Spo with Max30102 using Esp32
Hi, I'm using the sensor Max30102 with a Esp32, but I'm having trouble trying to get spo readings. I'm using the example code of the library sparkfun MAX30100x, with the conections of:
-5V = 5V (3.3V is allowed)
-GND = GND
-SDA = D21 (or SDA)
-SCL = D22 (or SCL)
-INT = Not connected
I'm expecting to have the spo values, but the MAX sensor is not even turning on the red led and I'm getting instead this information in the serial monitor:
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13964
load:0x40080400,len:3600
entry 0x400805f0
I tried using the same code with an Arduino Mega, switching the SDA pin to the 20, the SCL to the 21 (as those are the pins that corresponde to arduinoMega) and using 3.3V. The code and the sensor worked fine for the Arduino Mega.
CODE I'm using:
  Optical SP02 Detection (SPK Algorithm) using the MAX30105 Breakout
  By: Nathan Seidle @ SparkFun Electronics
  Date: October 19th, 2016
  https://github.com/sparkfun/MAX30105_Breakout
  This demo shows heart rate and SPO2 levels.
  It is best to attach the sensor to your finger using a rubber band or other tightening
  device. Humans are generally bad at applying constant pressure to a thing. When you
  press your finger against the sensor it varies enough to cause the blood in your
  finger to flow differently which causes the sensor readings to go wonky.
  This example is based on MAXREFDES117 and RD117_LILYPAD.ino from Maxim. Their example
  was modified to work with the SparkFun MAX30105 library and to compile under Arduino 1.6.11
  Please see license file for more info.
  Hardware Connections (Breakoutboard to Arduino):
  -GND = GND
  -SDA = A4 (or SDA)
  -SCL = A5 (or SCL)
  The MAX30105 Breakout can handle 5V or 3.3V I2C logic. We recommend powering the board with 5V
  but it will also run at 3.3V.
#include <Wire.h>
#include "MAX30105.h"
#include "spo2_algorithm.h"
MAX30105 particleSensor;
#define MAX_BRIGHTNESS 255
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated. Samples become 16-bit data.
uint16_t irBuffer[100];   //infrared LED sensor data
uint16_t redBuffer[100];  //red LED sensor data
#else
uint32_t irBuffer[100];   //infrared LED sensor data
uint32_t redBuffer[100];  //red LED sensor data
#endif
int32_t bufferLength;   //data length
int32_t spo2;           //SPO2 value
int8_t validSPO2;       //indicator to show if the SPO2 calculation is valid
int32_t heartRate;      //heart rate value
int8_t validHeartRate;  //indicator to show if the heart rate calculation is valid
byte pulseLED = 11;  //Must be on PWM pin
byte readLED = 13;   //Blinks with each data read
  Serial.begin(115200);  // initialize serial communication at 115200 bits per second:
  pinMode(pulseLED, OUTPUT);
  pinMode(readLED, OUTPUT);
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST))  //Use default I2C port, 400kHz speed
    Serial.println(F("MAX30105 was not found. Please check wiring/power."));
    while (1)
  Serial.println(F("Attach sensor to finger with rubber band. Press any key to start conversion"));
  while (Serial.available() == 0)
    ;  //wait until user presses a key
  Serial.read();
  byte ledBrightness = 60;  //Options: 0=Off to 255=50mA
  byte sampleAverage = 4;   //Options: 1, 2, 4, 8, 16, 32
  byte ledMode = 2;         //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
  byte sampleRate = 100;    //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
  int pulseWidth = 411;     //Options: 69, 118, 215, 411
  int adcRange = 4096;      //Options: 2048, 4096, 8192, 16384
  particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange);  //Configure sensor with these settings
  bufferLength = 100;  //buffer length of 100 stores 4 seconds of samples running at 25sps
  //read the first 100 samples, and determine the signal range
  for (byte i = 0; i < bufferLength; i++) {
    while (particleSensor.available() == false)  //do we have new data?
      particleSensor.check();                    //Check the sensor for new data
    redBuffer[i] = particleSensor.getRed();
    irBuffer[i] = particleSensor.getIR();
    particleSensor.nextSample();  //We're finished with this sample so move to next sample
    Serial.print(F("red="));
    Serial.print(redBuffer[i], DEC);
    Serial.print(F(", ir="));
    Serial.println(irBuffer[i], DEC);
  //calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
  maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
  //Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every 1 second
  while (1) {
    //dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
    for (byte i = 25; i < 100; i++) {
      redBuffer[i - 25] = redBuffer[i];
      irBuffer[i - 25] = irBuffer[i];
    //take 25 sets of samples before calculating the heart rate.
    for (byte i = 75; i < 100; i++) {
      digitalWrite(readLED, !digitalRead(readLED));  //Blink onboard LED with every data read
      //send samples and calculation result to terminal program through UART
      Serial.print(irBuffer[i], DEC);
      Serial.print(F(", HR="));
      Serial.print(heartRate, DEC);
      Serial.print(F(", HRvalid="));
      Serial.print(validHeartRate, DEC);
      Serial.print(F(", SPO2="));
      Serial.print(spo2, DEC);
      Serial.print(F(", SPO2Valid="));
      Serial.println(validSPO2, DEC);
    //After gathering 25 new samples recalculate HR and SP02
CONECTIONS shown in this page because I couldn't upload the image:
ESP32 conections to max30102
Thats kind of strange .Did try swapping sda and scl pins
I tried doing that but it didn't work out
How are you powering the device using 3.3 or 5v
I tried both too, but I discover what was the problem. The pulseLED and the readLED pins were declared wrong. At the end I didn't even use them, so I decided to erase them and now the code is working fine.
can you show the coding because i had the same problem
They did.
this is for my fyp, but the readings not accuratee
I'm also getting same error, IF anyone got the solutions and code that works. Please help me
hi, did you get the code?
