Hello, i have a project and i use a lot of switches on/off my project. But i want to control a switch all modules. Maybe i can't corretly explain, please look at the pictures. Thank you.
You are not "controlling" with your new switch. You are DISABLING the entire project. Is that what you want?
Paul
I want to use only one switch and control more sensor modules (four) power on/off. Can i do it ?
You can use 6 pin switches like these to open/close 3 circuits at the same time:
Also if those circles are your load then you don't really need the third connection because disconnecting the batteries will turn off everything.
pourduino:
Thanks ![]()
Do you need a separate battery for each module?
What is the module?
Tom... ![]()
TomGeorge:
What is the module?Tom...
Yes i need it. Sensor modules for example mq-4 CH4, CO, CO2, O3 etc.
Diagram 2 would make more sense, less hardware, and you could keep your Lipo batteries in one spot for charging.
You will need more than one 18650, how long do you want to it to run on batteries?
Tom.... ![]()
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
@BallScrewBob,
What happened to the cool yellow submarine ?
raschemmel:
@BallScrewBob,
Major machine crash and base machine change due to power spikes (multiple)
You mean like the one that lost my account and all my STATs ?
Did you need counseling ?
If it's any consolation I think I saved a copy of it on my MSI Laptop desktop.
I'll post it here when I get home because I can't send it via PM.
