What is your opinion in using a (inductive) boost converter oscillating at 180kHz to supply a UHF transmitter module in very close proximity?
How much do you think the EM field from the converter would interfere with the transmitter?
The line output ripple i don't think would cause any significant problems, since the transmitter works nicely even with a noisy PSU. I'm more concerned about the interacting EM fields.
The alternative would be to use a higher voltage battery. What would you recommend in this scenario?
I reasoned that since they are so close together (one besides the other), the oscilating inductor on the converter might somehow affect the inductors on the transmitter, causing a detuning or something. Maybe attenuating the signal.
The converter would be run at 50mA which i'm guessing it's not a negligible amount that the inductor EM field must handle.
But yes, we're talking orders of magnitude in frequency difference.
Is your transmitter a free running oscillator? I think not, if it is it would never have got type approval.
No all that could possibly happen is to introduce some frequency modulation on the carrier. The mechanism for that would not be electro-magnetic. And as I said that would only apply to a free running oscillator which you should not have.
By free running i presume you mean LC resonator circuit. I't snot, it's a crystal transmitter.
Yes, i was also thinking along the lines of modulating the carrier. But that would also not be a problem since my modulating signal is also far below the 180kHz. I think i'm good to go then. Thanks.
UHF Transmitter, put it in a metal (Ferrous) enclosure.
SMPS put it in a metal (ferrous) enclosure.
They don't have to be sophisticated, just some thin metal bent over each and grounded to chassis.
