Hi there!
So I bought myself a cheap SSD1306 I2C 128x64 OLED display and downloaded the appropriate libraries from Adafruit:
The example sketch worked without a problem and is not stretched.
So I decided to display a own image. I created a 124x31 pixel bmp which I converted using the Img2Code Java programm form the Adafruit-GFX-Library:
I added the code as an array to the sample sketch and used the display.drawBitmap( 0, 0, code, 124, 31, 1); function, which to my understand has the correct input: offset 0,0 width: 124, height: 31
//save the image as array
const unsigned char PROGMEM logo [] =
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xff,0xfc,0x0,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xff,0xc0,0x0,
0xff,0xfc,0xff,0xfc,0x7c,0x3e,0x7f,0xfe,0x3f,0xff,0x0,0x7f,0x0,0xff,0xc0,0x0,
0xff,0xfc,0xff,0xfc,0x7c,0x3e,0x7f,0xfe,0x3f,0xff,0x0,0xff,0x0,0xff,0xc0,0x0,
0xff,0xfc,0xff,0xfc,0x7c,0x3e,0x7f,0xfe,0x3f,0xff,0x3,0xff,0x0,0xff,0xc0,0x0,
0xff,0xfc,0xff,0xfc,0x7c,0x3e,0x7f,0xfe,0x3f,0xff,0x7,0xff,0x0,0xff,0xc1,0xff,
0xf8,0x0,0xf8,0x7c,0x7c,0x3e,0x7c,0x3e,0x3e,0x1f,0xf,0xff,0x0,0xff,0xc1,0xff,
0xf8,0x0,0xf8,0x7c,0x7c,0x3e,0x7c,0x3e,0x3e,0x1f,0x1f,0xdf,0x0,0xff,0xc1,0xff,
0xf8,0x0,0xf8,0x7c,0x7c,0x3e,0x7c,0x3e,0x3e,0x1f,0x3f,0x9f,0x0,0xff,0xff,0xff,
0xf8,0x7c,0xf8,0x7c,0x7c,0x3e,0x7c,0x3e,0x3e,0x1f,0x3f,0x1f,0x0,0xff,0xff,0xff,
0xf8,0x7c,0xff,0xfc,0x7c,0x3e,0x7f,0xfe,0x3f,0xff,0x3f,0xff,0x0,0xff,0xff,0xff,
0xff,0xfc,0xff,0xfc,0x7f,0xfe,0x7f,0xfe,0x3f,0xff,0x3f,0xff,0x0,0xff,0xff,0xff,
0xff,0xfc,0xff,0xfc,0x7f,0xfe,0x7f,0xfe,0x3f,0xff,0x3e,0x1f,0x0,0xff,0xff,0xff,
0xff,0xfc,0x3f,0x7c,0x7f,0xfe,0x7c,0x0,0x3e,0x0,0x3e,0x1f,0x0,0xff,0xff,0xff,
0xff,0xfc,0x7e,0x7c,0x7f,0xfe,0x7c,0x0,0x3e,0x0,0x3e,0x1f,0x0,0xff,0xff,0xff
//display the image
display.clearDisplay();
display.display();
delay(40000);
However what I get is that the image is around 64 (I assume 62) pixel wide instead of the 31, which it should have:
This is how I expected the output to be (photoshopped):
Any idea where I did go wrong?
I already play around with different (incorrect) inputs for the drawBitmap() function, but so far no success.
Many thanks!
