Strange output when using drawGrayscaleBitmap() [solved]
Hi all,
I have been playing around with bitmap images on my colour OLED display. The libraries I use for my display is Adafruit GFX and Adafruit SSD1351. So far I have managed to display RGB and monochrome bitmaps with decent quality on my display.
The website I use to convert images to arrays is: File to C style array converter. To produce convert images into greyscale bitmap arrays, I have used the settings shown in the screenshot of the website.
When I apply these settings for the image 'mona_lisa.gif', the result is a distorted blue image as seen in the second photo. PNG, BMP and JPG images also suffer from the same issue.
I am unsure about how generated greyscale bitmap images should look since I have only been able to find examples of monochrome and RGB bitmaps generated on displays. Is this how greyscale bitmaps should appear on an OLED display?
Is your hex code the same as base64, but without 0xBBBB?
Since you mentioned it's a color OLED, you probably need to select a different palette like "16bit RRRRRGGGGGGBBBBB". That'll convert the grayscale values to the equivalent RGB values that your display requires.
I am not fully sure. Is there a way to compare the hex code with base64?
The problem is that the function drawGrayscaleBitmap() expects a progmem array of type uint8_t. The format '16 bit RGB' works for the function drawRGBBitmap().
According to this:
http://adafruit.github.io/Adafruit-GFX-Library/html/class_adafruit___g_f_x.html#af7f146631268e8940d9c44c64c69ab80
void Adafruit_GFX::drawGrayscaleBitmap(int16_t *x*, int16_t *y*, const uint8_t *bitmap*[], int16_t *w*, int16_t *h* )
Draw a PROGMEM-resident 8-bit image (grayscale) at the specified (x,y) pos. Specifically for 8-bit display devices such as IS31FL3731; no color reduction/expansion is performed.
This function isn't made to work on your color display. You'll have to use drawRGBBitmap() and convert the image to the 16-bit RGB565 format.
This guy explains it in detail:
I did not check if the ASCII output of base64 translated directly to your 0xBBBB.
I have used the tool. The ASCII output of base64 did not match the image.
I see you solved it (says the forum bot)... cool... I hope you post your completed project here. I used to teach customers how to transfer files over a (rather antiquated) network using an image file, byte by byte.
#define IMAGE_HEIGHT 128
#define IMAGE_WIDTH 96
// array size is 12288
static const unsigned char image[] PROGMEM  = {
  0xd1, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xcf, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xcb, 0xbf, 0xba, 0xbc, 0xbf, 0xb5, 0x93, 0x82, 0x8a, 0x9e, 0xb4, 0xc9, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xce, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa8, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x8d, 0x88, 0x68, 0x41, 0x33, 0x2d, 0x2f, 0x3a, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x38, 0x52, 0x5f, 0x66, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x67, 0x88, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x70, 0x46, 0x54, 0x5c, 0x5b, 0x36, 0x4c, 0x58, 0x2f, 0x4a, 0x54, 0x4e, 0x35, 0x55, 0x46, 0x2f, 0x2e, 0x32, 0x3f, 0x44, 0x46, 0x47, 0x4c, 0x56, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0x5e, 0x50, 0x5d, 0x5e, 0x5e, 0x5e, 0x48, 0x58, 0x5d, 0x52, 0x5c, 0x5e, 0x5e, 0x5a, 0x5e, 0x5b, 0x39, 0x3a, 0x36, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3a, 0x52, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x67, 0x54, 0x5e, 0x60, 0x5e, 0x61, 0x5e, 0x54, 0x5d, 0x72, 0x61, 0x64, 0x78, 0x93, 0x7f, 0x6b, 0x5e, 0x59, 0x5c, 0x51, 0x2f, 0x3a, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x36, 0x4f, 0x5a, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x5a, 0x5e, 0x7a, 0xc5, 0x9f, 0xbe, 0x8e, 0x63, 0x5e, 0xbf, 0xb8, 0xb1, 0xce, 0xcd, 0xc6, 0xb9, 0x5d, 0x90, 0x5e, 0x5d, 0x4e, 0x5d, 0x41, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x30, 0x4a, 0x5a, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x81, 0x57, 0xab, 0xc1, 0xd0, 0xcf, 0xd0, 0xcb, 0xa1, 0x5e, 0xbb, 0xcf, 0xcf, 0xd0, 0xd0, 0xd0, 0xcb, 0x61, 0xa3, 0xb7, 0xaf, 0x5c, 0x5e, 0x5a, 0x58, 0x45, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x33, 0x53, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x5c, 0x5c, 0xb7, 0xd0, 0xd0, 0xce, 0xc1, 0xc8, 0xb4, 0x5e, 0x5e, 0x9e, 0x84, 0xb8, 0xcf, 0xa3, 0x9c, 0x5e, 0x95, 0xd0, 0xcf, 0xae, 0x5b, 0x5e, 0x5e, 0x5a, 0x3b, 0x35, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4e, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x7c, 0x53, 0x5e, 0x8d, 0xc3, 0xbe, 0xbb, 0x7d, 0x8b, 0xb0, 0x5e, 0x5e, 0x5e, 0x5c, 0x5d, 0x78, 0x5f, 0x5d, 0x5e, 0x64, 0xb4, 0xd0, 0xaa, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x5c, 0x47, 0x4c, 0x55, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x52, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x6f, 0x5d, 0x5e, 0x5e, 0x85, 0x64, 0x5d, 0x5e, 0x5e, 0x75, 0x5e, 0x5a, 0x5e, 0x51, 0x5a, 0x5d, 0x54, 0x5d, 0x5e, 0x54, 0x5f, 0x95, 0x74, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x57, 0x5c, 0x5d, 0x3c, 0x2f, 0x2f, 0x2f, 0x2f, 0x31, 0x58, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x6f, 0x5e, 0x5e, 0x5d, 0x5d, 0x5e, 0x5d, 0x5e, 0x5e, 0x5c, 0x5e, 0x4b, 0x5d, 0x4b, 0x4f, 0x58, 0x2e, 0x58, 0x5d, 0x3c, 0x47, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x5d, 0x5e, 0x44, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3c, 0x5c, 0x5b, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x65, 0x5e, 0x5e, 0x55, 0x4e, 0x56, 0x4d, 0x5c, 0x5c, 0x4a, 0x5e, 0x47, 0x52, 0x51, 0x34, 0x4d, 0x2f, 0x35, 0x44, 0x2f, 0x2f, 0x52, 0x5e, 0x5e, 0x58, 0x5d, 0x5e, 0x5d, 0x56, 0x5c, 0x5d, 0x59, 0x5c, 0x3f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4d, 0x5c, 0x55, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x86, 0x5f, 0x5e, 0x5e, 0x45, 0x2f, 0x2f, 0x2f, 0x51, 0x5b, 0x33, 0x5b, 0x4c, 0x35, 0x50, 0x2e, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x31, 0x51, 0x5c, 0x4a, 0x52, 0x59, 0x36, 0x2e, 0x46, 0x58, 0x3e, 0x5d, 0x4e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x33, 0x58, 0x49, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x83, 0x5e, 0x5e, 0x5d, 0x32, 0x2f, 0x2f, 0x2f, 0x2e, 0x39, 0x2f, 0x4e, 0x55, 0x2f, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x36, 0x2f, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x59, 0x52, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x50, 0x39, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x74, 0x5e, 0x5e, 0x58, 0x2e, 0x4a, 0x55, 0x32, 0x2f, 0x2f, 0x2f, 0x2f, 0x4b, 0x31, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4d, 0x52, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x3d, 0x2c, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x84, 0x5e, 0x5e, 0x5e, 0x4d, 0x51, 0x5d, 0x5e, 0x59, 0x54, 0x56, 0x55, 0x42, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x32, 0x4a, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3d, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x81, 0x5e, 0x5e, 0x5d, 0x58, 0x5e, 0x76, 0xa8, 0xb4, 0xa3, 0x85, 0x62, 0x5d, 0x4f, 0x3e, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3b, 0x55, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x83, 0x5e, 0x5e, 0x5e, 0x5e, 0x92, 0xcb, 0xd0, 0xd0, 0xd0, 0xd0, 0xc7, 0xa7, 0x6c, 0x5d, 0x53, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x40, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0x5d, 0x5e, 0x5e, 0x94, 0xce, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xc7, 0x8c, 0x5e, 0x59, 0x53, 0x44, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x44, 0x5b, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x82, 0x5e, 0x5e, 0x88, 0xcd, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xce, 0xa0, 0x5e, 0x5e, 0x56, 0x33, 0x2e, 0x2e, 0x2e, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x52, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x6d, 0x5e, 0x62, 0xc5, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xae, 0x67, 0x5e, 0x5d, 0x5c, 0x5b, 0x5b, 0x59, 0x53, 0x46, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x35, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0x5c, 0x5e, 0x89, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xc5, 0xa3, 0x8e, 0x8b, 0x93, 0x91, 0x82, 0x68, 0x5c, 0x59, 0x49, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x52, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x5c, 0x5e, 0xab, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xcc, 0xb9, 0x8d, 0x5e, 0x59, 0x4e, 0x38, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x42, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x60, 0x5c, 0xc4, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xb3, 0x65, 0x5e, 0x5c, 0x53, 0x36, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x31, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x5d, 0x82, 0xcf, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xaa, 0x5e, 0x5e, 0x5e, 0x5a, 0x3b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x5a, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x83, 0x5e, 0xb2, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xc6, 0x5c, 0x5e, 0x5e, 0x5e, 0x58, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x5a, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x7d, 0x67, 0xcc, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xb8, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x48, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x76, 0x8d, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xcd, 0xaa, 0x69, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x56, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3d, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x79, 0x5e, 0xa3, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xcd, 0x83, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x31, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x50, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x92, 0xb2, 0x5c, 0xb4, 0xba, 0xbb, 0xc5, 0xcd, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xc8, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x3e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x32, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x85, 0xc6, 0xca, 0x61, 0xb9, 0x72, 0x80, 0x63, 0x6b, 0x84, 0xa2, 0xc6, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xc1, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x44, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x86, 0xcc, 0xcb, 0x7f, 0xce, 0xce, 0xd0, 0xc7, 0xa1, 0x66, 0x5e, 0x64, 0x92, 0xb6, 0xce, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xce, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x56, 0x57, 0x33, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x36, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0xc8, 0xc8, 0xa7, 0xd0, 0xcf, 0xbd, 0xb2, 0xb5, 0xb6, 0x74, 0x5e, 0x5e, 0x5d, 0x8c, 0xce, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xa3, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x49, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x53, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0xbd, 0xbe, 0xc8, 0xd0, 0xc7, 0x87, 0x5c, 0x60, 0x5b, 0x6f, 0x54, 0x59, 0x5e, 0x5d, 0xae, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xce, 0x98, 0x82, 0x63, 0x5e, 0x5e, 0x5e, 0x5e, 0x51, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x45, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0xb3, 0xc8, 0xd0, 0xd0, 0xd0, 0xd0, 0xcb, 0xcc, 0xaa, 0x5f, 0x33, 0x39, 0x54, 0x5e, 0x78, 0xcf, 0xd0, 0xd0, 0xd0, 0xcf, 0xbb, 0xab, 0xb8, 0xcd, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xbc, 0x61, 0x5e, 0x5e, 0x5b, 0x34, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x33, 0x5a, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x84, 0xc2, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xce, 0xa2, 0x7a, 0x8e, 0x7f, 0x6c, 0x81, 0xce, 0xd0, 0xd0, 0xcd, 0x90, 0x5d, 0x5e, 0x5d, 0x72, 0x92, 0xa0, 0xa5, 0xa7, 0xa8, 0xaa, 0x68, 0x5e, 0x5e, 0x55, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x52, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x8d, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xaa, 0x5e, 0x58, 0x50, 0x4e, 0x53, 0x5a, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x54, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x44, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x8d, 0xcf, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0x87, 0x59, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x39, 0x4b, 0x55, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5a, 0x30, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x32, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x81, 0xbb, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xcf, 0x72, 0x5b, 0x55, 0x4f, 0x30, 0x3b, 0x3d, 0x48, 0x2f, 0x2f, 0x31, 0x48, 0x5a, 0x5d, 0x5d, 0x59, 0x31, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x51, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x84, 0xb7, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xb4, 0x5e, 0x5e, 0x5f, 0x63, 0x74, 0xa4, 0x9f, 0x74, 0x2e, 0x2f, 0x2f, 0x2f, 0x2e, 0x3b, 0x3e, 0x33, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x44, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0xb8, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xc1, 0x68, 0x5e, 0x5e, 0xa5, 0xcf, 0xd0, 0xd0, 0xb5, 0x66, 0x4b, 0x3d, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x35, 0x5a, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0xb5, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0x8d, 0x5e, 0x5e, 0x5e, 0xa9, 0xd0, 0xd0, 0xd0, 0xd0, 0xc7, 0x9c, 0x69, 0x50, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x40, 0x4b, 0x57, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0xa2, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xce, 0x6f, 0x5e, 0x5e, 0x5e, 0xa6, 0xd0, 0xd0, 0xd0, 0xd0, 0xc2, 0x7e, 0x5d, 0x5a, 0x53, 0x49, 0x35, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3a, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x98, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xbf, 0x5d, 0x5e, 0x5e, 0x5d, 0xb4, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xce, 0xbe, 0xa3, 0x7a, 0x5e, 0x5c, 0x4f, 0x30, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0xa0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xa5, 0x5e, 0x5e, 0x5e, 0x5e, 0xc5, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xcf, 0xa5, 0x5e, 0x5e, 0x52, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x39, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0xaa, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xce, 0xbb, 0xce, 0xd0, 0xd0, 0xd0, 0xd0, 0x85, 0x5e, 0x5e, 0x5d, 0x61, 0xc9, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xa2, 0x5e, 0x5e, 0x5a, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x86, 0xb1, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xce, 0x70, 0x8d, 0xca, 0xd0, 0xcb, 0xa7, 0x5e, 0x5e, 0x5e, 0x59, 0x5d, 0xc1, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xab, 0x5f, 0x5e, 0x5e, 0x4f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3a, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x84, 0xb3, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xae, 0x5d, 0x69, 0x77, 0x68, 0x5d, 0x5e, 0x5e, 0x5e, 0x53, 0x5d, 0xa5, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xcb, 0x97, 0x5d, 0x5e, 0x5d, 0x52, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x30, 0x57, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x84, 0xb2, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xcf, 0x9a, 0x5d, 0x4e, 0x49, 0x4a, 0x5b, 0x5e, 0x5c, 0x3f, 0x5d, 0x6b, 0xc8, 0xd0, 0xd0, 0xd0, 0xd0, 0xb9, 0x78, 0x5e, 0x5e, 0x5c, 0x49, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4f, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x84, 0xa7, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xcf, 0x81, 0x50, 0x2f, 0x2f, 0x3a, 0x47, 0x3a, 0x36, 0x5d, 0x5e, 0x95, 0xcf, 0xd0, 0xc8, 0x97, 0x5e, 0x5e, 0x5e, 0x5b, 0x40, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3a, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x85, 0x8d, 0xd0, 0xd0, 0xd0, 0xac, 0x9f, 0xcf, 0xd0, 0xd0, 0xd0, 0xd0, 0x96, 0x5e, 0x59, 0x42, 0x2e, 0x2f, 0x2e, 0x4c, 0x5e, 0x5e, 0x5e, 0x99, 0xa2, 0x6c, 0x5e, 0x5e, 0x5e, 0x59, 0x3b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x55, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0x67, 0xcc, 0xd0, 0xc5, 0x62, 0x7a, 0x98, 0xc9, 0xd0, 0xd0, 0xd0, 0xba, 0x6b, 0x5d, 0x5d, 0x56, 0x53, 0x57, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x59, 0x38, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x4f, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x5e, 0xb9, 0xd0, 0xd0, 0xc8, 0xce, 0xa0, 0x62, 0x7f, 0xa3, 0xc6, 0xd0, 0xcc, 0xbe, 0x77, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x58, 0x36, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x30, 0x51, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x72, 0x9f, 0xd0, 0xd0, 0xd0, 0xd0, 0xc6, 0xab, 0x7f, 0x5b, 0x62, 0x98, 0xa6, 0x9b, 0x69, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x59, 0x35, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x2e, 0x2f, 0x45, 0x58, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x82, 0x76, 0xce, 0xd0, 0xd0, 0xd0, 0xb3, 0xac, 0xd0, 0xc2, 0x70, 0x51, 0x52, 0x54, 0x58, 0x5c, 0x5d, 0x5e, 0x5d, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x3c, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4d, 0x59, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x5f, 0xbb, 0xd0, 0xd0, 0xd0, 0xc9, 0x68, 0x9d, 0xc4, 0xc8, 0xc9, 0x99, 0x58, 0x50, 0x3e, 0x39, 0x3d, 0x38, 0x36, 0x5d, 0x5e, 0x5e, 0x5e, 0x51, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x34, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x78, 0x95, 0xd0, 0xd0, 0xd0, 0xd0, 0x98, 0x5c, 0x5b, 0x62, 0x81, 0x76, 0x5e, 0x5e, 0x53, 0x2f, 0x2f, 0x3a, 0x52, 0x5e, 0x5e, 0x5e, 0x5d, 0x3c, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0x64, 0xc6, 0xd0, 0xd0, 0xd0, 0xc8, 0x75, 0x53, 0x50, 0x54, 0x56, 0x56, 0x52, 0x3b, 0x4a, 0x59, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x57, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x32, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x71, 0x99, 0xd0, 0xd0, 0xd0, 0xd0, 0xc7, 0x9b, 0x63, 0x55, 0x46, 0x3f, 0x42, 0x52, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x59, 0x39, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x75, 0x5f, 0xad, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xc3, 0x80, 0x5e, 0x5d, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x51, 0x32, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0x83, 0x79, 0x6e, 0x63, 0x54, 0x60, 0x77, 0x5f, 0xa1, 0xcc, 0xd0, 0xd0, 0xd0, 0xd0, 0xc7, 0x65, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5a, 0x43, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x33, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0x84, 0x82, 0x79, 0x6d, 0x61, 0x57, 0x56, 0x58, 0x49, 0x2d, 0x5a, 0xa4, 0x5e, 0x5e, 0x78, 0xab, 0xc2, 0xc9, 0xc5, 0xac, 0x60, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x55, 0x36, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x50, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa6, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0x86, 0x82, 0x7a, 0x6c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x54, 0x2c, 0x5b, 0xbf, 0x63, 0x5e, 0x5c, 0x5d, 0x5d, 0x5d, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x4e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x31, 0x58, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xa2, 0x82, 0x7e, 0x7c, 0x7a, 0x73, 0x65, 0x5f, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4e, 0x2d, 0x5b, 0xc7, 0x9f, 0x5d, 0x5c, 0x48, 0x4c, 0x54, 0x57, 0x58, 0x59, 0x57, 0x54, 0x4c, 0x39, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3a, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x45, 0x2e, 0x58, 0xc6, 0xcf, 0xb0, 0x65, 0x5c, 0x45, 0x2f, 0x2f, 0x2e, 0x2e, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x45, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x3a, 0x2f, 0x57, 0xc3, 0xd0, 0xd0, 0xa0, 0x5e, 0x5c, 0x3d, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4d, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x30, 0x2f, 0x55, 0xbf, 0xd0, 0xd0, 0xb6, 0x5e, 0x5e, 0x58, 0x30, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x54, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x58, 0x2f, 0x2f, 0x51, 0xb7, 0xd0, 0xd0, 0xba, 0x5e, 0x5e, 0x5e, 0x48, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x33, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4c, 0x2f, 0x2f, 0x48, 0xa7, 0xd0, 0xd0, 0xa5, 0x5e, 0x5e, 0x5e, 0x48, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3d, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x59, 0x30, 0x2f, 0x2f, 0x33, 0x78, 0xcd, 0xd0, 0x7e, 0x5e, 0x5c, 0x53, 0x31, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4a, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x45, 0x2f, 0x2f, 0x2f, 0x2f, 0x4c, 0x8e, 0x9d, 0x5f, 0x5e, 0x50, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x3b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x57, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x55, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x52, 0x5e, 0x5e, 0x5e, 0x5c, 0x4a, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x52, 0x5d, 0x49, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x39, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x51, 0x5d, 0x5e, 0x5e, 0x5d, 0x59, 0x4e, 0x40, 0x31, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4a, 0x5d, 0x5e, 0x5c, 0x3b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4f, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4d, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x4b, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5a, 0x3a, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3e, 0x5c, 0x5e, 0x5e, 0x5e, 0x57, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3a, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x59, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x35, 0x4a, 0x52, 0x53, 0x50, 0x48, 0x39, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x33, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4c, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x42, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x45, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x54, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5b, 0x38, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x47, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x55, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x4f, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x52, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4d, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x3b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4c, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x3a, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x52, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x46, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x31, 0x57, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5a, 0x33, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3e, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x58, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x37, 0x5a, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x49, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x36, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5b, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x40, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x57, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x56, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x59, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x49, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x42, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4f, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x54, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4f, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x54, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x47, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x55, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x3a, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3d, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x3c, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x35, 0x5a, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x50, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x33, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5a, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3e, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5b, 0x34, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x53, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x55, 0x2f, 0x2f, 0x2f, 0x2f, 0x33, 0x4c, 0x53, 0x4e, 0x37, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x47, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4c, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x49, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4b, 0x2f, 0x2f, 0x2f, 0x3f, 0x5a, 0x5e, 0x5e, 0x5e, 0x5c, 0x4f, 0x31, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4f, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x59, 0x30, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3e, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x3b, 0x2f, 0x2f, 0x39, 0x5a, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5a, 0x45, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x55, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x47, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x32, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5a, 0x2d, 0x2f, 0x2e, 0x56, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x53, 0x36, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x35, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x57, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x51, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x54, 0x2f, 0x2f, 0x46, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5b, 0x46, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3e, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x43, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x46, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x49, 0x2f, 0x2f, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x53, 0x33, 0x2f, 0x2f, 0x2f, 0x2f, 0x47, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x56, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x38, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x35, 0x2f, 0x46, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x59, 0x3f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4f, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x41, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x55, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x57, 0x2e, 0x2e, 0x57, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x48, 0x2e, 0x2f, 0x2f, 0x2f, 0x55, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x56, 0x2e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4a, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5c, 0x48, 0x58, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x4c, 0x2f, 0x3e, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x4e, 0x2f, 0x2f, 0x2f, 0x34, 0x59, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x41, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x39, 0x5b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x39, 0x2f, 0x4e, 0x5d, 0x5e, 0x5e, 0x5c, 0x37, 0x2f, 0x52, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5d, 0x53, 0x31, 0x2f, 0x2f, 0x3d, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x57, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x55, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x3d, 0x2f, 0x2f, 0x44, 0x5b, 0x5e, 0x55, 0x2f, 0x34, 0x5c, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x58, 0x37, 0x2f, 0x2f, 0x44, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8e, 0x5e, 0x5e, 0x5e, 0x5e, 0x47, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x46, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x40, 0x2f, 0x2f, 0x2f, 0x3f, 0x57, 0x3e, 0x2f, 0x4b, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5a, 0x3f, 0x2f, 0x2f, 0x4b, 0x5d, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x5e, 0x84, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x8d, 0x5d, 0x5d, 0x5d, 0x5a, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x30, 0x58, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x45, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x2f, 0x2e, 0x58, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5d, 0x5b, 0x45, 0x2f, 0x2e, 0x58, 0x5a, 0x5a, 0x5a, 0x5a, 0x5a, 0x5a, 0x5a, 0x7f, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x36, 0x36, 0x36, 0x34, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x35, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x31, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x35, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x36, 0x34, 0x2f, 0x2f, 0x2e, 0x2e, 0x2e, 0x2e, 0x2e, 0x2e, 0x2e, 0x2e, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x47, 0x4e, 0x4e, 0x4e, 0x4c, 0x36, 0x2f, 0x2f, 0x35, 0x4e, 0x4e, 0x3b, 0x2f, 0x2f, 0x34, 0x54, 0x5c, 0x50, 0x31, 0x2f, 0x2f, 0x48, 0x4e, 0x47, 0x2f, 0x2f, 0x47, 0x4e, 0x4b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x46, 0x4e, 0x43, 0x2f, 0x2f, 0x2f, 0x2f, 0x30, 0x4d, 0x5c, 0x57, 0x39, 0x2f, 0x44, 0x4e, 0x4e, 0x4e, 0x4e, 0x4e, 0x4e, 0x44, 0x3e, 0x4e, 0x4e, 0x33, 0x2f, 0x2f, 0x2f, 0x34, 0x4e, 0x4e, 0x4e, 0x4e, 0x4e, 0x4e, 0x45, 0x4e, 0x4d, 0x30, 0x2f, 0x2f, 0x4a, 0x4e, 0x47, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x88, 0x88, 0x88, 0x86, 0x5e, 0x2f, 0x48, 0x88, 0x88, 0x59, 0x2f, 0x48, 0x81, 0x88, 0x88, 0x88, 0x7c, 0x3c, 0x2e, 0x7a, 0x88, 0x78, 0x2f, 0x3a, 0x85, 0x88, 0x6c, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x7e, 0x88, 0x77, 0x2e, 0x2f, 0x2f, 0x37, 0x78, 0x88, 0x88, 0x88, 0x84, 0x4e, 0x6f, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x70, 0x61, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x88, 0x88, 0x88, 0x89, 0x63, 0x88, 0x88, 0x4d, 0x2f, 0x39, 0x86, 0x88, 0x6a, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x88, 0x88, 0x88, 0x88, 0x87, 0x45, 0x48, 0x88, 0x88, 0x58, 0x2e, 0x7a, 0x88, 0x88, 0x88, 0x88, 0x88, 0x6c, 0x2e, 0x7a, 0x88, 0x78, 0x2f, 0x65, 0x88, 0x86, 0x3f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x3a, 0x87, 0x88, 0x83, 0x31, 0x2f, 0x2f, 0x66, 0x88, 0x88, 0x87, 0x88, 0x88, 0x7c, 0x6f, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x70, 0x61, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x88, 0x88, 0x88, 0x89, 0x48, 0x85, 0x88, 0x67, 0x2f, 0x57, 0x88, 0x88, 0x4c, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x7b, 0x4a, 0x69, 0x88, 0x88, 0x61, 0x48, 0x88, 0x88, 0x58, 0x3f, 0x87, 0x88, 0x71, 0x3d, 0x7b, 0x88, 0x81, 0x2e, 0x7a, 0x88, 0x78, 0x34, 0x83, 0x88, 0x6b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x53, 0x88, 0x88, 0x88, 0x46, 0x2f, 0x2e, 0x7b, 0x88, 0x7d, 0x39, 0x67, 0x88, 0x87, 0x4b, 0x4a, 0x5b, 0x88, 0x88, 0x60, 0x4a, 0x41, 0x61, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x65, 0x4a, 0x4a, 0x4a, 0x33, 0x74, 0x88, 0x7b, 0x2f, 0x6f, 0x88, 0x80, 0x30, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x78, 0x2f, 0x3b, 0x87, 0x88, 0x69, 0x48, 0x88, 0x88, 0x58, 0x4d, 0x88, 0x88, 0x58, 0x2f, 0x69, 0x88, 0x86, 0x33, 0x7a, 0x88, 0x78, 0x60, 0x88, 0x86, 0x3f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x67, 0x88, 0x88, 0x88, 0x5c, 0x2f, 0x2d, 0x80, 0x88, 0x70, 0x2f, 0x45, 0x6c, 0x6c, 0x3e, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x5c, 0x2f, 0x2f, 0x2f, 0x2f, 0x59, 0x88, 0x87, 0x3e, 0x81, 0x88, 0x6a, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x78, 0x2f, 0x39, 0x87, 0x88, 0x69, 0x48, 0x88, 0x88, 0x58, 0x4e, 0x88, 0x88, 0x55, 0x2f, 0x3b, 0x45, 0x44, 0x30, 0x7a, 0x88, 0x78, 0x80, 0x88, 0x6b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x77, 0x88, 0x85, 0x88, 0x6e, 0x2f, 0x2e, 0x7e, 0x88, 0x79, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x5c, 0x2f, 0x2f, 0x2f, 0x2f, 0x37, 0x85, 0x88, 0x67, 0x88, 0x88, 0x4c, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x78, 0x2e, 0x57, 0x88, 0x88, 0x60, 0x48, 0x88, 0x88, 0x58, 0x4e, 0x88, 0x88, 0x55, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x7a, 0x88, 0x86, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x32, 0x83, 0x88, 0x73, 0x88, 0x7e, 0x2e, 0x2f, 0x73, 0x88, 0x88, 0x7b, 0x63, 0x3f, 0x2f, 0x2f, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x6d, 0x5a, 0x5a, 0x4a, 0x2f, 0x2f, 0x73, 0x88, 0x83, 0x88, 0x80, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x87, 0x82, 0x87, 0x88, 0x86, 0x41, 0x48, 0x88, 0x88, 0x58, 0x4e, 0x88, 0x88, 0x55, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x7a, 0x88, 0x88, 0x88, 0x88, 0x6f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x45, 0x88, 0x88, 0x56, 0x88, 0x87, 0x3b, 0x2f, 0x51, 0x87, 0x88, 0x88, 0x88, 0x86, 0x59, 0x2f, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x88, 0x88, 0x88, 0x6b, 0x2f, 0x2f, 0x58, 0x88, 0x88, 0x88, 0x69, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x88, 0x88, 0x88, 0x85, 0x56, 0x2f, 0x48, 0x88, 0x88, 0x58, 0x4e, 0x88, 0x88, 0x55, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x7a, 0x88, 0x88, 0x88, 0x88, 0x83, 0x34, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x5c, 0x88, 0x81, 0x39, 0x86, 0x88, 0x53, 0x2f, 0x2f, 0x57, 0x7e, 0x88, 0x88, 0x88, 0x84, 0x34, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x88, 0x87, 0x87, 0x6b, 0x2f, 0x2f, 0x35, 0x85, 0x88, 0x88, 0x4b, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x7e, 0x72, 0x88, 0x85, 0x35, 0x2f, 0x48, 0x88, 0x88, 0x58, 0x4e, 0x88, 0x88, 0x55, 0x2f, 0x2f, 0x2f, 0x2f, 0x2e, 0x7a, 0x88, 0x88, 0x75, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x6e, 0x88, 0x76, 0x2d, 0x7f, 0x88, 0x66, 0x2f, 0x2f, 0x2f, 0x2e, 0x45, 0x76, 0x88, 0x88, 0x4c, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x61, 0x3e, 0x3e, 0x38, 0x2f, 0x2f, 0x2f, 0x75, 0x88, 0x82, 0x30, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x78, 0x4c, 0x88, 0x88, 0x55, 0x2f, 0x48, 0x88, 0x88, 0x58, 0x4e, 0x88, 0x88, 0x55, 0x2f, 0x47, 0x58, 0x58, 0x31, 0x7a, 0x88, 0x7e, 0x3c, 0x87, 0x88, 0x70, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2d, 0x7e, 0x88, 0x78, 0x61, 0x7d, 0x88, 0x77, 0x2f, 0x2e, 0x2e, 0x2e, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x5c, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x72, 0x88, 0x80, 0x2d, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x78, 0x2f, 0x82, 0x88, 0x70, 0x2f, 0x48, 0x88, 0x88, 0x58, 0x4b, 0x88, 0x88, 0x5a, 0x2f, 0x6b, 0x88, 0x86, 0x31, 0x7a, 0x88, 0x78, 0x2e, 0x76, 0x88, 0x84, 0x34, 0x2f, 0x2f, 0x2f, 0x2f, 0x39, 0x86, 0x88, 0x88, 0x88, 0x88, 0x88, 0x84, 0x33, 0x80, 0x82, 0x5f, 0x2f, 0x4b, 0x88, 0x88, 0x53, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x3e, 0x2f, 0x2f, 0x2f, 0x42, 0x89, 0x88, 0x5c, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x72, 0x88, 0x80, 0x2d, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x78, 0x2f, 0x6f, 0x88, 0x84, 0x33, 0x48, 0x88, 0x88, 0x58, 0x3b, 0x87, 0x88, 0x78, 0x52, 0x80, 0x88, 0x7e, 0x2e, 0x7a, 0x88, 0x78, 0x2f, 0x5a, 0x88, 0x88, 0x57, 0x2f, 0x2f, 0x2f, 0x2f, 0x51, 0x88, 0x88, 0x7b, 0x7a, 0x7d, 0x88, 0x88, 0x47, 0x7f, 0x88, 0x7d, 0x51, 0x72, 0x88, 0x88, 0x45, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x62, 0x5d, 0x5d, 0x5b, 0x43, 0x89, 0x88, 0x6e, 0x5d, 0x5d, 0x5d, 0x36, 0x2f, 0x2f, 0x72, 0x88, 0x80, 0x2d, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x78, 0x88, 0x78, 0x2f, 0x56, 0x88, 0x88, 0x53, 0x48, 0x88, 0x88, 0x58, 0x2e, 0x75, 0x88, 0x88, 0x88, 0x88, 0x88, 0x63, 0x2e, 0x7a, 0x88, 0x78, 0x2f, 0x38, 0x85, 0x88, 0x72, 0x2f, 0x2f, 0x2f, 0x2f, 0x65, 0x88, 0x84, 0x30, 0x2e, 0x3a, 0x87, 0x88, 0x5e, 0x66, 0x88, 0x88, 0x88, 0x88, 0x88, 0x7c, 0x2f, 0x2f, 0x4c, 0x88, 0x88, 0x54, 0x2f, 0x2f, 0x60, 0x88, 0x88, 0x88, 0x88, 0x88, 0x85, 0x45, 0x89, 0x88, 0x88, 0x88, 0x88, 0x89, 0x41, 0x2f, 0x2f, 0x72, 0x88, 0x80, 0x2d, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x77, 0x87, 0x78, 0x2f, 0x38, 0x85, 0x87, 0x6d, 0x47, 0x88, 0x87, 0x58, 0x2f, 0x3e, 0x79, 0x88, 0x88, 0x87, 0x6f, 0x33, 0x2e, 0x79, 0x87, 0x77, 0x2f, 0x2f, 0x72, 0x87, 0x85, 0x34, 0x2f, 0x2f, 0x2f, 0x74, 0x87, 0x79, 0x2e, 0x2f, 0x2f, 0x7f, 0x87, 0x6f, 0x34, 0x70, 0x87, 0x88, 0x88, 0x7d, 0x46, 0x2f, 0x2f, 0x4c, 0x88, 0x87, 0x54, 0x2f, 0x2f, 0x60, 0x87, 0x87, 0x87, 0x87, 0x87, 0x85, 0x45, 0x88, 0x87, 0x87, 0x87, 0x87, 0x88, 0x41, 0x2f, 0x2f, 0x72, 0x87, 0x80, 0x2d, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0x7e, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x37, 0x3a, 0x37, 0x2f, 0x2f, 0x39, 0x3a, 0x38, 0x31, 0x3a, 0x3a, 0x33, 0x2f, 0x2f, 0x2f, 0x41, 0x4b, 0x3d, 0x2f, 0x2f, 0x2f, 0x38, 0x3a, 0x37, 0x2f, 0x2f, 0x34, 0x3a, 0x3a, 0x31, 0x2f, 0x2f, 0x2f, 0x38, 0x3a, 0x36, 0x2f, 0x2f, 0x2f, 0x38, 0x3a, 0x37, 0x2f, 0x2f, 0x3c, 0x4b, 0x43, 0x30, 0x2f, 0x2f, 0x2f, 0x31, 0x3a, 0x3a, 0x32, 0x2f, 0x2f, 0x34, 0x3a, 0x3a, 0x3a, 0x3a, 0x3a, 0x3a, 0x30, 0x3a, 0x3a, 0x3a, 0x3a, 0x3a, 0x3a, 0x30, 0x2f, 0x2f, 0x36, 0x3a, 0x39, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x2f, 0x66, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xb8, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xb2, 0xd0, 0xd0, 0xd0,
  0xd1, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0, 0xd0,
  0xd0, 0xcb, 0xc7, 0xc6, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc5, 0xc7
