topic));
if ((char)payload[0] == '1')
client.publish(mqttStatusTopic, "1");
setLatchChannelOn(getRelayFromTopic(topic));
else if ((char)payload[0] == '0')
client.publish(mqttStatusTopic, "0");
setLatchChannelOff(getRelayFromTopic(topic));
if i send the value of "1" to
house/switchboard/01/relay/32/command
the console displays
10:50:12.424 -> 32
and the status topic receives a 1.
im hoping its just something ive over looked
code in comments as i was over the 9000 limit
EDIT heres the first have
#include <Wire.h>
#include <Ethernet.h>
#include <PubSubClient.h>
/*--------------------------- Configuration ------------------------------*/
/* Core Settings */
#define SERIAL_SPEED 57600 // Serial port speed
/* Network Settings */
#define ENABLE_DHCP true // true/false
#define ENABLE_MAC_ADDRESS_ROM true // true/false
#define MAC_I2C_ADDR 0x50 // Microchip 24AA125E48 I2C ROM address
static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // Set if no MAC ROM
IPAddress ip(192,168,1,35); // Default if DHCP is not used
/* MQTT Settings */
IPAddress broker(192,168,1,108); // MQTT broker
#define MQTT_USER "username" // Username presented to the MQTT broker
#define MQTT_PASSWD "password" // Password presented to the MQTT broker
#define MQTT_TOPIC_BUFFER 40
char clientBuffer[40]; // Maximum clientID length
char messageBuffer[100]; // TODO: unused ATM
char topicBuffer[35]; // Maximum topic length
const char* mqttClientID = "Switchboard_12_Relays"; // Client ID presented to the MQTT broker
const char* mqttEventTopic = "events"; // MQTT logging topic
const char* mqttTopicPrefix = "house/switchboard/01/relay"; // MQTT topic prefix Change the Switchboard ID Eg 12. if you have more then 1 panel.
const char* mqttCmdTopic = "command"; // MQTT command topic suffix
const char* mqttStatusTopic = "status"; // MQTT status topic suffix
/* Watchdog Timer Settings */
#define ENABLE_EXTERNAL_WATCHDOG false // true / false
#define WATCHDOG_PIN 8 // Output to pat the watchdog
#define WATCHDOG_PULSE_LENGTH 50 // Milliseconds
#define WATCHDOG_RESET_INTERVAL 30000 // Milliseconds. Also the period for sensor reports.
long watchdogLastResetTime = 0;
/* Relay 8 Modules */
#define SHIELD_1_I2C_ADDRESS 0x20 // 0x20 is the address with all jumpers removed
#define SHIELD_2_I2C_ADDRESS 0x21 // 0x21 is the address with a jumper on position A0
#define SHIELD_3_I2C_ADDRESS 0x22 // 0x22 is the address with a jumper on position A1
#define SHIELD_4_I2C_ADDRESS 0x23 // 0x23 is the address with a jumper on position A0, A1
byte shield1BankA = 0; // Current status of all outputs on first shield, one bit per output
byte shield2BankA = 0; // Current status of all outputs on second shield, one bit per output
byte shield3BankA = 0; // Current status of all outputs on first shield, one bit per output
byte shield4BankA = 0; // Current status of all outputs on second shield, one bit per output
// Instantiate MQTT client
EthernetClient ethclient;
PubSubClient client(ethclient);
* Initial setup - called once
* @return void
Serial.begin( SERIAL_SPEED );
Serial.println("Home Automation Relay Controller");
Serial.println("--------------------------------");
Serial.println("Starting up.");
Wire.begin();
if( ENABLE_MAC_ADDRESS_ROM == true )
Serial.print(F("Getting MAC address from ROM: "));
mac[0] = readRegister(0xFA);
mac[1] = readRegister(0xFB);
mac[2] = readRegister(0xFC);
mac[3] = readRegister(0xFD);
mac[4] = readRegister(0xFE);
mac[5] = readRegister(0xFF);
Serial.print(F("Using static MAC address: "));
// Print the MAC address
char macAddr[17];
sprintf(macAddr, "%02X:%02X:%02X:%02X:%02X:%02X", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
Serial.println(macAddr);
// Set up the Ethernet library to talk to the Wiznet board
if( ENABLE_DHCP == true )
// Use DHCP
Ethernet.begin(mac);
// Use static address defined above
Ethernet.begin(mac, ip);
// Print IP address:
Serial.print(F("My IP: "));
for (byte thisByte = 0; thisByte < 4; thisByte++)
// print the value of each byte of the IP address:
Serial.print(Ethernet.localIP()[thisByte], DEC);
if( thisByte < 3 )
Serial.print(".");
// Initialise Relay8 modules
// TODO: support multiple shields
initialiseShield(SHIELD_1_I2C_ADDRESS);
sendRawValueToLatch(SHIELD_1_I2C_ADDRESS, 0); // If we don't do this, channel 6 turns on! I don't know why
initialiseShield(SHIELD_2_I2C_ADDRESS);
sendRawValueToLatch(SHIELD_2_I2C_ADDRESS, 0); // If we don't do this, channel 6 turns on! I don't know why
initialiseShield(SHIELD_3_I2C_ADDRESS);
sendRawValueToLatch(SHIELD_3_I2C_ADDRESS, 0); // If we don't do this, channel 6 turns on! I don't know why
initialiseShield(SHIELD_4_I2C_ADDRESS);
sendRawValueToLatch(SHIELD_4_I2C_ADDRESS, 0); // If we don't do this, channel 6 turns on! I don't know why
// Set MQTT broker settings
Serial.println("MQTT broker settings...");
client.setServer(broker, 1883);
client.setCallback(mqttCallback);
/* Set up the watchdog timer */
if(ENABLE_EXTERNAL_WATCHDOG == true)
pinMode(WATCHDOG_PIN, OUTPUT);
digitalWrite(WATCHDOG_PIN, LOW);
Serial.println("Ready.");
* Determines if Watchdog should be "pat"
* @return void
void runHeartbeat()
// Is it time to run yet?
if((millis() - watchdogLastResetTime) > WATCHDOG_RESET_INTERVAL)
// Only pat the watchdog if we successfully published to MQTT
patWatchdog();
* "Pat" watchdog module to prevent board being reset
* @return void
void patWatchdog()
if( ENABLE_EXTERNAL_WATCHDOG )
digitalWrite(WATCHDOG_PIN, HIGH);
delay(WATCHDOG_PULSE_LENGTH);
watchdogLastResetTime = millis();
* Main loop program
* @return void
// Stay connected to MQTT
if (!client.connected())
reconnect();
runHeartbeat();
client.loop();
* Reconnect to MQTT server
* @return void
any help is appreciated cheers
