I have a Nema 34 3 phase, bipolar, 3 wire stepper motor that has a drive voltage 220v I'm assuming is AC. Has holding torque of 5nm, and current is 3.0 amp.
I have the correct driver ( due to arrive in the post any day soon) What I don't have is a controller, or any idea what controller I should have.
The primary function of the stepper is to drive a linear motion guide from left to right then right to left continuously. I need to adjust the speed, it needs to be low speed. I have two limit switches. Any help would be much appreciated
Stephenstroudnz:
I don't have an actual data sheet, that is all the data I have
Without seeing the datasheet I have no basis for offering advice. If you are sure you have the correct driver then post a link to the datasheet for the driver.
From your link;
Model No.: FLS120L60010C7
Certification: FCC, ISO, CE, Other
IP Rating: IP65
Limit Switch: Without Voltage: 24VDC
Standard Stroke: Other
Max Thrust: Other
Ballscrew Type: G1610
Positioning Accuracy: 0.05mm
Max Speed: 300mm/s
Normal Load Capacity(kgs): 100kgs
Axial Load Capacity(kgs): 50kgs
Motor Type: 3-phase Nema 34 Stepper Motor
