Hi, I have a problem with birds pooping on my sailboat. They gather on top of the mast and poop all over the boat. One way I get rid of them when I am there is I shake a spare halyard (a line running up to the top of the mast). This scares the birds away and they fly away instantly.
I want to design something that will shake the line periodically when I am not on the boat. I was thinking about using an Arduino, stepper motor and driver. I would attach the halyard to an arm connected to the stepper motor. Then program the Arduino to oscilate 180 degrees and back a few times every x minutes.
Does this idea seem feasible? Any potential issues? I have limited experience with stepper motors.
I thought of that but I've read that deterrents like owls, ect, only work for short periods of time. Eventually the birds learn it's static and ignore it. But I'll probably give that a try if my way overcomplicated method doesn't work, lol.
Thanks. That's probably a simpler solution. I wanted to use a stepper motor though so I could have it go 180, change directions, and go back 180 repeatedly. Would that be possible with a dc motor?
Thanks... not really a lot power needed though from what I can tell. Just basically need to move an arm back and forth with a line connected to it. The line wouldn't be under any kind of a load per se. Probably speed would be more important.
There's a commercial vineyard near me that uses hawk kites attached to a post to scare the birds away. They move around in the wind and are sort of realistic looking. They bring them out every year just before harvest so I guess it must work.
But if you're intent on using Arduino all you need is a DC gearmotor and a basic FET driver to control it. Program arduino to run for a few seconds every 5 minutes or something.
If you have the mechanical wherewithal maybe something like an auto windshield wiper arrangement could work. Motor only turns one direction and levers convert that into a back and forth motion. I think with this you could dispense with the position switch(es), just run the motor for X seconds and let it stop where it is.
