Submarine control - Steering servo motors and Motor contollers
zoomkat:
I assume you already have an arduino, multimeter, breadboard, jumpers, power supplies, etc. to support your project. That being said, I suggest you get a couple of the below servos and modify for continuous rotation (very easy), and the below joysticks, and start experimenting to verify your joystick control concept. I doubt anyone in the forum has built what you plan, so reading DIY ROV sites will probably provide info that you need.
http://www.hobbyking.com/hobbyking/store/__3743__HXT_6_9kg_39_2g_16sec_Twin_bearing_servo.html
http://www.ebay.com/itm/3-X-New-Handle-Joystick-3D-for-Sony-Playstation2-PS2-PS-2-10V-/230803703512?hash=item35bcf906d8
rov build - Google Search
Hi Guys,
Thanks for the help.
at this stage the application isnt really an issue (submarine, steering of a car, aerlons on a plane, the movement of the existing servo through the 180 degree rotation controlled by a thumb joystick is the convern.
I figure from what I have been told i use an Arduino Uno with two single axis joysticks (similar to the remote control game board that arduino do). WHat I need to know is, other than this, what do I need-
  1. power supply? what do you use - I will just have 3 large deep cycle batteries, but what do you guys use or reccomend.
  2. what other support boards/hardware do I need.
  3. where do I get single axis thrumb joysticks like the one on the hand held game remote?
Regards.
Mike
Hi Guys,
Regards.
Mike
  1. Sounds good to me. Lead-acid have a low power density, but that may be adequate for you needs. You need to determine your motor amp draw and use the amp-hour capacity of your proposed battery to see if it meets your requirements. Moving up, you can go to NiCd/NiMH, and if that's still not enough, there's Li-ion and LiPo.
  2. Hard to answer, don't know everything you want to do?
  3. single axis joystick - Google Search turns up lots of hits?
I'd just get some joystick pots like below and just use the axis desired as you don't have to use both.
