I'am using the arduino stepper motor shield rev 3 to control a stepper motor Portescap 17h118D10B.
I am using this sample code :
// Include the Stepper Library
#include <Stepper.h>// Map our pins to constants to make things easier to keep track of
const int pwmA = 3;
const int pwmB = 11;
const int brakeA = 9;
const int brakeB = 8;
const int dirA = 12;
const int dirB = 13;// The amount of steps for a full revolution of your motor.
// 360 / stepAngle
const int STEPS = 48;// Initialize the Stepper class
Stepper myStepper(STEPS, dirA, dirB);void setup() {
// Set the RPM of the motor
myStepper.setSpeed(30);// Turn on pulse width modulation
pinMode(pwmA, OUTPUT);
digitalWrite(pwmA, HIGH);
pinMode(pwmB, OUTPUT);
digitalWrite(pwmB, HIGH);// Turn off the brakes
pinMode(brakeA, OUTPUT);
digitalWrite(brakeA, LOW);
pinMode(brakeB, OUTPUT);
digitalWrite(brakeB, LOW);// Log some shit
}void loop() {
// Move the motor X amount of steps
myStepper.step(STEPS);
Serial.println(STEPS);
// Pause
delay(2000);// Move the motor X amount of steps the other way
myStepper.step(-STEPS);
Serial.println(-STEPS);
// Pause
delay(2000);
My issue is that with this board my stepper motor vibrates a lot and overheats.
I also tried to control it with the BC4E20EU Quad 0.15 to 2.0 Amp Bipolar Current Regulating Motor Controller and the result is really much more satisfying.
My feeling is that the stepper motor shield Rev3 is not controlling my stepper in microstep mode.
With the adafruit motor shield and AFstepper library (AF_Stepper Class | Adafruit Motor Shield | Adafruit Learning System) it is possible to choose the "style".
step(steps, direction, style)Step the motor.
Parameters:
steps - the number of steps to turn
direction - the direction of rotation (FORWARD or BACKWARD)
style - the style of stepping:
Valid values for 'style' are:
SINGLE - One coil is energized at a time.
DOUBLE - Two coils are energized at a time for more torque.
INTERLEAVE - Alternate between single and double to create a half-step in between. This can result in smoother operation, but because of the extra half-step, the speed is reduced by half too.
MICROSTEP - Adjacent coils are ramped up and down to create a number of 'micro-steps' between each full step. This results in finer resolution and smoother rotation, but with a loss in torque.
My question is : Is the stepper shield Rev 3 also controlling the stepper in microstep mode ? If not, is there a way to do that ?
I found in the stepper.h file thiese lines :
The sequence of control signals for 4 control wires is as follows:
Step C0 C1 C2 C3
1 1 0 1 0
2 0 1 1 0
3 0 1 0 1
4 1 0 0 1The sequence of controls signals for 2 control wires is as follows
(columns C1 and C2 from above):Step C0 C1
1 0 1
2 1 1
3 1 0
4 0 0
