Hello,
I would like to make a kind of telegraph using a buzzer plugged into my arduino card, and sending morse code to my PC, which will decode it and show alphanumerics caracters.
I have an "arduino" card provided by my University, which is actually not a real Arduino card, but it basically does exactly the same things. I started to write code, but it does not work, nothing happens when I press the buzzer.
Could anyone help me please?
Yes.
Hello arduinouca
Post your current sketch, well formated, with comments and in so called code tags "</>" and a schematic, not a Fritzy diagram, to see how we can help.
Дайте миру шанс
arduinouca:
Buzzers are devices that make a noise. They are not devices that react on a press.
6v6gt
April 10, 2022, 9:57am
5
Here is one example: Problem in order of execution of functions however, the decoding is done on an Arduino, not on a PC.
Thank you all for your fast answers. I'm novice in both programming and making such projects.
Here is picture of my arduino card, with a press button included (the button I am supposed to press to make morse code) :
At the moment, I didnt not connect any buzzer to the card, but I am supposing the push button alone should make the whole system work?
Here is the code I used . I did not write it myself, but I've checked it and it seems correct:
const int letterPin = 6; //you can change these two pins to whatever you want
const int spacePin = 0;
unsigned long startPressedLetter;
unsigned long endPressedLetter;
unsigned long timeHeldLetter;
int buttonStateLetter = 0;
int lastButtonStateLetter = 0;
const unsigned long cutoff = 300; //I find that 300 ms works best
String morseLetter = "";
pinMode(letterPin, INPUT);
pinMode(spacePin, OUTPUT);
//all about the letter button
buttonStateLetter = digitalRead(letterPin); //Did the letter button state change?
if (buttonStateLetter != lastButtonStateLetter) { //if button is pressed or released:
if (buttonStateLetter == HIGH) { //if it was pressed
startPressedLetter = millis(); //save the time when it was pressed
} else { //if it was released
endPressedLetter = millis(); //save the time it was released
timeHeldLetter = endPressedLetter - startPressedLetter; //calculate how long it was held down for
morseLetter += isDash(timeHeldLetter); //this will be the morse code for a single letter
delay(50);
Serial.println(morseLetter);
lastButtonStateLetter = buttonStateLetter; //the current button state is now the old one too;
//other buttons
checkSpace();
void checkSpace(){
if (digitalRead(spacePin) == HIGH) { //if space button pressed down
morseLetter = "";
char determineLetter() {
if (morseLetter == "01") {
return 'A';
} else if (morseLetter == "1000") {
return 'B';
} else if (morseLetter == "1010") {
return 'C';
} else if (morseLetter == "100") {
return 'D';
} else if (morseLetter == "0") {
return 'E';
} else if (morseLetter == "0010") {
return 'F';
} else if (morseLetter == "110") {
return 'G';
} else if (morseLetter == "0000") {
return 'H';
} else if (morseLetter == "00") {
return 'I';
} else if (morseLetter == "0111") {
return 'J';
} else if (morseLetter == "101") {
return 'K';
} else if (morseLetter == "0100") {
return 'L';
} else if (morseLetter == "11") {
return 'M';
} else if (morseLetter == "10") {
return 'N';
} else if (morseLetter == "111") {
return 'O';
} else if (morseLetter == "0110") {
return 'P';
} else if (morseLetter == "1101") {
return 'Q';
} else if (morseLetter == "010") {
return 'R';
} else if (morseLetter == "000") {
return 'S';
} else if (morseLetter == "1") {
return 'T';
} else if (morseLetter == "001") {
return 'U';
} else if (morseLetter == "0001") {
return 'V';
} else if (morseLetter == "011") {
return 'W';
} else if (morseLetter == "1001") {
return 'X';
} else if (morseLetter == "1011") {
return 'Y';
} else if (morseLetter == "1100") {
return 'Z';
} else if (morseLetter == "") {
return ' ';
} else if (morseLetter == "010101") {
return '.';
} else if (morseLetter == "110011") {
return ',';
} else if (morseLetter == "001100") {
return '?';
} else if (morseLetter == "10010") {
return '/';
} else if (morseLetter == "011010") {
return '@';
} else if (morseLetter == "01111") {
return '1';
} else if (morseLetter == "00111") {
return '2';
} else if (morseLetter == "00011") {
return '3';
} else if (morseLetter == "00001") {
return '4';
} else if (morseLetter == "00000") {
return '5';
} else if (morseLetter == "10000") {
return '6';
} else if (morseLetter == "11000") {
return '7';
} else if (morseLetter == "11100") {
return '8';
} else if (morseLetter == "11110") {
return '9';
} else if (morseLetter == "11111") {
return '0';
Serial.println("That's not Morse.");
boolean isDash(long input) { //true means dash, false means dot
if (input < cutoff) {
return false;
} if (input >= cutoff) {
return true;
Paul_B
April 10, 2022, 12:14pm
7
You would not want to confess to that insult to a telegraphist!
