TB6612FNG via Bluetooth
Hi there,i am posting here in Motor Section hoping to get a answer...i have allready ask for help in Bluetooth comunicaction Section but i didn't get the answer...i don't know what to do..please help me
Using KAS Android Bluetooth Joystick aplication i am triyng to control a RC car,modifying it and hook up a servo for steering (Horizontal Axis) ,and a DC Motor with TB6612FNG (on Vertical Axis) ...so i took the code and modifying it :
I will try to explain it the clear as possible so can everybody understand it:
The Android aplicacion send to the Arduino via HC-06 the Joystick position.
Using this code now the Servo move as it should (Horizontal Axis) ,
The DC Motor (Vertical Axis of joystick) work both directions FWD /BACKWRD, goes to StandBy when the joystick is in middle , BUT it moves very slow....on the Serial Monitor it goes from -255 0 255 exactly how i move the joystick
#include <Servo.h>
boolean    DEBUG = true;
#define    pinServo_X     9
#define    PWM_Y          3
#define    STX            0x02
#define    ETX            0x03
#define    MAX_Y          255      // PWM limit
#define    ZERO_Y         0
#define    MIN_Y          -255
#define AIN1  4
#define AIN2  5   // AIN1 and AIN2 as Direction pins
#define STBY  7   // StandBy
int i=0;
byte cmd[6] = {0, 0, 0, 0, 0, 0};
Servo myservoX;
Servo myY;                 // ???? it is not a servo
byte buttonStatus = 0;
byte dataByte = 0;
long previousMillis = 0;
boolean setButtonFeedback = false;
long interval = 1000;
void setup()  {
  myservoX.attach(pinServo_X);
  myY.attach(PWM_Y);
pinMode(AIN1,OUTPUT);
pinMode(AIN2,OUTPUT);
pinMode(PWM_Y,OUTPUT);
pinMode(STBY,OUTPUT);
  if(Serial.available())  {                   // data received from smartphone
    delay(5);
    cmd[0] =  Serial.read();
    if(cmd[0] == STX)  {
      i=1;
      while(Serial.available())  {
        cmd[i] = Serial.read();
        if(cmd[i] == ETX)  {
          if(i==2 && cmd[1]>48)                break;    // Button data
          if(i==5 && cmd[1]<3 && cmd[3]<3)     break;    // Joystick data
        if(i>5)   break;
        i++;
        if(i==5)   setServoPosition(cmd);                                     // 5 Bytes
      else            Serial.println("Communication error");
  }  else  {
    long currentMillis = millis();
    if(setButtonFeedback == true)  {                      // allow momentary button visual effect (500 ms)
      previousMillis = currentMillis - interval*0.5;
  delay(5);
void setServoPosition(byte data[5])    {
  int joyX = (data[1]<<7) + data[2];
  int joyY = (data[3]<<7) + data[4];
  joyX = joyX - 200;                         // Offset to avoid
  joyY = joyY - 200;                         // transmitting negative numbers
  joyX = map(joyX, -180, 180, 180, 0);      // (-180/+180 JBC range)
  joyY = map(joyY,  -100, +100, -255, 255);
  joyY+=ZERO_Y;
  joyY = constrain(joyY, MIN_Y, MAX_Y);
  myservoX.write(joyX);
  myY.write(joyY);
  digitalWrite(STBY, HIGH); //disable standby
  if(DEBUG)  {
  //Serial.print(joyX); Serial.print(", ");
  Serial.println(joyY);}
  if(joyY > 0)	{
      digitalWrite (AIN1,HIGH);
      digitalWrite (AIN2,LOW);
  } else if(joyY < 0)  {
      digitalWrite (AIN1,LOW);
      digitalWrite (AIN2,HIGH);
  } else if(joyY == 0)  {
      digitalWrite(STBY, LOW); //enable standby
  analogWrite(PWM_Y,joyY);
I would reay apreciate if you can help me with the code,Thank you
