Stepper motor issue when using I2C LCD
Hello all:
I am trying to control a stepper motor using an Arduino UNO. [See attached file]
I also want to control/monitor the speed using and LCD with some built-in buttons:
I noticed that regardless of the method that I use for motor_control, when I use the LCD, arduino start sending inconsistent steps and make the motor to jitter and not run properly.
Once I turn of the code related to the LCD, it works just fine!
I am not sure if it is related to the "Adafruit_RGBLCDShield.h" library and if it messes up with the pins or it is just a timer setting that is not set properly!
Here is the drive in case some one is intrestd:
http://leadshineusa.com/UploadFile/Down/MX3660d_V1.0.pdf
Would appreciate your input!
Here is the code:
// include the library code:
#include <TimerOne.h>
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
#include <AccelStepper.h>
// The shield uses the I2C SCL and SDA pins. On classic Arduinos
// this is Analog 4 and 5 so you can't use those for analogRead() anymore
// However, you can connect other I2C sensors to the I2C bus and share
// the I2C bus.
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// These #defines make it easy to set the backlight color
AccelStepper stepper(1,7,6);
#define      RED              0x1
unsigned int t_sec          = 300;
unsigned int Speed          = 100;
unsigned int SpeedChange    = 100;
unsigned int SpeedFineTune  = 10;
unsigned int SpeedLowerTrsh = 10;
unsigned int SpeedUpprtTrsh = 1000;
long         pd             = 500;  // Pulse Delay period
boolean    setdir         = LOW; // Set Direction
char         MotDir         = 'L';
int            reverseSwitch  = 2;  // Push button for reverse
uint8_t     i              = 0;
  ///////////////////////////////////////////////// Motor Drive and LCD  Init   /////////////////////////////////////////
  lcd.begin(16, 2);
  lcd.print("XXXX Tech.");
  stepper.setMaxSpeed(1000);
  stepper.setSpeed(500);
  pinMode(9,OUTPUT);
  Timer1.initialize(100);  //100us = 10khz
  Timer1.pwm(9,512);       // 50% DC
  /////////////////////////////////////////////////  Main Loop ////////////////////////////////////////////////////////////
  stepper.runSpeed();
  //lcd_handler();
  ///////////////////////////////////////////// This is the LCD Functionality part ///////////////////////////////////////
  void lcd_handler(){
  // set the cursor to column 0, line 1
  lcd.setCursor(0, 1);
  lcd.print("Speed is: ");
  lcd.setCursor(15, 1);
  lcd.print(MotDir);
  lcd.setCursor(10, 1);
  lcd.print(Speed);
  uint8_t buttons = lcd.readButtons();
  if (buttons) {
    lcd.clear();
    lcd.setCursor(0,0);
    if (buttons & BUTTON_UP) {
      if (Speed+SpeedChange<SpeedUpprtTrsh){
        Speed += SpeedChange;
        delay(t_sec);
      lcd.print("Increase Speed");
    if (buttons & BUTTON_DOWN) {
      if (Speed > SpeedChange+SpeedLowerTrsh){
        Speed -= SpeedChange;
        delay(t_sec);
      lcd.print("Decrease Speed ");
    if (buttons & BUTTON_LEFT) {
      if (Speed > SpeedFineTune+SpeedLowerTrsh){
        Speed -= SpeedFineTune;
        delay(t_sec);
      lcd.print("Fine Tune (Low)");
    if (buttons & BUTTON_RIGHT) {
      if (Speed+SpeedFineTune<SpeedUpprtTrsh){
        Speed += SpeedFineTune;
        delay(t_sec);
      lcd.print("Fine Tune (Up)");
    if (buttons & BUTTON_SELECT) {
      lcd.print("* No Action *");
