Hello,
I'm working on a project involving a 3-phase inverter circuit. My goal is simply to design a 3-phase inverter circuit capable of delivering around 200 watts. I'm sharing the circuit and the code I'm trying to implement below. I'm planning to use an STM32 as the microcontroller, but I'm encountering multiple errors in the main.c file when working with STM32CubeIDE. Is there a better approach I should follow, or could you help me identify the issues in the code?
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "lcd.h"
#include "adc.h"
#include "dac.h"
#include "key.h"
#include "stdio.h"
#include "timer.h"
#include "control.h"
#include "pwm.h"
#include "oled.h"
#define Kp 40.0
#define Ki 20.0
void double_array_init(double* arr,double init_value,u8 n)
u8 i;
for(i = 0;i < n;i++)
arr[i] = init_value;
void ADC_Value_Filter(u16* Adc_Value,u16* Adc_Value_After_Filter)//ADC数据滤波
unsigned char i;
for(i=0;i<6;i++)
Adc_Value_After_Filter[i]+=Adc_Value[i];
for(i=0;i<6;i++)
Adc_Value_After_Filter[i]/=2;
u16 Adc_Value[6];//临时存放ADC值
// Adc_Value0:ADC1_CH_3 Adc_Value3:ADC1_CH_5
// Adc_Value1: ADC2_CH_6 Adc_Value4:ADC2_CH_10
// Adc_Value2: ADC3_CH_11 Adc_Value5:ADC3_CH_12
u16 Adc_Value_After_Filter[6];//存放ADC滤波后的值,程序使用这个
// Adc_Value_After_Filter[0]:ADC1_CH_3 Adc_Value_After_Filter[3]:ADC1_CH_5
// Adc_Value_After_Filter[1]: ADC2_CH_6 Adc_Value_After_Filter[4]:ADC2_CH_10
// Adc_Value_After_Filter[2]: ADC3_CH_11 Adc_Value_After_Filter[5]:ADC3_CH_12
int registe=0;
u16 ADC_CH3_=0;
u16 ADC_CH5_=0;
u16 ADC_CH6_=0;
int main(void)
char str_buf[60];
float Tabel_Error[Error_Buf_Size+1] = {8.506461,-16.872492,8.435995};
float Tabel_Output[Output_Buf_Size] = {1.454446,-0.454446};
float Target_Voltage = 25;
SystemInit();
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
Control_Init(&control,Target_Voltage,Tabel_Error,Tabel_Output);
delay_init(168); //初始化延时函数
uart_init(115200); //初始化串口波特率为115200
IIC_Init(); //与OLED初始化配合使用
OLED_Init(); //与IIC初始化配合使用
Adc_Init(); //adc初始化 : 3个ADC,每个ADC有2通道
LED_Init(); //初始化LED
TIM1_PWM_Init(500-1,84-1); //此处延续了原子的程序,实际上这里的参数并不起作用,PWM的周期和分频在pwm.h中设置
TIM1->CCR1=1000; //占空比初始化
TIM1->CCR2=1000; //占空比初始化
// TIM8_PWM_Init(500-1,84-1); //初始化TIM8后TIM1_CH2N输出将会变成TIM8_CH2N,可以根据需要初始化
// TIM8->CCR2=1000; //占空比初始化
while(1){
sprintf(str_buf,"%4d",Adc_Value[0]);
OLED_P6x8Str(0,0,str_buf);
sprintf(str_buf,"%4d",Adc_Value[1]);
OLED_P6x8Str(0,1,str_buf);
sprintf(str_buf,"%4d",Adc_Value[2]);
OLED_P6x8Str(0,2,str_buf);
sprintf(str_buf,"%4d",Adc_Value[3]);
OLED_P6x8Str(0,3,str_buf);
sprintf(str_buf,"%4d",Adc_Value[4]);
OLED_P6x8Str(0,4,str_buf);
sprintf(str_buf,"%4d",Adc_Value[5]);
OLED_P6x8Str(0,5,str_buf);
delay_ms(500);
