For last couple of days I've been making my own spot welder, building was pretty easy, but I've encoutered some problem while building my own code.
Components used:
20x4 LCD with I2C, Fotek 40Amps relay, rotary encoder, 3 pushbuttons, and a Arduino Nano. I have no idea what to do to make it work. First of all, relay keeps switching with base values continuously until I release welding button. Also I can't make any changes in the menu. My idea was to switch between single pulse and double pulse mode with encoder button. I wanted also to change the times with rotary encoder after pressing suitable pushbuton.
I will be grateful for any help
I've put simplified scheme in attachments.
Code:
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
const int relayPin = 11;
bool two_pulses_mode = false;
bool pulse_time_change = false;
bool delay_time_change = false;
const int time_changing_button = 4;
const int delay_changing_button = 5;
const int welding_button = 13;
int pulse_duration = 20;
int delay_duration = 50;
const int clkPin = 8; // A
const int dataPin = 9; // B
const int swPin = 10; // Button
int encoder_movement();
void menu();
void mode_change();
void time_change();
void delay_time_changeA();
pinMode(relayPin, OUTPUT);
pinMode(clkPin, INPUT);
pinMode(dataPin, INPUT);
pinMode(swPin, INPUT);
pinMode(time_changing_button, INPUT);
pinMode(delay_changing_button, INPUT);
pinMode(welding_button, INPUT);
lcd.begin(20, 4);
menu();
void menu() {
lcd.clear();
if (two_pulses_mode = false) {
lcd.clear();
lcd.setCursor(2,0);
lcd.print("One pulse");
lcd.setCursor(2,1);
lcd.print("Time: ");
lcd.print(pulse_duration);
lcd.print("ms");
lcd.setCursor(2,2);
lcd.print("N/A");
lcd.setCursor(2,0);
lcd.print("Two pulses");
lcd.setCursor(2,1);
lcd.print("ms");
lcd.setCursor(2,2);
lcd.print("Delay: ");
lcd.print(delay_duration);
lcd.print("ms");
void mode_change() {
if (digitalRead(swPin) == LOW){
if (two_pulses_mode = false){
two_pulses_mode = true;
menu();
two_pulses_mode=false;
int encoder_movement() {
static int aLastState = HIGH;
static int bLastState = HIGH;
int mov = 0;
int aState = digitalRead(clkPin);
int bState = digitalRead(dataPin);
if ((aState != aLastState) || (bState != bLastState)) {
if (aLastState == HIGH && aState == LOW) {
ruch = (bLastState * 2 - 1);
aLastState = aState;
bLastState = bState;
return mov;
void time_change() {
if (digitalRead(time_changing_button) == HIGH) {
pulse_time_change = true;
if (pulse_time_change = true) {
int enc_position = 0;
int enc_LastPosition = 0;
int enc_movement = 0;
enc_movement = encoder_movement();
enc_position += enc_movement;
if (enc_position > enc_LastPosition) {
if (pulse_duration == 9995) {
pulse_duration = 1;
if (pulse_duration < 10) {
pulse_duration++;
pulse_duration += 5;
} else if (enc_position < enc_LastPosition) {
if (pulse_duration == 1) {
pulse_duration = 9995;
if (pulse_duration <= 10) {
pulse_duration--;
pulse_duration -= 5;
} else if (digitalRead(time_changing_button) == HIGH) {
void delay_time_changeA() {
if (two_pulses_mode = true && digitalRead(delay_changing_button) == HIGH) {
delay_time_change = true;
if (delay_time_change = true) {
if (delay_duration == 9995) {
delay_duration = 1;
if (delay_duration < 10) {
delay_duration++;
delay_duration += 5;
if (delay_duration == 1) {
delay_duration = 9995;
if (delay_duration <= 10) {
delay_duration--;
delay_duration -= 5;
} else if (digitalRead(delay_changing_button) == HIGH) {
if (digitalRead(welding_button) == HIGH) {
if (two_pulses_mode = true) {
digitalWrite(relayPin, HIGH);
delay(pulse_duration);
digitalWrite(relayPin, LOW);
delay(delay_duration);
menu();
} else
menu ();
