TCP/IP barcode scanner
I would like to connect a TCP/IP enabled barcode scanner to an arduino to be able to read and display scanned codes.
Already did it with a RS232 one, any suggestion will be more than welcome.
do you have a link to a documentation for the scanner?
what networking shield/module do you plan to use?
It is cognex dm8072-dl with base
Thanks
it uses Modbus TCP. that is simple to read but you need the documentation for the Modbus addresses
here I have an Arduino project which uses Modbus TCP with Ethernet library.
