I'm trying to use a button to make my step motor work but it was suppost only work while i'm pressing the button but it's always working and when i press the button it stop. What did i do wrong?
This is the code
#include <Stepper.h>
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int stepsPerRevolution = 500;
Stepper myStepper(stepsPerRevolution, 8,10,9,11);
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
myStepper.setSpeed(60);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH)
myStepper.step(-513); [code]
// delay(2000);
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What are you driving the stepper with?
What is your stepper spec/data, can you post a link.
Do you have an external resistor wired with your switch? You are not using the internal pullup resistor, so you MUST have an external one. Is it wired as a pullup or pulldown resistor?
