Start with LiquidCrystal_I2C
I Try to start with LiquidCrystal_I2C, but it doesn't work. I thing isn't necessary include wire libary with the las version of LC I2C. The LCD's screen lights, but does'nt apear the message I have written.. I dont know why?! Can you help me?
I've defined LiquidCrystal_I2C lcd(0x27, 16,2)
I've used init, backlight, clear, setCursor, print..., (void setup) and scrollDisplayLeft, delay(500) (void loop)
I have SDA to A4 and SCL to A5
Thanks!!!
Images of code suck.
Use code tags (the </> icon above the compose window) to make it easier to read and copy code for examination
I2C scanner
What did the I2C scanner report?
if the I2C address is correct on the scanner, (0x27),
make sure the brightness setting is not too intense.
Vary the adjustment on the potentiometer and see if anything appears.
I've adjusted the potentiometer yet!
Uoooo!!! It is working!
Then, whay my LCD can't read the message?!
Thanks
  • Have you tried Arduino IDE 1.8.19 running on a PC?
In the File > Prefeences menu, select these options ...
Have you pressed the upload button?
  • Could you reply to post #2? (Click thisimage and post your code in the highlighted area)
  • Could you post an image project?
I've pressed the upload button, yes!
I've upload many others sketches using only LEDS. They've working all ok!
I don't understand the other question... I'm going to try...
I thing I've started on a wrong way with Arduino, because I thing I am working always in the cloud and I have not de IDE instaled. I've tried it, but I don't get the instaling screen...
I upload a file where I show you the screens I get. According to tutorials for a download, I would get a creen in which I can install, agree,..chech a list, instal...and close. Then, an arduino icon is in the desk, or in donlowds....I don't have this symbol in my PC.
my screens Arduino.pdf (524,5 KB)
