I want to be able to turn the TPS7A7002 regulator on and off using a pin from my Uno using the ENable pin on the regulator. I want the regulator to have a 5 volt input, and a fixed 3.3 volt output. Does this sound possible, and if so, how do I do that?
Are you reading the datasheet?
Citing from the document:
EN - Enable input. Pulling this pin to less than 0.5 V turns the regulator off. Connect to VIN if not
being used.
If you read this - what is your question?
That is my question. I already know how to use the EN pin. People on the forum keep telling me to include more info in my questions, so that's why I was explaining what I was trying to do.
Read the datasheet is that easy.. You got a formula on the first page about two resistors, for setting the output voltage.
yes, it possible
From the document:
- Input Voltage as Low as 1.425 V
• 380-mV Maximum Dropout at 2 A
• 600-mV Maximum Dropout at 3 A
• Adjustable Output from 0.5 V
You should to learn read datasheets yourself if you plan to go further in electronics
So R1 should be 110k, and R2 should be 20k? That gives me 3.25 volts. Is that close enough? I have noticed that the 3.3v out of my Uno is sometimes lower than that.
Please do not overflow the forum with questions, first learn something...
Isn't that the point of the forum? I wouldn't ask if I knew, obviously.
The point of this forum isn't to inform everyone what I had for breakfast...
You can add 2 resistor in series to get closer to 3V3.
AND please do not try to answer in any and every thread... First think then write...
Ah, yes. I will have to. My calculations suggest that R2 should be 19.6k, so two resistors will have to be used.
Table 2 in page 9 of the datasheet contains the examples of resistors values for the most popular cases including 3v3
Warning taken and heeded.
According to the table @b707 kindly pointed out, I will actually need a 30.1k, and a 169 k resistor! But that is also easy to substitute: 30k + 100 ohm = 30.1k and 120k + 47k + 2k = 169k.
Both 30.1k and 169k are available in SMD.
you can take 30k and 100k + 68k - it give you exactly 3.3v
Oh. Well I was trying to follow the datasheet at your suggestion...
the exact values don't matter, only the ratio matters
Ah, I see.
