Changing the display type in a sketch
Hello everyone! I want to make a signal strength indicator (SSI Meter). But the display on the SSD 1306 controller is too small. I want to replace the display with an SSD 1305 because it's too big. But there's a problem. The SSD 1306 library contains the operator SSD1306_INVERSE. But the SSD 1305 doesn't have this operator. What should I do?
Scetch:
#include <Wire.h>
#include <Adafruit_GFX.h>     // https://github.com/adafruit/Adafruit-GFX-Library
#include <Adafruit_SSD1306.h> // https://github.com/adafruit/Adafruit_SSD1306
                              // https://github.com/adafruit/Adafruit_BusIO.git
 Adafruit_SSD1306 display(128, 32, &Wire);
 int an_izm_r,an_izm_l;
 int ur_l,urr_l,ur_r,urr_r;
 int u_l0[20],u_r0[20];
 int ur,ul,urr,ull,urrr,ulll;
 int x,i1,u_maxr,u_maxl;
 Wire.begin();Wire.setClock(800000L);
 display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
 analogReadResolution(8);
 analogReference(INTERNAL1V024);
 pinMode(A0,INPUT);
 pinMode(A1,INPUT);
 an_izm_r = analogRead(A0);
 an_izm_l = analogRead(A1);
   urr_l = an_izm_l;
   urr_r = an_izm_r;
  if(urr_l<ur_l){ur_l=ur_l-2;}else{ur_l = an_izm_l;}
  if(urr_r<ur_r){ur_r=ur_r-2;}else{ur_r = an_izm_r;}
  if(urr_l>124){urr_l=124;}
  if(urr_r>124){urr_r=124;}
  if(ur_l>124){ur_l=124;}
  if(ur_r>124){ur_r=124;}
  i1++;if(i1<15){u_l0[i1]=abs(urr_l);u_r0[i1]=abs(urr_r);}else{i1=0;}
  if(i1==14){u_maxr=0;u_maxl=0;
    for(x=1;x<=15;x++){
      u_maxl=max(u_maxl,u_l0[x]);
      u_maxr=max(u_maxr,u_r0[x]);}}
  if(u_maxl<ulll){ulll=ulll-4;}else{ulll = u_maxl;}
  if(u_maxr<urrr){urrr=urrr-4;}else{urrr = u_maxr;}
  if(u_maxl<=urr_l){u_maxl=urr_l+4;}
  if(u_maxr<=urr_r){u_maxr=urr_r+4;}
 testfillrect();
void testfillrect(void) {
  display.clearDisplay();
if(ulll>4) { display.fillRect(ulll, 0, 2, 8, SSD1306_INVERSE);}
for(int i=0;i<=ur_l;i+=4){
  display.fillRect(i, 0, 2, 8, SSD1306_INVERSE);
  display.setTextSize(1);
  display.setTextColor(SSD1306_WHITE);
  display.drawLine(0, 9, 125, 9, SSD1306_WHITE);
  display.setCursor(0,11);
  display.println("-20  -10   -3");
  display.drawLine(90, 10, 125, 10, SSD1306_WHITE);
  display.setCursor(90,11);
  display.setTextColor(SSD1306_BLACK, SSD1306_WHITE);
  display.println(" 0  +3");
  display.drawLine(0, 19, 125, 19, SSD1306_WHITE);
 if(urrr>4) {display.fillRect(urrr, 21, 2, 8, SSD1306_INVERSE);}
for(int i=0;i<=ur_r;i+=4){
  display.fillRect(i, 21, 2, 8, SSD1306_INVERSE);
  display.display();
Libary SSD1306:
 * @file Adafruit_SSD1306.h
 * This is part of for Adafruit's SSD1306 library for monochrome
 * OLED displays: http://www.adafruit.com/category/63_98
 * These displays use I2C or SPI to communicate. I2C requires 2 pins
 * (SCL+SDA) and optionally a RESET pin. SPI requires 4 pins (MOSI, SCK,
 * select, data/command) and optionally a reset pin. Hardware SPI or
 * 'bitbang' software SPI are both supported.
 * Adafruit invests time and resources providing this open source code,
 * please support Adafruit and open-source hardware by purchasing
 * products from Adafruit!
 * Written by Limor Fried/Ladyada for Adafruit Industries, with
 * contributions from the open source community.
 * BSD license, all text above, and the splash screen header file,
 * must be included in any redistribution.
#ifndef _Adafruit_SSD1306_H_
#define _Adafruit_SSD1306_H_
// ONE of the following three lines must be #defined:
// #define SSD1306_128_64 ///< DEPRECTAED: old way to specify 128x64 screen
#define SSD1306_128_32 ///< DEPRECATED: old way to specify 128x32 screen
// #define SSD1306_96_16  ///< DEPRECATED: old way to specify 96x16 screen
// This establishes the screen dimensions in old Adafruit_SSD1306 sketches
// (NEW CODE SHOULD IGNORE THIS, USE THE CONSTRUCTORS THAT ACCEPT WIDTH
// AND HEIGHT ARGUMENTS).
// Uncomment to disable Adafruit splash logo
// #define SSD1306_NO_SPLASH
#if defined(ARDUINO_STM32_FEATHER)
typedef class HardwareSPI SPIClass;
#endif
#include <SPI.h>
#include <Wire.h>
#if defined(__AVR__)
typedef volatile uint8_t PortReg;
typedef uint8_t PortMask;
#define HAVE_PORTREG
#elif defined(__SAM3X8E__)
typedef volatile RwReg PortReg;
typedef uint32_t PortMask;
#elif defined(ARDUINO_ARCH_RTTHREAD)
#undef HAVE_PORTREG
#elif (defined(__arm__) || defined(ARDUINO_FEATHER52)) &&                      \
    !defined(ARDUINO_ARCH_MBED) && !defined(ARDUINO_ARCH_RP2040)
typedef volatile uint32_t PortReg;
#endif
/// The following "raw" color names are kept for backwards client compatability
/// They can be disabled by predefining this macro before including the Adafruit
/// header client code will then need to be modified to use the scoped enum
/// values directly
#ifndef NO_ADAFRUIT_SSD1306_COLOR_COMPATIBILITY
#define BLACK SSD1306_BLACK     ///< Draw 'off' pixels
#define WHITE SSD1306_WHITE     ///< Draw 'on' pixels
#define INVERSE SSD1306_INVERSE ///< Invert pixels
#endif
/// fit into the SSD1306_ naming scheme
#define SSD1306_BLACK 0   ///< Draw 'off' pixels
#define SSD1306_WHITE 1   ///< Draw 'on' pixels
#define SSD1306_INVERSE 2 ///< Invert pixels
#define SSD1306_MEMORYMODE 0x20          ///< See datasheet
#define SSD1306_COLUMNADDR 0x21          ///< See datasheet
#define SSD1306_PAGEADDR 0x22            ///< See datasheet
#define SSD1306_SETCONTRAST 0x81         ///< See datasheet
#define SSD1306_CHARGEPUMP 0x8D          ///< See datasheet
#define SSD1306_SEGREMAP 0xA0            ///< See datasheet
#define SSD1306_DISPLAYALLON_RESUME 0xA4 ///< See datasheet
#define SSD1306_DISPLAYALLON 0xA5        ///< Not currently used
#define SSD1306_NORMALDISPLAY 0xA6       ///< See datasheet
#define SSD1306_INVERTDISPLAY 0xA7       ///< See datasheet
#define SSD1306_SETMULTIPLEX 0xA8        ///< See datasheet
#define SSD1306_DISPLAYOFF 0xAE          ///< See datasheet
#define SSD1306_DISPLAYON 0xAF           ///< See datasheet
#define SSD1306_COMSCANINC 0xC0          ///< Not currently used
#define SSD1306_COMSCANDEC 0xC8          ///< See datasheet
#define SSD1306_SETDISPLAYOFFSET 0xD3    ///< See datasheet
#define SSD1306_SETDISPLAYCLOCKDIV 0xD5  ///< See datasheet
#define SSD1306_SETPRECHARGE 0xD9        ///< See datasheet
#define SSD1306_SETCOMPINS 0xDA          ///< See datasheet
#define SSD1306_SETVCOMDETECT 0xDB       ///< See datasheet
#define SSD1306_SETLOWCOLUMN 0x00  ///< Not currently used
#define SSD1306_SETHIGHCOLUMN 0x10 ///< Not currently used
#define SSD1306_SETSTARTLINE 0x40  ///< See datasheet
#define SSD1306_EXTERNALVCC 0x01  ///< External display voltage source
#define SSD1306_SWITCHCAPVCC 0x02 ///< Gen. display voltage from 3.3V
#define SSD1306_RIGHT_HORIZONTAL_SCROLL 0x26              ///< Init rt scroll
#define SSD1306_LEFT_HORIZONTAL_SCROLL 0x27               ///< Init left scroll
#define SSD1306_VERTICAL_AND_RIGHT_HORIZONTAL_SCROLL 0x29 ///< Init diag scroll
#define SSD1306_VERTICAL_AND_LEFT_HORIZONTAL_SCROLL 0x2A  ///< Init diag scroll
#define SSD1306_DEACTIVATE_SCROLL 0x2E                    ///< Stop scroll
#define SSD1306_ACTIVATE_SCROLL 0x2F                      ///< Start scroll
#define SSD1306_SET_VERTICAL_SCROLL_AREA 0xA3             ///< Set scroll range
// Deprecated size stuff for backwards compatibility with old sketches
#if defined SSD1306_128_64
#define SSD1306_LCDWIDTH 128 ///< DEPRECATED: width w/SSD1306_128_64 defined
#define SSD1306_LCDHEIGHT 64 ///< DEPRECATED: height w/SSD1306_128_64 defined
#endif
#if defined SSD1306_128_32
#define SSD1306_LCDWIDTH 128 ///< DEPRECATED: width w/SSD1306_128_32 defined
#define SSD1306_LCDHEIGHT 32 ///< DEPRECATED: height w/SSD1306_128_32 defined
#endif
#if defined SSD1306_96_16
#define SSD1306_LCDWIDTH 96  ///< DEPRECATED: width w/SSD1306_96_16 defined
#define SSD1306_LCDHEIGHT 16 ///< DEPRECATED: height w/SSD1306_96_16 defined
#endif
    @brief  Class that stores state and functions for interacting with
            SSD1306 OLED displays.
class Adafruit_SSD1306 : public Adafruit_GFX {
public:
  // NEW CONSTRUCTORS -- recommended for new projects
  Adafruit_SSD1306(uint8_t w, uint8_t h, TwoWire *twi = &Wire,
                   int8_t rst_pin = -1, uint32_t clkDuring = 400000UL,
                   uint32_t clkAfter = 100000UL);
  Adafruit_SSD1306(uint8_t w, uint8_t h, int8_t mosi_pin, int8_t sclk_pin,
                   int8_t dc_pin, int8_t rst_pin, int8_t cs_pin);
  Adafruit_SSD1306(uint8_t w, uint8_t h, SPIClass *spi, int8_t dc_pin,
                   int8_t rst_pin, int8_t cs_pin, uint32_t bitrate = 8000000UL);
  // DEPRECATED CONSTRUCTORS - for back compatibility, avoid in new projects
  Adafruit_SSD1306(int8_t mosi_pin, int8_t sclk_pin, int8_t dc_pin,
  Adafruit_SSD1306(int8_t dc_pin, int8_t rst_pin, int8_t cs_pin);
  Adafruit_SSD1306(int8_t rst_pin = -1);
  ~Adafruit_SSD1306(void);
  bool begin(uint8_t switchvcc = SSD1306_SWITCHCAPVCC, uint8_t i2caddr = 0,
             bool reset = true, bool periphBegin = true);
  void display(void);
  void clearDisplay(void);
  void invertDisplay(bool i);
  void dim(bool dim);
  void drawPixel(int16_t x, int16_t y, uint16_t color);
  virtual void drawFastHLine(int16_t x, int16_t y, int16_t w, uint16_t color);
  virtual void drawFastVLine(int16_t x, int16_t y, int16_t h, uint16_t color);
  void startscrollright(uint8_t start, uint8_t stop);
  void startscrollleft(uint8_t start, uint8_t stop);
  void startscrolldiagright(uint8_t start, uint8_t stop);
  void startscrolldiagleft(uint8_t start, uint8_t stop);
  void stopscroll(void);
  void ssd1306_command(uint8_t c);
  bool getPixel(int16_t x, int16_t y);
  uint8_t *getBuffer(void);
protected:
  inline void SPIwrite(uint8_t d) __attribute__((always_inline));
  void drawFastHLineInternal(int16_t x, int16_t y, int16_t w, uint16_t color);
  void drawFastVLineInternal(int16_t x, int16_t y, int16_t h, uint16_t color);
  void ssd1306_command1(uint8_t c);
  void ssd1306_commandList(const uint8_t *c, uint8_t n);
  SPIClass *spi;   ///< Initialized during construction when using SPI. See
                   ///< SPI.cpp, SPI.h
  TwoWire *wire;   ///< Initialized during construction when using I2C. See
                   ///< Wire.cpp, Wire.h
  uint8_t *buffer; ///< Buffer data used for display buffer. Allocated when
                   ///< begin method is called.
  int8_t i2caddr;  ///< I2C address initialized when begin method is called.
  int8_t vccstate; ///< VCC selection, set by begin method.
  int8_t page_end; ///< not used
  int8_t mosiPin;  ///< (Master Out Slave In) set when using SPI set during
                   ///< construction.
  int8_t clkPin;   ///< (Clock Pin) set when using SPI set during construction.
  int8_t dcPin;    ///< (Data Pin) set when using SPI set during construction.
  int8_t
      csPin; ///< (Chip Select Pin) set when using SPI set during construction.
  int8_t rstPin; ///< Display reset pin assignment. Set during construction.
#ifdef HAVE_PORTREG
  PortReg *mosiPort, *clkPort, *dcPort, *csPort;
  PortMask mosiPinMask, clkPinMask, dcPinMask, csPinMask;
#endif
#if ARDUINO >= 157
  uint32_t wireClk;    ///< Wire speed for SSD1306 transfers
  uint32_t restoreClk; ///< Wire speed following SSD1306 transfers
#endif
  uint8_t contrast; ///< normal contrast setting for this device
#if defined(SPI_HAS_TRANSACTION)
protected:
  // Allow sub-class to change
  SPISettings spiSettings;
#endif
#endif // _Adafruit_SSD1306_H_
Libary SSD1305:
This is a library for our Monochrome OLEDs based on SSD1305 drivers
  Pick one up today in the adafruit shop!
  ------> https://www.adafruit.com/products/2675
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
#include <Adafruit_GrayOLED.h>
#define BLACK 0
#define WHITE 1
#define SSD1305_I2C_ADDRESS 0x3C // 011110+SA0+RW - 0x3C or 0x3D
#define SSD1305_SETLOWCOLUMN 0x00
#define SSD1305_SETHIGHCOLUMN 0x10
#define SSD1305_MEMORYMODE 0x20
#define SSD1305_SETCOLADDR 0x21
#define SSD1305_SETPAGEADDR 0x22
#define SSD1305_SETSTARTLINE 0x40
#define SSD1305_SETCONTRAST 0x81
#define SSD1305_SETBRIGHTNESS 0x82
#define SSD1305_SETLUT 0x91
#define SSD1305_SEGREMAP 0xA0
#define SSD1305_DISPLAYALLON_RESUME 0xA4
#define SSD1305_DISPLAYALLON 0xA5
#define SSD1305_NORMALDISPLAY 0xA6
#define SSD1305_INVERTDISPLAY 0xA7
#define SSD1305_SETMULTIPLEX 0xA8
#define SSD1305_DISPLAYDIM 0xAC
#define SSD1305_MASTERCONFIG 0xAD
#define SSD1305_DISPLAYOFF 0xAE
#define SSD1305_DISPLAYON 0xAF
#define SSD1305_SETPAGESTART 0xB0
#define SSD1305_COMSCANINC 0xC0
#define SSD1305_COMSCANDEC 0xC8
#define SSD1305_SETDISPLAYOFFSET 0xD3
#define SSD1305_SETDISPLAYCLOCKDIV 0xD5
#define SSD1305_SETAREACOLOR 0xD8
#define SSD1305_SETPRECHARGE 0xD9
#define SSD1305_SETCOMPINS 0xDA
#define SSD1305_SETVCOMLEVEL 0xDB
/*! The controller object for SSD1305 OLED displays */
class Adafruit_SSD1305 : public Adafruit_GrayOLED {
public:
  Adafruit_SSD1305(uint16_t w, uint16_t h, TwoWire *twi = &Wire,
                   int8_t rst_pin = -1, uint32_t preclk = 400000,
                   uint32_t postclk = 100000);
  Adafruit_SSD1305(uint16_t w, uint16_t h, int8_t mosi_pin, int8_t sclk_pin,
  Adafruit_SSD1305(uint16_t w, uint16_t h, SPIClass *spi, int8_t dc_pin,
  ~Adafruit_SSD1305(void);
  bool begin(uint8_t i2caddr = SSD1305_I2C_ADDRESS, bool reset = true);
  void display();
  void sleep();
  void wake();
private:
  uint8_t page_offset = 0;
  uint8_t column_offset = 0;
Welcome to the forum
The Adafruit SSD1305 library has an SSD1305_INVERTDISPLAY function and an example with the library shows how to use it
  // invert the display
  display.invertDisplay(true);
Maybe this can be done using the ADAFRUIT_GFX library. But I'm just a beginner. I'm having trouble with this line. The SSD1305 display doesn't support INVERSE.
There's no need to invert the entire display. Just the selected area with the specified coordinates.
