(HELP) Step motor with Button
I'd like to control step motor with button
So I made a circuit like this.
I can handle LED, but Step motor doesn't move.
Here is Arduino CODE
#include<Stepper.h>
int ledPin = 5;
int buttonApin = 12;
int buttonBpin = 13;
int motorPin1 = 8;
int motorPin2 = 9;
int motorPin3 = 10;
int motorPin4 = 11;
int delayTime = 1;
Stepper motor(200, motorPin1, motorPin2, motorPin3, motorPin4);
byte leds = 0;
pinMode(ledPin, OUTPUT);
pinMode(buttonApin, INPUT_PULLUP);
pinMode(buttonBpin, INPUT_PULLUP);
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
motor.setSpeed(100);
if (digitalRead(buttonApin) == LOW)
digitalWrite(ledPin, HIGH);
digitalWrite(motorPin1, HIGH);
digitalWrite(motorPin2, LOW);
digitalWrite(motorPin3, HIGH);
digitalWrite(motorPin4, LOW);
delay(delayTime);
digitalWrite(motorPin1, LOW);
digitalWrite(motorPin2, HIGH);
delay(delayTime);
digitalWrite(motorPin3, LOW);
digitalWrite(motorPin4, HIGH);
delay(delayTime);
delay(delayTime);
if (digitalRead(buttonBpin) == LOW)
digitalWrite(ledPin, LOW);
What is the problem?
Can you guys please help me?
You can download circuit images!!!
You seem to have a lot of digitalWrite()s which (I presume) are intended to control the motor.
That is what the Stepper library is for. Read the documentation.
  • What stepper driver are you using ? I hope you are not connecting your motor directly to the Arduino - that would probably damage the Arduino.
  • Post a link to the datasheet for your stepper motor.
  • What power supply are you using for the motor (volts and amps)
...R
Stepper Motor Basics
