Converting the project from Indrek
Hey guys, i followed this Tutorial by Indrek in order to take a picture with my OV7670 camera module and my arduino uno: https://www.youtube.com/watch?v=R94WZH8XAvM&list=LL&index=1
Everything works fine with the UART and the ArduImageCapture Tool. But instead of visualizing the picture directly via UART, i want to transform the pixel values and output them via Serial Monitor. Did anyone do this before or can help me with it?
Here is the code of the UART example where the data is loaded from the camera:
// Created by indrek on 1.05.2016.
// set EXAMPLE to EXAMPLE_UART in setup.h to activate
#include "setup.h"
#if EXAMPLE == 3
#include "Arduino.h"
#include "CameraOV7670.h"
// select resolution and communication speed:
//  1 - 115200bps 160x120 rgb
//  2 - 115200bps 160x120 grayscale
//  3 - 500000bps 160x120 rgb
//  4 - 500000bps 160x120 grayscale
//  5 - 500000bps 320x240 rgb
//  6 - 500000bps 320x240 grayscale
//  7 - 1Mbps 160x120 rgb
//  8 - 1Mbps 160x120 grayscale
//  9 - 1Mbps 320x240 rgb
// 10 - 1Mbps 320x240 grayscale
// 11 - 1Mbps 640x480 grayscale
// 12 - 2Mbps 160x120 rgb
// 13 - 2Mbps 160x120 grayscale
// 14 - 2Mbps 320x240 rgb
// 15 - 2Mbps 320x240 grayscale
// 16 - 2Mbps 640x480 rgb
// 17 - 2Mbps 640x480 grayscale
#define UART_MODE 6
const uint8_t VERSION = 0x10;
const uint8_t COMMAND_NEW_FRAME = 0x01 | VERSION;
const uint8_t COMMAND_DEBUG_DATA = 0x03 | VERSION;
const uint16_t UART_PIXEL_FORMAT_RGB565 = 0x01;
const uint16_t UART_PIXEL_FORMAT_GRAYSCALE = 0x02;
// Pixel byte parity check:
// Pixel Byte H: odd number of bits under H_BYTE_PARITY_CHECK and H_BYTE_PARITY_INVERT
// Pixel Byte L: even number of bits under L_BYTE_PARITY_CHECK and L_BYTE_PARITY_INVERT
//                                          H:RRRRRGGG
const uint8_t H_BYTE_PARITY_CHECK =  0b00100000;
const uint8_t H_BYTE_PARITY_INVERT = 0b00001000;
//                                          L:GGGBBBBB
const uint8_t L_BYTE_PARITY_CHECK =  0b00001000;
const uint8_t L_BYTE_PARITY_INVERT = 0b00100000;
// Since the parity for L byte can be zero we must ensure that the total byet value is above zero.
// Increasing the lowest bit of blue color is OK for that.
const uint8_t L_BYTE_PREVENT_ZERO  = 0b00000001;
const uint16_t COLOR_GREEN = 0x07E0;
const uint16_t COLOR_RED = 0xF800;
void processGrayscaleFrameBuffered();
void processGrayscaleFrameDirect();
void processRgbFrameBuffered();
void processRgbFrameDirect();
typedef void (*ProcessFrameData)(void) ;
#if UART_MODE==1
const uint16_t lineLength = 160;
const uint16_t lineCount = 120;
const uint32_t baud  = 115200;
const ProcessFrameData processFrameData = processRgbFrameBuffered;
const uint16_t lineBufferLength = lineLength * 2;
const bool isSendWhileBuffering = true;
const uint8_t uartPixelFormat = UART_PIXEL_FORMAT_RGB565;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_RGB565, 34);
#endif
#if UART_MODE==2
const ProcessFrameData processFrameData = processGrayscaleFrameBuffered;
const uint16_t lineBufferLength = lineLength;
const uint8_t uartPixelFormat = UART_PIXEL_FORMAT_GRAYSCALE;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_YUV422, 17);
#endif
#if UART_MODE==3
const uint32_t baud  = 500000;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_RGB565, 8);
#endif
#if UART_MODE==4
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_YUV422, 4);
#endif
#if UART_MODE==5
const uint16_t lineLength = 320;
const uint16_t lineCount = 240;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_RGB565, 32);
#endif
#if UART_MODE==6
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_YUV422, 16);
#endif
#if UART_MODE==7
const uint32_t baud  = 1000000;
const bool isSendWhileBuffering = false;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_RGB565, 5);
#endif
#if UART_MODE==8
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_YUV422, 2);
#endif
#if UART_MODE==9
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_RGB565, 16);
#endif
#if UART_MODE==10
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_YUV422, 8);
#endif
#if UART_MODE==11
const uint16_t lineLength = 640;
const uint16_t lineCount = 480;
const ProcessFrameData processFrameData = processGrayscaleFrameDirect;
const uint16_t lineBufferLength = 1;
CameraOV7670 camera(CameraOV7670::RESOLUTION_VGA_640x480, CameraOV7670::PIXEL_YUV422, 39);
#endif
#if UART_MODE==12
const uint32_t baud  = 2000000;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_RGB565, 2);
#endif
#if UART_MODE==13
#endif
#if UART_MODE==14
const uint32_t baud  = 2000000; // may be unreliable
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_RGB565, 12);
#endif
#if UART_MODE==15
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_YUV422, 6);
#endif
#if UART_MODE==16
const ProcessFrameData processFrameData = processRgbFrameDirect;
CameraOV7670 camera(CameraOV7670::RESOLUTION_VGA_640x480, CameraOV7670::PIXEL_RGB565, 39);
#endif
#if UART_MODE==17
CameraOV7670 camera(CameraOV7670::RESOLUTION_VGA_640x480, CameraOV7670::PIXEL_YUV422, 19);
#endif
uint8_t lineBuffer [lineBufferLength]; // Two bytes per pixel
uint8_t * lineBufferSendByte;
bool isLineBufferSendHighByte;
bool isLineBufferByteFormatted;
uint16_t frameCounter = 0;
uint16_t processedByteCountDuringCameraRead = 0;
void commandStartNewFrame(uint8_t pixelFormat);
void commandDebugPrint(const String debugText);
uint8_t sendNextCommandByte(uint8_t checksum, uint8_t commandByte);
void sendBlankFrame(uint16_t color);
inline void processNextGrayscalePixelByteInBuffer() __attribute__((always_inline));
inline void processNextRgbPixelByteInBuffer() __attribute__((always_inline));
inline void tryToSendNextRgbPixelByteInBuffer() __attribute__((always_inline));
inline void formatNextRgbPixelByteInBuffer() __attribute__((always_inline));
inline uint8_t formatRgbPixelByteH(uint8_t byte) __attribute__((always_inline));
inline uint8_t formatRgbPixelByteL(uint8_t byte) __attribute__((always_inline));
inline uint8_t formatPixelByteGrayscaleFirst(uint8_t byte) __attribute__((always_inline));
inline uint8_t formatPixelByteGrayscaleSecond(uint8_t byte) __attribute__((always_inline));
inline void waitForPreviousUartByteToBeSent() __attribute__((always_inline));
inline bool isUartReady() __attribute__((always_inline));
// this is called in Arduino setup() function
void initializeScreenAndCamera() {
  // Enable this for WAVGAT CPUs
  // For UART communiation we want to set WAVGAT Nano to 16Mhz to match Atmel based Arduino
  //CLKPR = 0x80; // enter clock rate change mode
  //CLKPR = 1; // set prescaler to 1. WAVGAT MCU has it 3 by default.
  Serial.begin(baud);
  if (camera.init()) {
    sendBlankFrame(COLOR_GREEN);
    sendBlankFrame(COLOR_RED);
    delay(3000);
void sendBlankFrame(uint16_t color) {
  uint8_t colorH = (color >> 8) & 0xFF;
  uint8_t colorL = color & 0xFF;
  commandStartNewFrame(UART_PIXEL_FORMAT_RGB565);
  for (uint16_t j=0; j<lineCount; j++) {
    for (uint16_t i=0; i<lineLength; i++) {
      waitForPreviousUartByteToBeSent();
      UDR0 = formatRgbPixelByteH(colorH);
      UDR0 = formatRgbPixelByteL(colorL);
// this is called in Arduino loop() function
void processFrame() {
  commandStartNewFrame(uartPixelFormat);
  noInterrupts();
  processFrameData();
  interrupts();
  frameCounter++;
  commandDebugPrint("Frame " + String(frameCounter)/* + " " + String(processedByteCountDuringCameraRead)*/);
  //commandDebugPrint("Frame " + String(frameCounter, 16)); // send number in hexadecimal
void processGrayscaleFrameBuffered() {
  camera.waitForVsync();
  commandDebugPrint("Vsync");
  camera.ignoreVerticalPadding();
  for (uint16_t y = 0; y < lineCount; y++) {
    lineBufferSendByte = &lineBuffer[0];
    camera.ignoreHorizontalPaddingLeft();
    uint16_t x = 0;
    while ( x < lineBufferLength) {
      camera.waitForPixelClockRisingEdge(); // YUV422 grayscale byte
      camera.readPixelByte(lineBuffer[x]);
      lineBuffer[x] = formatPixelByteGrayscaleFirst(lineBuffer[x]);
      camera.waitForPixelClockRisingEdge(); // YUV422 color byte. Ignore.
      if (isSendWhileBuffering) {
        processNextGrayscalePixelByteInBuffer();
      x++;
      lineBuffer[x] = formatPixelByteGrayscaleSecond(lineBuffer[x]);
      x++;
    camera.ignoreHorizontalPaddingRight();
    // Debug info to get some feedback how mutch data was processed during line read.
    processedByteCountDuringCameraRead = lineBufferSendByte - (&lineBuffer[0]);
    // Send rest of the line
    while (lineBufferSendByte < &lineBuffer[lineLength]) {
void processNextGrayscalePixelByteInBuffer() {
  if (isUartReady()) {
    UDR0 = *lineBufferSendByte;
    lineBufferSendByte++;
void processGrayscaleFrameDirect() {
    uint16_t x = 0;
    while ( x < lineLength) {
      camera.readPixelByte(lineBuffer[0]);
      lineBuffer[0] = formatPixelByteGrayscaleFirst(lineBuffer[0]);
      UDR0 = lineBuffer[0];
      x++;
      lineBuffer[0] = formatPixelByteGrayscaleSecond(lineBuffer[0]);
      x++;
uint8_t formatPixelByteGrayscaleFirst(uint8_t pixelByte) {
  // For the First byte in the parity chek byte pair the last bit is always 0.
  pixelByte &= 0b11111110;
  if (pixelByte == 0) {
    // Make pixel color always slightly above 0 since zero is a command marker.
    pixelByte |= 0b00000010;
  return pixelByte;
uint8_t formatPixelByteGrayscaleSecond(uint8_t pixelByte) {
  // For the second byte in the parity chek byte pair the last bit is always 1.
  return pixelByte | 0b00000001;
void processRgbFrameBuffered() {
    isLineBufferSendHighByte = true; // Line starts with High byte
    isLineBufferByteFormatted = false;
    for (uint16_t x = 0; x < lineBufferLength;  x++) {
        processNextRgbPixelByteInBuffer();
    // send rest of the line
    while (lineBufferSendByte < &lineBuffer[lineLength * 2]) {
void processNextRgbPixelByteInBuffer() {
  // Format pixel bytes and send out in different cycles.
  // There is not enough time to do both on faster frame rates.
  if (isLineBufferByteFormatted) {
    tryToSendNextRgbPixelByteInBuffer();
    formatNextRgbPixelByteInBuffer();
void tryToSendNextRgbPixelByteInBuffer() {
void formatNextRgbPixelByteInBuffer() {
  if (isLineBufferSendHighByte) {
    *lineBufferSendByte = formatRgbPixelByteH(*lineBufferSendByte);
    *lineBufferSendByte = formatRgbPixelByteL(*lineBufferSendByte);
  isLineBufferByteFormatted = true;
  isLineBufferSendHighByte = !isLineBufferSendHighByte;
void processRgbFrameDirect() {
    for (uint16_t x = 0; x < lineLength; x++) {
      lineBuffer[0] = formatRgbPixelByteH(lineBuffer[0]);
      lineBuffer[0] = formatRgbPixelByteL(lineBuffer[0]);
// RRRRRGGG
uint8_t formatRgbPixelByteH(uint8_t pixelByteH) {
  // Make sure that
  // A: pixel color always slightly above 0 since zero is end of line marker
  // B: odd number of bits for H byte under H_BYTE_PARITY_CHECK and H_BYTE_PARITY_INVERT to enable error correction
  if (pixelByteH & H_BYTE_PARITY_CHECK) {
    return pixelByteH & (~H_BYTE_PARITY_INVERT);
    return pixelByteH | H_BYTE_PARITY_INVERT;
// GGGBBBBB
uint8_t formatRgbPixelByteL(uint8_t pixelByteL) {
  // Make sure that
  // B: even number of bits for L byte under L_BYTE_PARITY_CHECK and L_BYTE_PARITY_INVERT to enable error correction
  if (pixelByteL & L_BYTE_PARITY_CHECK) {
    return pixelByteL | L_BYTE_PARITY_INVERT | L_BYTE_PREVENT_ZERO;
    return (pixelByteL & (~L_BYTE_PARITY_INVERT)) | L_BYTE_PREVENT_ZERO;
void commandStartNewFrame(uint8_t pixelFormat) {
  UDR0 = 0x00; // New command
  UDR0 = 4; // Command length
  uint8_t checksum = 0;
  checksum = sendNextCommandByte(checksum, COMMAND_NEW_FRAME);
  checksum = sendNextCommandByte(checksum, lineLength & 0xFF); // lower 8 bits of image width
  checksum = sendNextCommandByte(checksum, lineCount & 0xFF); // lower 8 bits of image height
      ((lineLength >> 8) & 0x03) // higher 2 bits of image width
      | ((lineCount >> 6) & 0x0C) // higher 2 bits of image height
      | ((pixelFormat << 4) & 0xF0));
  UDR0 = checksum;
void commandDebugPrint(const String debugText) {
  if (debugText.length() > 0) {
    UDR0 = 0x00; // New commnad
    UDR0 = debugText.length() + 1; // Command length. +1 for command code.
    checksum = sendNextCommandByte(checksum, COMMAND_DEBUG_DATA);
    for (uint16_t i=0; i<debugText.length(); i++) {
      checksum = sendNextCommandByte(checksum, debugText[i]);
    UDR0 = checksum;
uint8_t sendNextCommandByte(uint8_t checksum, uint8_t commandByte) {
  UDR0 = commandByte;
  return checksum ^ commandByte;
void waitForPreviousUartByteToBeSent() {
  while(!isUartReady()); //wait for byte to transmit
bool isUartReady() {
  return UCSR0A & (1<<UDRE0);
#endif
There is also this GrayScaleTable file included:
// Created by indrek on 1.12.2016.
#ifndef LIVEOV7670_GRAYSCALETABLE_H
#define LIVEOV7670_GRAYSCALETABLE_H
const uint8_t graysScaleTableHigh[] = {
    0x00,
    0x00,
    0x00,
    0x00,
    0x00,
    0x00,
    0x00,
    0x00,
    0x08,
    0x08,
    0x08,
    0x08,
    0x08,
    0x08,
    0x08,
    0x08,
    0x10,
    0x10,
    0x10,
    0x10,
    0x10,
    0x10,
    0x10,
    0x10,
    0x18,
    0x18,
    0x18,
    0x18,
    0x18,
    0x18,
    0x18,
    0x18,
    0x21,
    0x21,
    0x21,
    0x21,
    0x21,
    0x21,
    0x21,
    0x21,
    0x29,
    0x29,
    0x29,
    0x29,
    0x29,
    0x29,
    0x29,
    0x29,
    0x31,
    0x31,
    0x31,
    0x31,
    0x31,
    0x31,
    0x31,
    0x31,
    0x39,
    0x39,
    0x39,
    0x39,
    0x39,
    0x39,
    0x39,
    0x39,
    0x42,
    0x42,
    0x42,
    0x42,
    0x42,
    0x42,
    0x42,
    0x42,
    0x4A,
    0x4A,
    0x4A,
    0x4A,
    0x4A,
    0x4A,
    0x4A,
    0x4A,
    0x52,
    0x52,
    0x52,
    0x52,
    0x52,
    0x52,
    0x52,
    0x52,
    0x5A,
    0x5A,
    0x5A,
    0x5A,
    0x5A,
    0x5A,
    0x5A,
    0x5A,
    0x63,
    0x63,
    0x63,
    0x63,
    0x63,
    0x63,
    0x63,
    0x63,
    0x6B,
    0x6B,
    0x6B,
    0x6B,
    0x6B,
    0x6B,
    0x6B,
    0x6B,
    0x73,
    0x73,
    0x73,
    0x73,
    0x73,
    0x73,
    0x73,
    0x73,
    0x7B,
    0x7B,
    0x7B,
    0x7B,
    0x7B,
    0x7B,
    0x7B,
    0x7B,
    0x84,
    0x84,
    0x84,
    0x84,
    0x84,
    0x84,
    0x84,
    0x84,
    0x8C,
    0x8C,
    0x8C,
    0x8C,
    0x8C,
    0x8C,
    0x8C,
    0x8C,
    0x94,
    0x94,
    0x94,
    0x94,
    0x94,
    0x94,
    0x94,
    0x94,
    0x9C,
    0x9C,
    0x9C,
    0x9C,
    0x9C,
    0x9C,
    0x9C,
    0x9C,
    0xA5,
    0xA5,
    0xA5,
    0xA5,
    0xA5,
    0xA5,
    0xA5,
    0xA5,
    0xAD,
    0xAD,
    0xAD,
    0xAD,
    0xAD,
    0xAD,
    0xAD,
    0xAD,
    0xB5,
    0xB5,
    0xB5,
    0xB5,
    0xB5,
    0xB5,
    0xB5,
    0xB5,
    0xBD,
    0xBD,
    0xBD,
    0xBD,
    0xBD,
    0xBD,
    0xBD,
    0xBD,
    0xC6,
    0xC6,
    0xC6,
    0xC6,
    0xC6,
    0xC6,
    0xC6,
    0xC6,
    0xCE,
    0xCE,
    0xCE,
    0xCE,
    0xCE,
    0xCE,
    0xCE,
    0xCE,
    0xD6,
    0xD6,
    0xD6,
    0xD6,
    0xD6,
    0xD6,
    0xD6,
    0xD6,
    0xDE,
    0xDE,
    0xDE,
    0xDE,
    0xDE,
    0xDE,
    0xDE,
    0xDE,
    0xE7,
    0xE7,
    0xE7,
    0xE7,
    0xE7,
    0xE7,
    0xE7,
    0xE7,
    0xEF,
    0xEF,
    0xEF,
    0xEF,
    0xEF,
    0xEF,
    0xEF,
    0xEF,
    0xF7,
    0xF7,
    0xF7,
    0xF7,
    0xF7,
    0xF7,
    0xF7,
    0xF7,
    0xFF,
    0xFF,
    0xFF,
    0xFF,
    0xFF,
    0xFF,
    0xFF,
    0xFF,
uint8_t graysScaleTableLow[] = {
    0x00,
    0x00,
    0x00,
    0x00,
    0x20,
    0x20,
    0x20,
    0x20,
    0x41,
    0x41,
    0x41,
    0x41,
    0x61,
    0x61,
    0x61,
    0x61,
    0x82,
    0x82,
    0x82,
    0x82,
    0xA2,
    0xA2,
    0xA2,
    0xA2,
    0xC3,
    0xC3,
    0xC3,
    0xC3,
    0xE3,
    0xE3,
    0xE3,
    0xE3,
    0x04,
    0x04,
    0x04,
    0x04,
    0x24,
    0x24,
    0x24,
    0x24,
    0x45,
    0x45,
    0x45,
    0x45,
    0x65,
    0x65,
    0x65,
    0x65,
    0x86,
    0x86,
    0x86,
    0x86,
    0xA6,
    0xA6,
    0xA6,
    0xA6,
    0xC7,
    0xC7,
    0xC7,
    0xC7,
    0xE7,
    0xE7,
    0xE7,
    0xE7,
    0x08,
    0x08,
    0x08,
    0x08,
    0x28,
    0x28,
    0x28,
    0x28,
    0x49,
    0x49,
    0x49,
    0x49,
    0x69,
    0x69,
    0x69,
    0x69,
    0x8A,
    0x8A,
    0x8A,
    0x8A,
    0xAA,
    0xAA,
    0xAA,
    0xAA,
    0xCB,
    0xCB,
    0xCB,
    0xCB,
    0xEB,
    0xEB,
    0xEB,
    0xEB,
    0x0C,
    0x0C,
    0x0C,
    0x0C,
    0x2C,
    0x2C,
    0x2C,
    0x2C,
    0x4D,
    0x4D,
    0x4D,
    0x4D,
    0x6D,
    0x6D,
    0x6D,
    0x6D,
    0x8E,
    0x8E,
    0x8E,
    0x8E,
    0xAE,
    0xAE,
    0xAE,
    0xAE,
    0xCF,
    0xCF,
    0xCF,
    0xCF,
    0xEF,
    0xEF,
    0xEF,
    0xEF,
    0x10,
    0x10,
    0x10,
    0x10,
    0x30,
    0x30,
    0x30,
    0x30,
    0x51,
    0x51,
    0x51,
    0x51,
    0x71,
    0x71,
    0x71,
    0x71,
    0x92,
    0x92,
    0x92,
    0x92,
    0xB2,
    0xB2,
    0xB2,
    0xB2,
    0xD3,
    0xD3,
    0xD3,
    0xD3,
    0xF3,
    0xF3,
    0xF3,
    0xF3,
    0x14,
    0x14,
    0x14,
    0x14,
    0x34,
    0x34,
    0x34,
    0x34,
    0x55,
    0x55,
    0x55,
    0x55,
    0x75,
    0x75,
    0x75,
    0x75,
    0x96,
    0x96,
    0x96,
    0x96,
    0xB6,
    0xB6,
    0xB6,
    0xB6,
    0xD7,
    0xD7,
    0xD7,
    0xD7,
    0xF7,
    0xF7,
    0xF7,
    0xF7,
    0x18,
    0x18,
    0x18,
    0x18,
    0x38,
    0x38,
    0x38,
    0x38,
    0x59,
    0x59,
    0x59,
    0x59,
    0x79,
    0x79,
    0x79,
    0x79,
    0x9A,
    0x9A,
    0x9A,
    0x9A,
    0xBA,
    0xBA,
    0xBA,
    0xBA,
    0xDB,
    0xDB,
    0xDB,
    0xDB,
    0xFB,
    0xFB,
    0xFB,
    0xFB,
    0x1C,
    0x1C,
    0x1C,
    0x1C,
    0x3C,
    0x3C,
    0x3C,
    0x3C,
    0x5D,
    0x5D,
    0x5D,
    0x5D,
    0x7D,
    0x7D,
    0x7D,
    0x7D,
    0x9E,
    0x9E,
    0x9E,
    0x9E,
    0xBE,
    0xBE,
    0xBE,
    0xBE,
    0xDF,
    0xDF,
    0xDF,
    0xDF,
    0xFF,
    0xFF,
    0xFF,
    0xFF,
#endif //LIVEOV7670_GRAYSCALETABLE_H
And this is the main .ino script:
// change setup.h to switch between buffered and pixel-by-pixel processing
#include "setup.h"
  // This is not necessary and has no effect for ATMEGA based Arduinos.
  // WAVGAT Nano has slower clock rate by default. We want to reset it to maximum speed
  CLKPR = 0; // set prescaler to 0. WAVGAT MCU has it 3 by default.
  initializeScreenAndCamera();
  processFrame();
