Teensy 4.1 with 7in ssd1963 display
Im trying to run a ssd1963 display with a teensy 4.1 using a modified version of UTFT. After about 12hrs of jacking around i have the display making lines but no text, full color, etc. It changes every second like my code is commanding but it just changes a few lines here and there. If this display chip is impossible to manage or use what 7-10in display do you recommend?
Here is initlcd.h
case SSD1963_800ALT:
	LCD_Write_COM(0xE2);		// PLL multiplier, set PLL clock to 120M
	LCD_Write_DATA(0x23);	    // N=0x36 for 6.5M, 0x23 for 10M crystal
	delay(1);
	LCD_Write_DATA(0x02);
	delay(1);
	LCD_Write_DATA(0x04);
	delay(1);
	LCD_Write_COM(0xE0);		// PLL enable
	LCD_Write_DATA(0x01);
	delay(10);
	LCD_Write_DATA(0x03);
	delay(10);
	LCD_Write_COM(0x01);		// Software reset
	delay(100);
	LCD_Write_COM(0xE6);		// PLL setting for PCLK
	delay(1);
	LCD_Write_DATA(0x93);
	delay(1);
	LCD_Write_DATA(0xE0);
	delay(1);
	LCD_Write_COM(0xB0);		// LCD SPECIFICATION
	LCD_Write_DATA(0x00);	    // TFT mode
	delay(1);
	delay(1);
	LCD_Write_DATA(0x03);		// Set HDP (799)
	delay(1);
	LCD_Write_DATA(0x1F);
	delay(1);
	LCD_Write_DATA(0x01);		// Set VDP (479)
	delay(1);
	LCD_Write_DATA(0xDF);
	delay(1);
	delay(1);
	LCD_Write_COM(0xB4);		// HSYNC
	LCD_Write_DATA(0x03);		// Set HT (928)
	delay(1);
	LCD_Write_DATA(0xA0);
	delay(1);
	LCD_Write_DATA(0x00);		// Set HPS (46)
	delay(1);
	LCD_Write_DATA(0x2E);
	delay(1);
	LCD_Write_DATA(0x30);		// Set HPW (48)
	delay(1);
	LCD_Write_DATA(0x00);		// Set LPS (15)
	delay(1);
	LCD_Write_DATA(0x0F);
	delay(1);
	delay(1);
	LCD_Write_COM(0xB6);		// VSYNC
	LCD_Write_DATA(0x02);		// Set VT (525)
	delay(1);
	LCD_Write_DATA(0x0D);
	delay(1);
	LCD_Write_DATA(0x00);		// Set VPS (16)
	delay(1);
	LCD_Write_DATA(0x10);
	delay(1);
	LCD_Write_DATA(0x10);		// Set VPW (16)
	delay(1);
	LCD_Write_DATA(0x00);		// Set FPS (8)
	delay(1);
	LCD_Write_DATA(0x08);
	delay(1);
	LCD_Write_COM(0xBA);		// GPIO control
	LCD_Write_DATA(0x05);		// GPIO[3:0] out 1
	delay(1);
	LCD_Write_COM(0xB8);		// GPIO config
	LCD_Write_DATA(0x07);	    // GPIO3=input, GPIO[2:0]=output
	delay(1);
	LCD_Write_DATA(0x01);		// GPIO0 normal
	delay(1);
	// ⬇️ Rotation & RGB Order
	LCD_Write_COM(0x36);              // Set Address Mode
	LCD_Write_DATA(0b01000010);       // MX + BGR (Landscape)
	delay(1);
	LCD_Write_COM(0xF0);		// Pixel data interface
	LCD_Write_DATA(0x03);       // 16-bit 565
	delay(1);
	delay(10);
	setXY(0, 0, 799, 479);
	LCD_Write_COM(0x29);		// Display on
	LCD_Write_COM(0xBE);		// PWM for B/L
	LCD_Write_DATA(0x06);
	delay(1);
	LCD_Write_DATA(0xF0);
	delay(1);
	delay(1);
	delay(1);
	delay(1);
	delay(1);
	LCD_Write_COM(0xD0);
	delay(1);
	LCD_Write_COM(0x2C);
HW_teensy4.h
// CTE TFT LCD/SD Shield for Arduino Due
// Uncomment the following line if you are using this shield
//#define CTE_DUE_SHIELD 1
// For this shield: RS=25, WR=26, CS=27, RST=28
// ElecHouse TFT LCD/SD Shield for Arduino Due
//#define EHOUSE_DUE_SHIELD 1
// For this shield: RS=22, WR=23, CS=31, RST=33
// *** Hardwarespecific defines ***
// HW_Teensy4.h – Hardware-specific defines for UTFT on Teensy 4.x
#ifndef UTFT_TEENSY4
#define UTFT_TEENSY4
// Uncomment one of these if you're using a shield:
// #define CTE_DUE_SHIELD 1  // RS=25, WR=26, CS=27, RST=28
// #define EHOUSE_DUE_SHIELD 1  // RS=22, WR=23, CS=31, RST=33
#define UTFT_DATA_PORT1 GPIO6  // Pins 2–17 map to GPIO6
// Optional fast-write function for 16-bit
#if defined(ENERGIA)
  #define cbi(reg, bitmask) HWREG((uint32_t)(reg) + 0x3FC) &= ~(bitmask)
  #define sbi(reg, bitmask) HWREG((uint32_t)(reg) + 0x3FC) |= (bitmask)
#elif defined(__IMXRT1062__)
  #define cbi(reg, bitmask) *(reg) &= ~(bitmask)
  #define sbi(reg, bitmask) *(reg) |= (bitmask)
#else
  #define cbi(reg, bitmask) digitalWriteFast((reg), LOW)
  #define sbi(reg, bitmask) digitalWriteFast((reg), HIGH)
#endif
#define pulse_high(reg, bitmask) sbi(reg, bitmask); cbi(reg, bitmask)
#define pulse_low(reg, bitmask) cbi(reg, bitmask); sbi(reg, bitmask)
#define cport(port, data) port &= data
#define sport(port, data) port |= data
#define swap(type, i, j) {type t = i; i = j; j = t;}
#define fontbyte(x) cfont.font[x]
#ifndef pgm_read_word
  #define pgm_read_word(data) *data
#endif
#ifndef pgm_read_byte
  #define pgm_read_byte(data) *data
#endif
#define bitmapdatatype unsigned short*
// Define register types based on architecture
#if defined(__IMXRT1062__)  // Teensy 4.0 / 4.1
  #pragma message("✅ Compiling for Teensy 4.x")
  #define regtype volatile uint32_t
  #define regsize uint32_t
#elif defined(TEENSYDUINO)
  #define regtype volatile uint8_t
  #define regsize uint8_t
#else
#endif
#endif  // UTFT_TEENSY4
UTFT.CPP
  UTFT.cpp - Multi-Platform library support for Color TFT LCD Boards
  Copyright (C)2015-2018 Rinky-Dink Electronics, Henning Karlsen. All right reserved
  This library is the continuation of my ITDB02_Graph, ITDB02_Graph16
  and RGB_GLCD libraries for Arduino and chipKit. As the number of
  supported display modules and controllers started to increase I felt
  it was time to make a single, universal library as it will be much
  easier to maintain in the future.
  Basic functionality of this library was origianlly based on the
  demo-code provided by ITead studio (for the ITDB02 modules) and
  NKC Electronics (for the RGB GLCD module/shield).
  This library supports a number of 8bit, 16bit and serial graphic
  displays, and will work with both Arduino, chipKit boards and select
  TI LaunchPads. For a full list of tested display modules and controllers,
  see the document UTFT_Supported_display_modules_&_controllers.pdf.
  When using 8bit and 16bit display modules there are some
  requirements you must adhere to. These requirements can be found
  in the document UTFT_Requirements.pdf.
  There are no special requirements when using serial displays.
  You can find the latest version of the library at
  http://www.RinkyDinkElectronics.com/
  This library is free software; you can redistribute it and/or
  modify it under the terms of the CC BY-NC-SA 3.0 license.
  Please see the included documents for further information.
  Commercial use of this library requires you to buy a license that
  will allow commercial use. This includes using the library,
  modified or not, as a tool to sell products.
  The license applies to all part of the library including the
  examples and tools supplied with the library.
#include "UTFT.h"
// Include hardware-specific functions for the correct MCU
#if defined(__AVR__)
	#include <avr/pgmspace.h>
	#include "hardware/avr/HW_AVR.h"
	#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
		#include "hardware/avr/HW_ATmega1280.h"
	#elif defined(__AVR_ATmega328P__)
		#include "hardware/avr/HW_ATmega328P.h"
	#elif defined(__AVR_ATmega32U4__)
		#include "hardware/avr/HW_ATmega32U4.h"
	#elif defined(__AVR_ATmega168__)
		#error "ATmega168 MCUs are not supported because they have too little flash memory!"
	#elif defined(__AVR_ATmega1284P__)
		#include "hardware/avr/HW_ATmega1284P.h"
	#else
		#error "Unsupported AVR MCU!"
	#endif
	#pragma message("Compiling for Teensy 4.x")
	#include "hardware/arm/HW_Teensy4.h"
#elif defined(__PIC32MX__)
  #include "hardware/pic32/HW_PIC32.h"
  #if defined(__32MX320F128H__)
    #pragma message("Compiling for chipKIT UNO32 (PIC32MX320F128H)")
	#include "hardware/pic32/HW_PIC32MX320F128H.h"
  #elif defined(__32MX340F512H__)
    #pragma message("Compiling for chipKIT uC32 (PIC32MX340F512H)")
	#include "hardware/pic32/HW_PIC32MX340F512H.h"
  #elif defined(__32MX795F512L__)
    #pragma message("Compiling for chipKIT MAX32 (PIC32MX795F512L)")
	#include "hardware/pic32/HW_PIC32MX795F512L.h"
  #else
    #error "Unsupported PIC32 MCU!"
  #endif
#elif defined(__arm__)
  #include "hardware/arm/HW_ARM.h"
  #if defined(__IMXRT1062__)  // Teensy 4.x
    #pragma message("✅ Including HW_Teensy4.h for Teensy 4.x")
  #elif defined(__SAM3X8E__)
    #pragma message("Compiling for Arduino Due (AT91SAM3X8E)...")
    #include "hardware/arm/HW_SAM3X8E.h"
  #elif defined(__MK20DX128__) || defined(__MK20DX256__)
    #pragma message("Compiling for Teensy 3.x (MK20DX128VLH7 / MK20DX256VLH7)...")
    #include "hardware/arm/HW_MX20DX256.h"
  #elif defined(__CC3200R1M1RGC__)
    #pragma message("Compiling for TI CC3200 LaunchPad...")
    #include "hardware/arm/HW_CC3200.h"
  #else
    #error "Unsupported ARM MCU!"
  #endif
#endif
#include "memorysaver.h"
UTFT::UTFT()
UTFT::UTFT(byte model, int RS, int WR, int CS, int RST, int SER)
	word	dsx[] = {239, 239, 239, 239, 239, 239, 175, 175, 239, 127,						// 00-09
					 127, 239, 271, 479, 239, 239, 239, 239, 239, 239,						// 10-19
					 479, 319, 239, 175,   0, 239, 239, 319, 319, 799,						// 20-29
					 127};																	// 30-
	word	dsy[] = {319, 399, 319, 319, 319, 319, 219, 219, 399, 159,						// 00-09
					 127, 319, 479, 799, 319, 319, 319, 319, 319, 319,						// 10-19
					 799, 479, 319, 219,   0, 319, 319, 479, 479, 479,						// 20-29
					 159};																	// 30-
	byte	dtm[] = {16, 16, 16, 8, 8, 16, 8, SERIAL_4PIN, 16, SERIAL_5PIN,					// 00-09
					 SERIAL_5PIN, 16, 16, 16, 8, 16, LATCHED_16, 16, 8, 8,					// 10-19
					 16, 16, 16, 8, 0, SERIAL_5PIN, SERIAL_4PIN, 16, 16, 16,				// 20-29
					 SERIAL_5PIN};															// 30-
	disp_x_size =			dsx[model];
	disp_y_size =			dsy[model];
	display_transfer_mode =	dtm[model];
	display_model =			model;
	__p1 = RS;
	__p2 = WR;
	__p3 = CS;
	__p4 = RST;
	__p5 = SER;
	if (display_transfer_mode == SERIAL_4PIN)
		display_transfer_mode=1;
		display_serial_mode=SERIAL_4PIN;
	if (display_transfer_mode == SERIAL_5PIN)
		display_serial_mode=SERIAL_5PIN;
	if (display_transfer_mode!=1)
		_set_direction_registers(display_transfer_mode);
		P_RS = (regtype*) portOutputRegister(RS);
		P_WR = (regtype*) portOutputRegister(WR);
		P_CS = (regtype*) portOutputRegister(CS);
		//P_RS	= portOutputRegister(digitalPinToPort(RS));
		B_RS	= digitalPinToBitMask(RS);
		//P_WR	= portOutputRegister(digitalPinToPort(WR));
		B_WR	= digitalPinToBitMask(WR);
		//P_CS	= portOutputRegister(digitalPinToPort(CS));
		B_CS	= digitalPinToBitMask(CS);
		P_RST	= portOutputRegister(digitalPinToPort(RST));
		B_RST	= digitalPinToBitMask(RST);
		if (display_transfer_mode==LATCHED_16)
			P_ALE	= portOutputRegister(digitalPinToPort(SER));
			B_ALE	= digitalPinToBitMask(SER);
			cbi(P_ALE, B_ALE);
			pinMode(8,OUTPUT);
			digitalWrite(8, LOW);
		P_SDA	= portOutputRegister(digitalPinToPort(RS));
		B_SDA	= digitalPinToBitMask(RS);
		P_SCL	= portOutputRegister(digitalPinToPort(WR));
		B_SCL	= digitalPinToBitMask(WR);
		if (RST != NOTINUSE)
		if (display_serial_mode!=SERIAL_4PIN)
			P_RS	= portOutputRegister(digitalPinToPort(SER));
			B_RS	= digitalPinToBitMask(SER);
void UTFT::LCD_Write_COM(char VL)
		cbi(P_RS, B_RS);
		LCD_Writ_Bus(0x00,VL,display_transfer_mode);
void UTFT::LCD_Write_DATA(char VH,char VL)
		sbi(P_RS, B_RS);
		LCD_Writ_Bus(VH,VL,display_transfer_mode);
		LCD_Writ_Bus(0x01,VH,display_transfer_mode);
		LCD_Writ_Bus(0x01,VL,display_transfer_mode);
void UTFT::LCD_Write_DATA(char VL)
		sbi(P_RS, B_RS);
void UTFT::LCD_Write_COM_DATA(char com1,int dat1)
     LCD_Write_COM(com1);
     LCD_Write_DATA(dat1>>8,dat1);
void UTFT::LCD_Write_DATA_8(char VL)
    sbi(P_RS, B_RS);
    LCD_Write_Bus_8(VL);
void UTFT::InitLCD(byte orientation)
	orient=orientation;
	_hw_special_init();
	pinMode(__p1,OUTPUT);
	pinMode(__p2,OUTPUT);
	pinMode(__p3,OUTPUT);
	if (__p4 != NOTINUSE)
		pinMode(__p4,OUTPUT);
	if ((display_transfer_mode==LATCHED_16) or ((display_transfer_mode==1) and (display_serial_mode==SERIAL_5PIN)))
		pinMode(__p5,OUTPUT);
	sbi(P_RST, B_RST);
	delay(5);
	cbi(P_RST, B_RST);
	delay(15);
	sbi(P_RST, B_RST);
	delay(15);
	cbi(P_CS, B_CS);
	switch(display_model)
#ifndef DISABLE_HX8347A
	#include "tft_drivers/hx8347a/initlcd.h"
#endif
#ifndef DISABLE_ILI9327
	#include "tft_drivers/ili9327/initlcd.h"
#endif
#ifndef DISABLE_SSD1289
	#include "tft_drivers/ssd1289/initlcd.h"
#endif
#ifndef DISABLE_ILI9325C
	#include "tft_drivers/ili9325c/initlcd.h"
#endif
#ifndef DISABLE_ILI9325D
	#include "tft_drivers/ili9325d/default/initlcd.h"
#endif
#ifndef DISABLE_ILI9325D_ALT
	#include "tft_drivers/ili9325d/alt/initlcd.h"
#endif
#ifndef DISABLE_HX8340B_8
	#include "tft_drivers/hx8340b/8/initlcd.h"
#endif
#ifndef DISABLE_HX8340B_S
	#include "tft_drivers/hx8340b/s/initlcd.h"
#endif
#ifndef DISABLE_ST7735
	#include "tft_drivers/st7735/std/initlcd.h"
#endif
#ifndef DISABLE_PCF8833
	#include "tft_drivers/pcf8833/initlcd.h"
#endif
#ifndef DISABLE_S1D19122
	#include "tft_drivers/s1d19122/initlcd.h"
#endif
#ifndef DISABLE_HX8352A
	#include "tft_drivers/hx8352a/initlcd.h"
#endif
#ifndef DISABLE_SSD1963_480
	#include "tft_drivers/ssd1963/480/initlcd.h"
#endif
#ifndef DISABLE_SSD1963_800
	#include "tft_drivers/ssd1963/800/initlcd.h"
#endif
#ifndef DISABLE_SSD1963_800_ALT
	#include "tft_drivers/ssd1963/800alt/initlcd.h"
#endif
#ifndef DISABLE_S6D1121
	#include "tft_drivers/s6d1121/initlcd.h"
#endif
#ifndef DISABLE_ILI9481
	#include "tft_drivers/ili9481/initlcd.h"
#endif
#ifndef DISABLE_S6D0164
	#include "tft_drivers/s6d0164/initlcd.h"
#endif
#ifndef DISABLE_ILI9341_S4P
	#include "tft_drivers/ili9341/s4p/initlcd.h"
#endif
#ifndef DISABLE_ILI9341_S5P
	#include "tft_drivers/ili9341/s5p/initlcd.h"
#endif
#ifndef DISABLE_ILI9341_8
	#include "tft_drivers/ili9341/8/initlcd.h"
#endif
#ifndef DISABLE_ILI9341_16
	#include "tft_drivers/ili9341/16/initlcd.h"
#endif
#ifndef DISABLE_R61581
	#include "tft_drivers/r61581/initlcd.h"
#endif
#ifndef DISABLE_ILI9486
	#include "tft_drivers/ili9486/initlcd.h"
#endif
#ifndef DISABLE_CPLD
	#include "tft_drivers/cpld/initlcd.h"
#endif
#ifndef DISABLE_HX8353C
	#include "tft_drivers/hx8353c/initlcd.h"
#endif
	sbi (P_CS, B_CS);
	setColor(255, 255, 255);
	setBackColor(0, 0, 0);
	cfont.font=0;
	_transparent = false;
void UTFT::setXY(word x1, word y1, word x2, word y2)
	if (orient==LANDSCAPE)
		swap(word, x1, y1);
		swap(word, x2, y2)
		y1=disp_y_size-y1;
		y2=disp_y_size-y2;
		swap(word, y1, y2)
	#include "tft_drivers/hx8347a/setxy.h"
#endif
	#include "tft_drivers/hx8352a/setxy.h"
#endif
	#include "tft_drivers/ili9327/setxy.h"
#endif
	#include "tft_drivers/ssd1289/setxy.h"
#endif
	#include "tft_drivers/ili9325c/setxy.h"
#endif
	#include "tft_drivers/ili9325d/default/setxy.h"
#endif
	#include "tft_drivers/ili9325d/alt/setxy.h"
#endif
	#include "tft_drivers/hx8340b/8/setxy.h"
#endif
	#include "tft_drivers/hx8340b/s/setxy.h"
#endif
	#include "tft_drivers/st7735/std/setxy.h"
#endif
	#include "tft_drivers/s1d19122/setxy.h"
#endif
	#include "tft_drivers/pcf8833/setxy.h"
#endif
	#include "tft_drivers/ssd1963/480/setxy.h"
#endif
	#include "tft_drivers/ssd1963/800/setxy.h"
#endif
	#include "tft_drivers/ssd1963/800alt/setxy.h"
#endif
	#include "tft_drivers/s6d1121/setxy.h"
#endif
	#include "tft_drivers/ili9481/setxy.h"
#endif
	#include "tft_drivers/s6d0164/setxy.h"
#endif
	#include "tft_drivers/ili9341/s4p/setxy.h"
#endif
	#include "tft_drivers/ili9341/s5p/setxy.h"
#endif
	#include "tft_drivers/ili9341/8/setxy.h"
#endif
	#include "tft_drivers/ili9341/16/setxy.h"
#endif
	#include "tft_drivers/r61581/setxy.h"
#endif
	#include "tft_drivers/ili9486/setxy.h"
#endif
	#include "tft_drivers/cpld/setxy.h"
#endif
	#include "tft_drivers/hx8353c/setxy.h"
#endif
void UTFT::clrXY()
	if (orient==PORTRAIT)
		setXY(0,0,disp_x_size,disp_y_size);
		setXY(0,0,disp_y_size,disp_x_size);
void UTFT::drawRect(int x1, int y1, int x2, int y2)
	if (x1>x2)
		swap(int, x1, x2);
	if (y1>y2)
		swap(int, y1, y2);
	drawHLine(x1, y1, x2-x1);
	drawHLine(x1, y2, x2-x1);
	drawVLine(x1, y1, y2-y1);
	drawVLine(x2, y1, y2-y1);
void UTFT::drawRoundRect(int x1, int y1, int x2, int y2)
	if (x1>x2)
		swap(int, x1, x2);
	if (y1>y2)
		swap(int, y1, y2);
	if ((x2-x1)>4 && (y2-y1)>4)
		drawPixel(x1+1,y1+1);
		drawPixel(x2-1,y1+1);
		drawPixel(x1+1,y2-1);
		drawPixel(x2-1,y2-1);
		drawHLine(x1+2, y1, x2-x1-4);
		drawHLine(x1+2, y2, x2-x1-4);
		drawVLine(x1, y1+2, y2-y1-4);
		drawVLine(x2, y1+2, y2-y1-4);
void UTFT::fillRect(int x1, int y1, int x2, int y2)
	if (x1>x2)
		swap(int, x1, x2);
	if (y1>y2)
		swap(int, y1, y2);
	if (display_transfer_mode==16)
		cbi(P_CS, B_CS);
		setXY(x1, y1, x2, y2);
		sbi(P_RS, B_RS);
		_fast_fill_16(fch,fcl,((long(x2-x1)+1)*(long(y2-y1)+1)));
		sbi(P_CS, B_CS);
	else if ((display_transfer_mode==8) and (fch==fcl))
		cbi(P_CS, B_CS);
		sbi(P_RS, B_RS);
		_fast_fill_8(fch,((long(x2-x1)+1)*(long(y2-y1)+1)));
		sbi(P_CS, B_CS);
			for (int i=0; i<((y2-y1)/2)+1; i++)
				drawHLine(x1, y1+i, x2-x1);
				drawHLine(x1, y2-i, x2-x1);
			for (int i=0; i<((x2-x1)/2)+1; i++)
				drawVLine(x1+i, y1, y2-y1);
				drawVLine(x2-i, y1, y2-y1);
void UTFT::fillRoundRect(int x1, int y1, int x2, int y2)
	if (x1>x2)
		swap(int, x1, x2);
	if (y1>y2)
		swap(int, y1, y2);
			switch(i)
			case 0:
				drawHLine(x1+2, y1+i, x2-x1-4);
				drawHLine(x1+2, y2-i, x2-x1-4);
			case 1:
				drawHLine(x1+1, y1+i, x2-x1-2);
				drawHLine(x1+1, y2-i, x2-x1-2);
			default:
void UTFT::drawCircle(int x, int y, int radius)
	int f = 1 - radius;
	int ddF_x = 1;
	int ddF_y = -2 * radius;
	int x1 = 0;
	int y1 = radius;
	cbi(P_CS, B_CS);
	setXY(x, y + radius, x, y + radius);
	LCD_Write_DATA(fch,fcl);
	setXY(x, y - radius, x, y - radius);
	setXY(x + radius, y, x + radius, y);
	setXY(x - radius, y, x - radius, y);
	while(x1 < y1)
		if(f >= 0)
			y1--;
			ddF_y += 2;
			f += ddF_y;
		x1++;
		ddF_x += 2;
		f += ddF_x;
		setXY(x + x1, y + y1, x + x1, y + y1);
		setXY(x - x1, y + y1, x - x1, y + y1);
		setXY(x + x1, y - y1, x + x1, y - y1);
		setXY(x - x1, y - y1, x - x1, y - y1);
		setXY(x + y1, y + x1, x + y1, y + x1);
		setXY(x - y1, y + x1, x - y1, y + x1);
		setXY(x + y1, y - x1, x + y1, y - x1);
		setXY(x - y1, y - x1, x - y1, y - x1);
	sbi(P_CS, B_CS);
	clrXY();
void UTFT::fillCircle(int x, int y, int radius)
	for(int y1=-radius; y1<=0; y1++)
		for(int x1=-radius; x1<=0; x1++)
			if(x1*x1+y1*y1 <= radius*radius)
				drawHLine(x+x1, y+y1, 2*(-x1));
				drawHLine(x+x1, y-y1, 2*(-x1));
void UTFT::clrScr()
	long i;
	cbi(P_CS, B_CS);
	clrXY();
		sbi(P_RS, B_RS);
		_fast_fill_16(0,0,((disp_x_size+1)*(disp_y_size+1)));
	else if (display_transfer_mode==8)
		_fast_fill_8(0,((disp_x_size+1)*(disp_y_size+1)));
		for (i=0; i<((disp_x_size+1)*(disp_y_size+1)); i++)
				LCD_Writ_Bus(0,0,display_transfer_mode);
				LCD_Writ_Bus(1,0,display_transfer_mode);
	sbi(P_CS, B_CS);
void UTFT::fillScr(byte r, byte g, byte b)
	word color = ((r&248)<<8 | (g&252)<<3 | (b&248)>>3);
	fillScr(color);
void UTFT::fillScr(word color)
	long i;
	char ch, cl;
	ch=byte(color>>8);
	cl=byte(color & 0xFF);
	cbi(P_CS, B_CS);
	clrXY();
		sbi(P_RS, B_RS);
		_fast_fill_16(ch,cl,((disp_x_size+1)*(disp_y_size+1)));
	else if ((display_transfer_mode==8) and (ch==cl))
		_fast_fill_8(ch,((disp_x_size+1)*(disp_y_size+1)));
				LCD_Writ_Bus(ch,cl,display_transfer_mode);
				LCD_Writ_Bus(1,ch,display_transfer_mode);
				LCD_Writ_Bus(1,cl,display_transfer_mode);
	sbi(P_CS, B_CS);
void UTFT::setColor(byte r, byte g, byte b)
	fch=((r&248)|g>>5);
	fcl=((g&28)<<3|b>>3);
void UTFT::setColor(word color)
	fch=byte(color>>8);
	fcl=byte(color & 0xFF);
word UTFT::getColor()
	return (fch<<8) | fcl;
void UTFT::setBackColor(byte r, byte g, byte b)
	bch=((r&248)|g>>5);
	bcl=((g&28)<<3|b>>3);
	_transparent=false;
void UTFT::setBackColor(uint32_t color)
	if (color==VGA_TRANSPARENT)
		_transparent=true;
		bch=byte(color>>8);
		bcl=byte(color & 0xFF);
		_transparent=false;
word UTFT::getBackColor()
	return (bch<<8) | bcl;
void UTFT::setPixel(word color)
	LCD_Write_DATA((color>>8),(color&0xFF));	// rrrrrggggggbbbbb
void UTFT::drawPixel(int x, int y)
	cbi(P_CS, B_CS);
	setXY(x, y, x, y);
	setPixel((fch<<8)|fcl);
	sbi(P_CS, B_CS);
	clrXY();
void UTFT::drawLine(int x1, int y1, int x2, int y2)
	if (y1==y2)
	else if (x1==x2)
		unsigned int	dx = (x2 > x1 ? x2 - x1 : x1 - x2);
		short			xstep =  x2 > x1 ? 1 : -1;
		unsigned int	dy = (y2 > y1 ? y2 - y1 : y1 - y2);
		short			ystep =  y2 > y1 ? 1 : -1;
		int				col = x1, row = y1;
		cbi(P_CS, B_CS);
		if (dx < dy)
			int t = - (dy >> 1);
			while (true)
				setXY (col, row, col, row);
				LCD_Write_DATA (fch, fcl);
				if (row == y2)
					return;
				row += ystep;
				t += dx;
				if (t >= 0)
					col += xstep;
					t   -= dy;
			int t = - (dx >> 1);
			while (true)
				if (col == x2)
					return;
				col += xstep;
				t += dy;
				if (t >= 0)
					row += ystep;
					t   -= dx;
		sbi(P_CS, B_CS);
	clrXY();
void UTFT::drawHLine(int x, int y, int l)
	if (l<0)
		l = -l;
		x -= l;
	cbi(P_CS, B_CS);
	setXY(x, y, x+l, y);
	if (display_transfer_mode == 16)
		sbi(P_RS, B_RS);
		_fast_fill_16(fch,fcl,l);
		sbi(P_RS, B_RS);
		_fast_fill_8(fch,l);
		for (int i=0; i<l+1; i++)
			LCD_Write_DATA(fch, fcl);
	sbi(P_CS, B_CS);
	clrXY();
void UTFT::drawVLine(int x, int y, int l)
	if (l<0)
		l = -l;
		y -= l;
	cbi(P_CS, B_CS);
	setXY(x, y, x, y+l);
		sbi(P_RS, B_RS);
		sbi(P_RS, B_RS);
	sbi(P_CS, B_CS);
	clrXY();
void UTFT::printChar(byte c, int x, int y)
	byte i,ch;
	word j;
	word temp;
	cbi(P_CS, B_CS);
	if (!_transparent)
			setXY(x,y,x+cfont.x_size-1,y+cfont.y_size-1);
			temp=((c-cfont.offset)*((cfont.x_size/8)*cfont.y_size))+4;
			for(j=0;j<((cfont.x_size/8)*cfont.y_size);j++)
				ch=pgm_read_byte(&cfont.font[temp]);
				for(i=0;i<8;i++)
					if((ch&(1<<(7-i)))!=0)
						setPixel((bch<<8)|bcl);
				temp++;
			for(j=0;j<((cfont.x_size/8)*cfont.y_size);j+=(cfont.x_size/8))
				setXY(x,y+(j/(cfont.x_size/8)),x+cfont.x_size-1,y+(j/(cfont.x_size/8)));
				for (int zz=(cfont.x_size/8)-1; zz>=0; zz--)
					ch=pgm_read_byte(&cfont.font[temp+zz]);
					for(i=0;i<8;i++)
						if((ch&(1<<i))!=0)
				temp+=(cfont.x_size/8);
		for(j=0;j<cfont.y_size;j++)
			for (int zz=0; zz<(cfont.x_size/8); zz++)
				for(i=0;i<8;i++)
						setXY(x+i+(zz*8),y+j,x+i+(zz*8)+1,y+j+1);
	sbi(P_CS, B_CS);
	clrXY();
void UTFT::rotateChar(byte c, int x, int y, int pos, int deg)
	byte i,j,ch;
	word temp;
	int newx,newy;
	double radian;
	radian=deg*0.0175;
	cbi(P_CS, B_CS);
			for(i=0;i<8;i++)
				newx=x+(((i+(zz*8)+(pos*cfont.x_size))*cos(radian))-((j)*sin(radian)));
				newy=y+(((j)*cos(radian))+((i+(zz*8)+(pos*cfont.x_size))*sin(radian)));
				setXY(newx,newy,newx+1,newy+1);
					if (!_transparent)
	sbi(P_CS, B_CS);
	clrXY();
void UTFT::print(char *st, int x, int y, int deg)
	int stl, i;
	stl = strlen(st);
	if (x==RIGHT)
		x=(disp_x_size+1)-(stl*cfont.x_size);
	if (x==CENTER)
		x=((disp_x_size+1)-(stl*cfont.x_size))/2;
	if (x==RIGHT)
		x=(disp_y_size+1)-(stl*cfont.x_size);
	if (x==CENTER)
		x=((disp_y_size+1)-(stl*cfont.x_size))/2;
	for (i=0; i<stl; i++)
		if (deg==0)
			printChar(*st++, x + (i*(cfont.x_size)), y);
			rotateChar(*st++, x, y, i, deg);
void UTFT::print(String st, int x, int y, int deg)
	char buf[st.length()+1];
	st.toCharArray(buf, st.length()+1);
	print(buf, x, y, deg);
void UTFT::printNumI(long num, int x, int y, int length, char filler)
	char buf[25];
	char st[27];
	boolean neg=false;
	int c=0, f=0;
	if (num==0)
		if (length!=0)
			for (c=0; c<(length-1); c++)
				st[c]=filler;
			st[c]=48;
			st[c+1]=0;
			st[0]=48;
			st[1]=0;
		if (num<0)
			neg=true;
			num=-num;
		while (num>0)
			buf[c]=48+(num % 10);
			c++;
			num=(num-(num % 10))/10;
		buf[c]=0;
		if (neg)
			st[0]=45;
		if (length>(c+neg))
			for (int i=0; i<(length-c-neg); i++)
				st[i+neg]=filler;
				f++;
		for (int i=0; i<c; i++)
			st[i+neg+f]=buf[c-i-1];
		st[c+neg+f]=0;
	print(st,x,y);
void UTFT::printNumF(double num, byte dec, int x, int y, char divider, int length, char filler)
	char st[27];
	boolean neg=false;
	if (dec<1)
		dec=1;
	else if (dec>5)
		dec=5;
	if (num<0)
		neg = true;
	_convert_float(st, num, length, dec);
	if (divider != '.')
		for (size_t i=0; i<sizeof(st); i++)
			if (st[i]=='.')
				st[i]=divider;
	if (filler != ' ')
		if (neg)
			st[0]='-';
			for (size_t i=1; i<sizeof(st); i++)
				if ((st[i]==' ') || (st[i]=='-'))
					st[i]=filler;
				if (st[i]==' ')
					st[i]=filler;
	print(st,x,y);
void UTFT::setFont(uint8_t* font)
	cfont.font=font;
	cfont.x_size=fontbyte(0);
	cfont.y_size=fontbyte(1);
	cfont.offset=fontbyte(2);
	cfont.numchars=fontbyte(3);
uint8_t* UTFT::getFont()
	return cfont.font;
uint8_t UTFT::getFontXsize()
	return cfont.x_size;
uint8_t UTFT::getFontYsize()
	return cfont.y_size;
void UTFT::drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int scale)
	unsigned int col;
	int tx, ty, tc, tsx, tsy;
	if (scale==1)
			cbi(P_CS, B_CS);
			setXY(x, y, x+sx-1, y+sy-1);
			for (tc=0; tc<(sx*sy); tc++)
				col=pgm_read_word(&data[tc]);
				LCD_Write_DATA(col>>8,col & 0xff);
			sbi(P_CS, B_CS);
			cbi(P_CS, B_CS);
			for (ty=0; ty<sy; ty++)
				setXY(x, y+ty, x+sx-1, y+ty);
				for (tx=sx-1; tx>=0; tx--)
					col=pgm_read_word(&data[(ty*sx)+tx]);
			sbi(P_CS, B_CS);
			cbi(P_CS, B_CS);
				setXY(x, y+(ty*scale), x+((sx*scale)-1), y+(ty*scale)+scale);
				for (tsy=0; tsy<scale; tsy++)
					for (tx=0; tx<sx; tx++)
						for (tsx=0; tsx<scale; tsx++)
			sbi(P_CS, B_CS);
			cbi(P_CS, B_CS);
					setXY(x, y+(ty*scale)+tsy, x+((sx*scale)-1), y+(ty*scale)+tsy);
			sbi(P_CS, B_CS);
	clrXY();
void UTFT::drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int deg, int rox, int roy)
	unsigned int col;
	int tx, ty, newx, newy;
	double radian;
	radian=deg*0.0175;
	if (deg==0)
		drawBitmap(x, y, sx, sy, data);
		cbi(P_CS, B_CS);
				newx=x+rox+(((tx-rox)*cos(radian))-((ty-roy)*sin(radian)));
				newy=y+roy+(((ty-roy)*cos(radian))+((tx-rox)*sin(radian)));
				setXY(newx, newy, newx, newy);
		sbi(P_CS, B_CS);
	clrXY();
void UTFT::lcdOff()
	cbi(P_CS, B_CS);
	switch (display_model)
	case PCF8833:
		LCD_Write_COM(0x28);
	case CPLD:
		LCD_Write_COM_DATA(0x01,0x0000);
		LCD_Write_COM(0x0F);
	sbi(P_CS, B_CS);
void UTFT::lcdOn()
	cbi(P_CS, B_CS);
	case PCF8833:
	case CPLD:
		LCD_Write_COM_DATA(0x01,0x0010);
	sbi(P_CS, B_CS);
void UTFT::setContrast(char c)
	cbi(P_CS, B_CS);
	case PCF8833:
		if (c>64) c=64;
		LCD_Write_COM(0x25);
		LCD_Write_DATA(c);
	sbi(P_CS, B_CS);
int UTFT::getDisplayXSize()
		return disp_x_size+1;
		return disp_y_size+1;
int UTFT::getDisplayYSize()
void UTFT::setBrightness(byte br)
	cbi(P_CS, B_CS);
	case CPLD:
		if (br>16) br=16;
		LCD_Write_COM_DATA(0x01,br);
	sbi(P_CS, B_CS);
void UTFT::setDisplayPage(byte page)
	cbi(P_CS, B_CS);
	case CPLD:
		if (page>7) page=7;
		LCD_Write_COM_DATA(0x04,page);
	sbi(P_CS, B_CS);
void UTFT::setWritePage(byte page)
	cbi(P_CS, B_CS);
	case CPLD:
		if (page>7) page=7;
		LCD_Write_COM_DATA(0x05,page);
	sbi(P_CS, B_CS);
const uint8_t dataPins[16] = {
  24, 25, 26, 27, 17, 16, 22, 23,
  20, 21, 1,  0,  19, 18, 14, 15
// Control pins
const uint8_t pinRS = 3;
const uint8_t pinWR = 4;
const uint8_t pinCS = 5;
const uint8_t pinRESET = 6;
// Set data pins as output
void UTFT::_set_direction_registers(byte mode) {
  for (int i = 0; i < 16; i++) {
    pinMode(dataPins[i], OUTPUT);
    digitalWriteFast(dataPins[i], LOW); // default low
  pinMode(pinRS, OUTPUT);
  pinMode(pinWR, OUTPUT);
  pinMode(pinCS, OUTPUT);
  pinMode(pinRESET, OUTPUT);
  digitalWriteFast(pinCS, HIGH);  // CS inactive
  digitalWriteFast(pinWR, HIGH);  // WR inactive (high)
  digitalWriteFast(pinRS, HIGH);  // RS default high
  digitalWriteFast(pinRESET, HIGH); // RESET default high
// Write 16-bit data bus (VH = high byte, VL = low byte)
void UTFT::LCD_Writ_Bus(char VH, char VL, byte mode) {
  // Write 16 data bits to data pins
  uint16_t data = ((uint8_t)VH << 8) | (uint8_t)VL;
  // Set all 16 pins in parallel
    digitalWriteFast(dataPins[i], (data & (1 << i)) ? HIGH : LOW);
  // Pulse WR low to write data
  digitalWriteFast(pinWR, LOW);
  // small delay to meet timing (optional, can be tuned)
// Hardware special init (reset, CS high)
void UTFT::_hw_special_init() {
  digitalWriteFast(pinRESET, LOW);
  delay(50);
  delay(120);
// 8-bit write (not used in 16-bit mode, stub)
void UTFT::LCD_Write_Bus_8(char VL) {
  // If you want 8-bit mode, implement here
  // For 16-bit mode just ignore or call LCD_Writ_Bus with VL twice
  LCD_Writ_Bus(0, VL, 0);
// Fast fill 16-bit color pixels
void UTFT::_fast_fill_16(int ch, int cl, long pix) {
  // Example: Fill 'pix' pixels with color ch<<8 | cl
  uint16_t color = ((uint8_t)ch << 8) | (uint8_t)cl;
  for (long i = 0; i < pix; i++) {
    LCD_Writ_Bus(ch, cl, 16);
// Fast fill 8-bit pixels (stub, not used in 16-bit)
void UTFT::_fast_fill_8(int ch, long pix) {
  // For 8-bit mode, fill 'pix' pixels with ch
    LCD_Write_Bus_8(ch);
UTFT.h
UTFT.h - Multi-Platform library support for Color TFT LCD Boards
#ifndef UTFT_h
#define UTFT_h
#include <stdint.h>
typedef volatile uint32_t regtype;
typedef uint8_t regsize;
#define UTFT_VERSION 283
#define LEFT 0
#define RIGHT 9999
#define CENTER 9998
#define PORTRAIT 0
#define LANDSCAPE 1
#define HX8347A 0
#define ILI9327 1
#define SSD1289 2
#define ILI9325C 3
#define ILI9325D_8 4
#define ILI9325D_16 5
#define HX8340B_8 6
#define HX8340B_S 7
#define HX8352A 8
#define ST7735 9
#define PCF8833 10
#define S1D19122 11
#define SSD1963_480 12
#define SSD1963_800 13
#define S6D1121_8 14
#define S6D1121_16 15
#define SSD1289LATCHED 16
#define ILI9341_16 17
#define ILI9341_8 18
#define SSD1289_8 19
#define SSD1963_800ALT 20
#define ILI9481 21
#define ILI9325D_16ALT 22
#define S6D0164 23
#define NOT_IN_USE 24
#define ILI9341_S5P 25
#define ILI9341_S4P 26
#define R61581 27
#define ILI9486 28
#define CPLD 29
#define HX8353C 30
#define ITDB32 0 // HX8347-A (16bit)
#define ITDB32WC 1 // ILI9327 (16bit)
#define ITDB32S 2 // SSD1289 (16bit)
#define CTE32 2 // SSD1289 (16bit)
#define ITDB24 3 // ILI9325C (8bit)
#define ITDB24D 4 // ILI9325D (8bit)
#define ITDB24DWOT 4 // ILI9325D (8bit)
#define ITDB28 4 // ILI9325D (8bit)
#define DMTFT24104 4 // ILI9325D (8bit)
#define DMTFT28103 4 // ILI9325D (8bit)
#define ITDB22 6 // HX8340-B (8bit)
#define ITDB22SP 7 // HX8340-B (Serial 4Pin)
#define ITDB32WD 8 // HX8352-A (16bit)
#define CTE32W 8 // HX8352-A (16bit)
#define ITDB18SP 9 // ST7735 (Serial 5Pin)
#define LPH9135 10 // PCF8833 (Serial 5Pin)
#define ITDB25H 11 // S1D19122 (16bit)
#define ITDB43 12 // SSD1963 (16bit) 480x272
#define ITDB50 13 // SSD1963 (16bit) 800x480
#define CTE50 13 // SSD1963 (16bit) 800x480
#define EHOUSE50 13 // SSD1963 (16bit) 800x480
#define ITDB24E_8 14 // S6D1121 (8bit)
#define ITDB24E_16 15 // S6D1121 (16bit)
#define INFINIT32 16 // SSD1289 (Latched 16bit) -- Legacy, will be removed later
#define ELEE32_REVA 16 // SSD1289 (Latched 16bit)
#define CTE32_R2 17 // ILI9341 (16bit)
#define ITDB24E_V2_16 17 // ILI9341 (16bit)
#define ITDB28_V2_ALT 17 // ILI9341 (16bit)
#define ITDB32S_V2 17 // ILI9341 (16bit)
#define ITDB28_V2 18 // ILI9341 (8bit)
#define ITDB24E_V2_8 18 // ILI9341 (8bit)
#define ELEE32_REVB 19 // SSD1289 (8bit)
#define CTE70 20 // SSD1963 (16bit) 800x480 Alternative Init
#define EHOUSE70 20 // SSD1963 (16bit) 800x480 Alternative Init
#define CTE32HR 21 // ILI9481 (16bit)
#define CTE28 22 // ILI9325D (16bit) Alternative Init
#define CTE22 23 // S6D0164 (8bit)
#define DMTFT22102 23 // S6D0164 (8bit)
#define DMTFT28105 25 // ILI9341 (Serial 5Pin)
#define MI0283QT9 26 // ILI9341 (Serial 4Pin)
#define CTE35IPS 27 // R61581 (16bit)
#define CTE40 28 // ILI9486 (16bit)
#define EHOUSE50CPLD 29 // CPLD (16bit)
#define CTE50CPLD 29 // CPLD (16bit)
#define CTE70CPLD 29 // CPLD (16bit)
#define DMTFT18101 30 // HX8353C (Serial 5Pin)
#define SERIAL_4PIN 4
#define SERIAL_5PIN 5
#define LATCHED_16 17
#ifndef bitmapdatatype
#endif
#define NOTINUSE 255
// COLORS
// VGA color palette
#define VGA_BLACK 0x0000
#define VGA_WHITE 0xFFFF
#define VGA_RED 0xF800
#define VGA_GREEN 0x0400
#define VGA_BLUE 0x001F
#define VGA_SILVER 0xC618
#define VGA_GRAY 0x8410
#define VGA_MAROON 0x8000
#define VGA_YELLOW 0xFFE0
#define VGA_OLIVE 0x8400
#define VGA_LIME 0x07E0
#define VGA_AQUA 0x07FF
#define VGA_TEAL 0x0410
#define VGA_NAVY 0x0010
#define VGA_FUCHSIA 0xF81F
#define VGA_PURPLE 0x8010
#define VGA_TRANSPARENT 0xFFFFFFFF
#if defined(AVR)
#include "Arduino.h"
#include "hardware/avr/HW_AVR_defines.h"
#elif defined(IMXRT1062)
#elif defined(PIC32MX)
#include "WProgram.h"
#include "hardware/pic32/HW_PIC32_defines.h"
#elif defined(arm) && defined(CORE_TEENSY)
#if defined(IMXRT1062) // Teensy 4.0 / 4.1
#include "hardware/arm/HW_TEENSY41_defines.h"
#else
#include "hardware/arm/HW_Teensy3_defines.h"
#endif
#endif
struct _current_font
uint8_t* font;
uint8_t x_size;
uint8_t y_size;
uint8_t offset;
uint8_t numchars;
class UTFT
public:
UTFT();
UTFT(byte model, int RS, int WR, int CS, int RST, int SER=0);
void InitLCD(byte orientation=LANDSCAPE);
void clrScr();
void drawPixel(int x, int y);
void drawLine(int x1, int y1, int x2, int y2);
void fillScr(byte r, byte g, byte b);
void fillScr(word color);
void drawRect(int x1, int y1, int x2, int y2);
void drawRoundRect(int x1, int y1, int x2, int y2);
void fillRect(int x1, int y1, int x2, int y2);
void fillRoundRect(int x1, int y1, int x2, int y2);
void drawCircle(int x, int y, int radius);
void fillCircle(int x, int y, int radius);
void setColor(byte r, byte g, byte b);
void setColor(word color);
word getColor();
void setBackColor(byte r, byte g, byte b);
void setBackColor(uint32_t color);
word getBackColor();
void print(char st, int x, int y, int deg=0);
void print(String st, int x, int y, int deg=0);
void printNumI(long num, int x, int y, int length=0, char filler=' ');
void printNumF(double num, byte dec, int x, int y, char divider='.', int length=0, char filler=' ');
void setFont(uint8_t
font);
uint8_t* getFont();
uint8_t getFontXsize();
uint8_t getFontYsize();
void drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int scale=1);
void drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int deg, int rox, int roy);
void lcdOff();
void lcdOn();
void setContrast(char c);
int getDisplayXSize();
int getDisplayYSize();
void setBrightness(byte br);
void setDisplayPage(byte page);
void setWritePage(byte page);
The functions and variables below should not normally be used.
They have been left publicly available for use in add-on libraries
that might need access to the lower level functions of UTFT.
Please note that these functions and variables are not documented
and I do not provide support on how to use them.
byte fch, fcl, bch, bcl;
byte orient;
long disp_x_size, disp_y_size;
byte display_model, display_transfer_mode, display_serial_mode;
regtype *P_RS, *P_WR, *P_CS, *P_RST, *P_SDA, *P_SCL, *P_ALE;
regsize B_RS, B_WR, B_CS, B_RST, B_SDA, B_SCL, B_ALE;
byte __p1, __p2, __p3, __p4, __p5;
_current_font cfont;
boolean _transparent;
	void LCD_Writ_Bus(char VH,char VL, byte mode);
	void LCD_Write_COM(char VL);
	void LCD_Write_DATA(char VH,char VL);
	void LCD_Write_DATA(char VL);
	void LCD_Write_COM_DATA(char com1,int dat1);
	void LCD_Write_Bus_8(char VL);
	void LCD_Write_DATA_8(char VL);
	void _hw_special_init();
	void setPixel(word color);
	void drawHLine(int x, int y, int l);
	void drawVLine(int x, int y, int l);
	void printChar(byte c, int x, int y);
	void setXY(word x1, word y1, word x2, word y2);
	void clrXY();
	void rotateChar(byte c, int x, int y, int pos, int deg);
	void _set_direction_registers(byte mode);
	void _fast_fill_16(int ch, int cl, long pix);
	void _fast_fill_8(int ch, long pix);
	void _convert_float(char *buf, double num, int width, byte prec);
volatile uint32_t* portOutputRegister(int value);
#endif
#endif
HW_teensy41.h
// HW_TEENSY41_defines.h
#ifndef HW_TEENSY41_DEFINES_H
#define HW_TEENSY41_DEFINES_H
#define UTFT_TEENSY41
#include <Arduino.h>
// For Teensy 4.1: dummy types to satisfy UTFT structure
#define bitRead(value, bit) (((value) >> (bit)) & 0x01)
#define bitSet(value, bit) ((value) |= (1UL << (bit)))
#define bitClear(value, bit) ((value) &= ~(1UL << (bit)))
//Data Pins D0-D15 -> Teensy pins 2-17
#define P_RS    18
#define P_WR    19
#define P_CS    21
#define P_RST   22
// RD is optional unless doing readbacks
//#define P_RD    20
// 16-bit mode
#define UTFT_16BIT
#define UTFT_16BIT_DATA_PORT0  GPIO6_DR
#define UTFT_16BIT_DATA_PORT1  GPIO7_DR
#define UTFT_16BIT_DATA_MASK   0xFFFF
#endif```
Post all your code in code tags. Also post any log in code tags. Make a hand drawn diagram of YOUR wires and post a photo of that.
