Sunday afternoon project, my first robot
This is my first real Arduino project. I was amazed how simple it was all this is what I create in a sunday afternoon.
I created a robot with 3 ir sensors and a sonar on a servo.
Here is a part list:
Base plate inc motors 16 euro
Arduino 8 euro
Left and right IR sensor, 3,50 euro a piece (these are rated for 10-30 volt, but still works at 5 volt just fine)
Mid IR sensor 4 euro
Sonar sensor 5 euro
mini servo 3,50 euro
motor shield 12 euro
protoshield 4 euro
RF1100-232 transciever 433mhz 8 euro
Ok it's still messy, just a first prototype:
I can't find many example robot codes on the net, so I post mine here, still it need some work on the sonar sensor part en servo.
This is my fist code, so comments are more then welcome on the code:
//Robot Code
// servo
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int pos = 0;    // variable to store the servo position
// sonar code, mostly taken from luckylarry.co.uk
const int numOfReadings = 5;                   // number of readings to take/ items in the array
int readings[numOfReadings];                    // stores the distance readings in an array
int arrayIndex = 0;                             // arrayIndex of the current item in the array
int total = 0;                                  // stores the cumlative total
int averageDistance = 0;                        // stores the average value
// setup pins and variables for SRF05 sonar device
int echoPin = 2;                                // SRF05 echo pin (digital 2)
int initPin = 3;                                // SRF05 trigger pin (digital 3)
unsigned long pulseTime = 0;                    // stores the pulse in Micro Seconds
unsigned long distance = 0;                     // variable for storing the distance (cm)
//Arduino PWM Speed Control based upon code from dfrobot[ch65306]
const int E1 = 6;
const int M1 = 7;
const int E2 = 5;
const int M2 = 4;
//IR sensors
const int IRsensorFm = 2;     // pin that the FRONT middle sensor is attached to
const int IRsensorFl = 1;     // pin that the FRONT left sensor is attached to
const int IRsensorFr = 0;     // pin that the FRONT right sensor is attached to
int sensorValue = 0;
// LED pin
const int ledPin =  13;
    myservo.attach(11);  // attaches the servo on pin 11 to the servo object
    pinMode(initPin, OUTPUT);                     // set init pin 3 as output
    pinMode(echoPin, INPUT);                      // set echo pin 2 as input
    pinMode(M1, OUTPUT);
    pinMode(M2, OUTPUT);
    pinMode (IRsensorFm, INPUT);
    pinMode (IRsensorFl, INPUT);
    pinMode (IRsensorFr, INPUT);
    pinMode(ledPin, OUTPUT);
    digitalWrite(ledPin, LOW);
    // open the serial port:
    Serial.begin(19200);
    Serial.println("I am alive!");
  // create array loop to iterate over every item in the array
  for (int thisReading = 0; thisReading < numOfReadings; thisReading++) {
readings[thisReading] = 0;
  //myservo.write(45);              // tell servo to go to position in variable 'pos'
  //delay(1000);
  digitalWrite(initPin, HIGH);                    // send 10 microsecond pulse
  delayMicroseconds(10);                  // wait 10 microseconds before turning off
  digitalWrite(initPin, LOW);                     // stop sending the pulse
  pulseTime = pulseIn(echoPin, HIGH);             // Look for a return pulse, it should be high as the pulse goes low-high-low
  distance = pulseTime/58;                        // Distance = pulse time / 58 to convert to cm.
  total= total - readings[arrayIndex];           // subtract the last distance
  readings[arrayIndex] = distance;                // add distance reading to array
  total= total + readings[arrayIndex];            // add the reading to the total
  arrayIndex = arrayIndex + 1;                    // go to the next item in the array
  // At the end of the array (10 items) then start again
  if (arrayIndex >= numOfReadings)  {
    arrayIndex = 0;
  averageDistance = total / numOfReadings;      // calculate the average distance
  // if the distance is less than xx then change direction
  if (averageDistance < 30) {
    turnleft(200);
  Serial.println(averageDistance, DEC);
  // while the front sensor reading is low
  if (analogRead(IRsensorFm) <= 300) {
  sensorValue = analogRead(IRsensorFm);
  //Serial.println(sensorValue);
  digitalWrite(ledPin, HIGH);
  stopmoter(1000);
  backwards(400);
  turnleft(800);
  stopmoter(1000);
  // while the front left sensor reading is low
  else if (analogRead(IRsensorFl) <= 300) {
  stopmoter(1000);
  backwards(400);
  stopmoter(100);
  turnright(400);
  stopmoter(1000);
  // while the front right sensor reading is low
  else if (analogRead(IRsensorFr) <= 300) {
  stopmoter(1000);
  backwards(400);
  stopmoter(100);
  turnleft(400);
  stopmoter(1000);
  else {
  forward();  // No obstacle detected, so move forward
  //myservo.write(165);              // tell servo to go to position in variable 'pos'
  //delay(1000);
void forward() {
  // turn on motor forward
  digitalWrite(M1,HIGH);
  digitalWrite(M2, LOW);
  analogWrite(E1, 140);   //PWM Speed Control
  analogWrite(E2, 140);   //PWM Speed Control
void backwards(int time) {
  // turn on motor backwards
  digitalWrite(M1,LOW);
  digitalWrite(M2, HIGH);
  analogWrite(E1, 120);   //PWM Speed Control
  analogWrite(E2, 120);   //PWM Speed Control
  Serial.println("Backwards");
  delay(time);
void stopmoter(int time) {
  analogWrite(E1, 0);   //PWM Speed Control
  analogWrite(E2, 0);   //PWM Speed Control
  Serial.println("Stop");
  delay(time);
void turnleft(int time) {
  analogWrite(E1, 150);   //PWM Speed Control
  analogWrite(E2, 150);   //PWM Speed Control
  Serial.println("turnleft");
  delay(time);
void turnright(int time) {
  Serial.println("turnright");
  delay(time);
Now I was inspired to make a robot like this at the side of my balancing robot. :slight_smile:
