Hello there.
I want to see the sensor value (0 -1023) that I will connect to the Arduino "A0" analog input as a floating graphic on the LCD. The Y axis of the graph will be at the value of the X axis analog signal for 2 minutes and the graph will shift to the left as time passes. There are many examples made with OLED display, but I couldn't find an example made with "ST7920 128X64 2.9" LCD.
Thank you in advance.
this is clear
this is totally unclear
do you want to display something like this on your display???
you have to describe
very precise
what you want to have
if your english is limited just use google translate.
Write down a detailed description in your native language.
Then let do google translate the translation.
The grammar won't be brilliant but it will be easy to understand.
best regards Stefan
I did a quoogling with keywords Github ST7920
and google found this
best regards Stefan
