Hi all, I have a few questions regarding the TCS3200 sensor from DFRobot.
I am doing a project that uses the to determine the health of leaves and plants. I have done my calibration with the following code
// Define color sensor pins
#define S0 4
#define S1 5
#define S2 6
#define S3 7
#define sensorOut 8
// Variables for Color Pulse Width Measurements
int redPW = 0;
int greenPW = 0;
int bluePW = 0;
// Set S0 - S3 as outputs
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
// Set Sensor output as input
pinMode(sensorOut, INPUT);
// Set Pulse Width scaling to 20%
digitalWrite(S0,HIGH);
digitalWrite(S1,LOW);
// Setup Serial Monitor
// Read Red Pulse Width
redPW = getRedPW();
// Delay to stabilize sensor
delay(200);
// Read Green Pulse Width
greenPW = getGreenPW();
delay(200);
// Read Blue Pulse Width
bluePW = getBluePW();
delay(200);
// Print output to Serial Monitor
Serial.print(redPW);
Serial.print(", ");
Serial.print(greenPW);
Serial.print(", ");
Serial.print(bluePW);
Serial.println("");
// Function to read Red Pulse Widths
int getRedPW() {
// Set sensor to read Red only
digitalWrite(S2,LOW);
digitalWrite(S3,LOW);
// Define integer to represent Pulse Width
int PW;
// Read the output Pulse Width
PW = pulseIn(sensorOut, LOW);
// Return the value
return PW;
// Function to read Green Pulse Widths
int getGreenPW() {
// Set sensor to read Green only
digitalWrite(S2,HIGH);
digitalWrite(S3,HIGH);
int PW;
// Return the value
return PW;
// Function to read Blue Pulse Widths
int getBluePW() {
// Set sensor to read Blue only
int PW;
// Return the value
return PW;
Which is from DroneBot Workshop. The calibration is done by scanning white and black object and recording the min and max of the RGB values. Following is the updated code:
#define S0 4
#define S1 5
#define S2 6
#define S3 7
#define sensorOut 8
// Calibration Values
// Get these from Calibration Sketch
int redMin = 19; // Red minimum value
int redMax = 255; // Red maximum value
int greenMin = 18; // Green minimum value
int greenMax = 252; // Green maximum value
int blueMin = 11; // Blue minimum value
int blueMax = 175; // Blue maximum value
int redPW = 0;
int greenPW = 0;
int bluePW = 0;
// Variables for final Color values
int redValue;
int greenValue;
int blueValue;
// Set Frequency scaling to 20%
digitalWrite(S0, HIGH);
digitalWrite(S1, LOW);
// Read Red value
redPW = getRedPW();
// Map to value from 0-255
redValue = map(redPW, redMin, redMax, 255, 0);
// Constrain the value to the 0-255 range
redValue = constrain(redValue, 0, 255);
delay(200);
// Read Green value
greenValue = map(greenPW, greenMin, greenMax, 255, 0);
greenValue = constrain(greenValue, 0, 255);
delay(200);
// Read Blue value
blueValue = map(bluePW, blueMin, blueMax, 255, 0);
blueValue = constrain(blueValue, 0, 255);
delay(200);
Serial.print(redValue);
Serial.print(",");
Serial.print(greenValue);
Serial.print(",");
Serial.println(blueValue);
int getRedPW() {
digitalWrite(S2, LOW);
digitalWrite(S3, LOW);
int PW;
// Return the value
return PW;
int getGreenPW() {
digitalWrite(S2, HIGH);
digitalWrite(S3, HIGH);
int PW;
// Return the value
return PW;
int getBluePW() {
int PW;
// Return the value
return PW;
After the calibration, I generated an GUI using python to display the colour of the detected object. The following is the code:
import tkinter as tk
import serial
import time
import threading
# Define a dictionary of RGB color codes and their corresponding color names
color_database = {
"#FF0000": "Red",
"#00FF00": "Green",
"#0000FF": "Blue",
"#FFFF00": "Yellow",
"#FF00FF": "Magenta",
"#00FFFF": "Cyan / Aqua",
"#FFFFFF": "White",
"#000000": "Black",
# Initialize serial communication with Arduino (use the correct COM port)
ser = serial.Serial('COM6', baudrate=9600) # Replace 'COM6' with the correct port
# Function to look up and display color name and color
def lookup_color():
try:
# Read RGB values from Arduino via serial connection
rgb_values = ser.readline().decode().strip().split(',')
r, g, b = [int(val) for val in rgb_values]
# Initialize color_code
color_code = f"#{r:02X}{g:02X}{b:02X}"
# Check for various color ranges
if 0 <= r <= 15 and 0 <= g <= 15 and 0 <= b <= 15:
color_name = "Black"
elif 200 <= r <= 255 and 0 <= g <= 50 and 0 <= b <= 50:
color_name = "Red"
elif 0 <= r <= 50 and 200 <= g <= 255 and 0 <= b <= 50:
color_name = "Green"
elif 0 <= r <= 50 and 0 <= g <= 50 and 200 <= b <= 255:
color_name = "Blue"
elif 250 <= r <= 255 and 250 <= g <= 255 and 250 <= b <= 255:
color_name = "white"
elif 200 <= r <= 220 and 200 <= g <= 220 and 135 <= b <= 151:
color_name = "Green - Healthy Leaf"
elif 214 <= r <= 237 and 209 <= g <= 231 and 150 <= b <= 166:
elif 226 <= r <= 250 and 221 <= g <= 245 and 182 <= b <= 202:
color_name = "Yellow - Senescence Leaf"
elif 214 <= r <= 236 and 188 <= g <= 208 and 150 <= b <= 166:
color_name = "Brown - Dead Leaf"
elif 242 <= r <= 255 and 227 <= g <= 251 and 209 <= b <= 231:
else:
# Look up color name in the database
color_name = color_database.get(color_code, "Unknown")
# Update the UI elements
color_label.config(text=f"Color Name: {color_name}")
rgb_label.config(text=f"RGB Value: R={r}, G={g}, B={b}")
canvas.config(bg=color_code)
except Exception as e:
print(f"Error: {e}")
# Create a tkinter window
window = tk.Tk()
window.title("Color Detection and Lookup")
# Create and configure UI elements
color_label = tk.Label(window, text="Color Name: ")
color_label.pack(pady=10)
rgb_label = tk.Label(window, text="RGB Value: R=0, G=0, B=0")
rgb_label.pack(pady=10)
canvas = tk.Canvas(window, width=100, height=100)
canvas.pack()
# Set the scanning interval in seconds (e.g., 2 seconds)
scanning_interval = 0.02
# Function to continuously scan for colors
def continuous_scan():
while True:
lookup_color() # Call the lookup_color function
window.update() # Update the tkinter window
time.sleep(scanning_interval) # Wait for the specified interval
# Create a separate thread for continuous scanning
scan_thread = threading.Thread(target=continuous_scan)
scan_thread.daemon = True # Allow the thread to exit when the main program exits
scan_thread.start() # Start the continuous scanning thread
# Start the tkinter main loop
window.mainloop()
I am able to display the colour but the RGB values will fluctuate (around 5%-10%) of values when.
I have also made a black box and mounted the sensor within it to reduce the influence of ambient lighting. But the fluctuation is still occurring. Would like to check if anyone got any solutions/advice to improve the situation.
Thank you.
