I am pretty new into Arduino and trying to make a small cnc router.
I have connected the Arduino board with a GRBL based cnc shield, And as motor driver i am using DRV8825 module. As power source I am using a 12v 27aH lead acid battery to power the NEMA 17 4.2 kgcm motor.
While I am running one motor with one driver and providing manual feed from universal G-code sender, the motors is working fine. but whenever I am connecting three driver and three motors the motors are not moving.Rather they are only vibrating.
Sayab:
You need to explain that in more detail. For example ...
Can you get every one of the motors to work one at a time?
Does it matter which driver the motor is connected to?
How is everything connected when you try with one motor, and with all three motors?
and anything else that might help us to help you
Also post a link to the datasheet for your stepper motors.
Firstly I hope you have a suitable fuse on that battery, a 27Ah lead acid battery can do an enormous
amount of damage without a fuse.
Secondly are your wiring and connectors adequate for the current - the voltage at the motor
driver board should hold up at 12V without much droop, you should measure to confirm this.
If the voltage is drooping you have either a duff battery or poor connector somewhere.
Note that lead acid batteries are easy to destroy - they must never be stored except at full-charge,
and should be regularly topped up in storage (every month is good). Over-discharge also ruins them.
If your lead-acid battery has been neglected it would account for the behaviour.
