Hello all. I was trying to replicate the wall in the show Stranger things, where there are 26 lights, and under each light is a letter. I wanted to pre-program it with my arduino uno to control each led to flash, and do pre programmed light sequences like have the lights flash R U N, and other things from the show. But, I only have 13 pins on the arduino. Does anyone know how to combine two arduinos or control double the LEDs with only 13 pins?
Here's a good introduction to NeoPixels:
Start there. Potentially, 1 pin to meet all your needs.
Search "arduino word clock" for lighting sequences and adding to @camsysca reply, search "APA106 RGB strand" for your "Christmas lights" effect.
For the Word Search...
For the Word Wall...
The MAX7219 multiplexing chip can control up to 64 LEDs.
You will need to layout the required LEDs in a matrix fashion. -
The NeoPixel suggestion gives you the option to control the pixel colours.
Only one (1) Arduino GPIO pin is needed to talk to the LED string.
Using more than one Arduino is almost always a mistake, but it seems to be suggested a lot by beginners. This is because they normally have little knowledge of electronics.
This used to be a very common request when the series first started, so do a forum search to find them, like the other contributors have done.
I agree - my analogy is trying to harness a dozen Shetland ponies when what you need is a Clydesdale. Getting reliable communication between multiple processors right is a non trivial exercise.
