Strange behavior with tlc5940 led driver for led cube
For some time now I have been working on a 888 RGB led cube. The only problem is that when ever I try to switch a large number of the red LED's on I get random LED's lighting up. I will say that the chip's that run the red LED's are at the start of the data chain (Sin). I have tried swapping the drivers, checking the wiring and a few other things. I am using a arduino nano.
code: (note that I have only been working with one layer)
 #include "SparkFun_Tlc5940.h"
  Tlc.init();
  Tlc.clear();
  Random("G",100,10);
  Random("RGB",100,10);
  Random("R",100,10);
  Random("GB",100,10);
  Random("B",100,10);
  Random("RG",100,10);
  //fill_slide("R",1000);
void Random(String type, int times, int delay_time) {
  int direction = 1;
  int channel = 0, first = 0, last = 0;
  if(type == "R"){
    first = 0;
    last = 64;
  }else if(type == "G"){
    first = 65;
    last = 128;
  }else if(type == "B"){
    first = 129;
    last = 192;
  }else if(type == "RG"){
    first = 0;
    last = 128;
  }else if(type == "GB"){
    first = 65;
    last = 192;
  }else if(type == "RGB"){
    first = 0;
    last = 192;
  Tlc.clear();
  for (int count = 0; count <= times; count ++) {
    Tlc.set(random(first, last), 500);
    Tlc.update();
    delay(delay_time);
TLC5940 Datasheet - http://www.ti.com/lit/ds/symlink/tlc5940.pdf
TLC5940 Library - GitHub - sparkfun/SparkFun_TLC5940_Arduino_Library: Library for the TLC5940
Thanks,
Eli
If I were to guess you are powering from the Arduino. Remember the Arduino is not a power supply and what I suspect is you are swamping the power supply causing the voltage to drop and the microprocessor to lose its place in the program. Use a separate power supply. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
Hi Gil
Thanks, but I am all ready using a 8A regulated 5v power supply that is powering everything including the arduino via the 5v and GND pins. Also it is just red with this behavior both green and blue are working perfectly.
Eli
I will try to get better documentation posted like schematics, videos, etc.
Have you got decoupling caps on those chips?
yes I do.
Turns out that all I needed to do was add some extra connections to the data lines due to the weird way I soldered everything together. Sorry for the wasted time.
Thanks,
Eli
